Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 08-18-2013, 01:09 PM   #361
Johnnykash
My Ride: 2001 bmw 325i Sedan
Man **** just got this problem no reverse my car is a 2001 bmw 325i with the sports pkg wtf should I do? Do I have to get a new tranny that's what the mechanics telling me ;(. Any suggestions would be helpful I might convert to stick let me know some good shops in the DMV area if anyone lives around here
Johnnykash is offline   Reply With Quote
Old 08-18-2013, 01:20 PM   #362
Johnnykash
Unhappy So sad
How do I find out what kind of tranny I have? My car just won't go in reverse anymore it happened when I was in drive and then tried to reverse quick nd it wouldn't move. What should I do man any suggestions are extremely helpful in this trying time for me. It's a 2001 bmw 325i sports pkg so it might be the gm. This is really stressing me the **** out man
Old 08-18-2013, 01:28 PM   #363
dwtaylorpdx
My Ride: 2005 330xi
Did you start from the beginning of this thread?/ Its all there..
Dave
dwtaylorpdx is offline   Reply With Quote
Old 08-30-2013, 09:11 AM   #364
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You probably have a ZF tranny. Just take a quick look under the car and look at the tranny pan. If it has ribs in it, it is the ZF.
You need to remove the tranny and replace the reverse drum to fix it.
Look at post here describing that procedure:
DIY- How to replace reverse drum, ZF5HP19
(http://forum.e46fanatics.com/showthread.php?t=750714)
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 09-12-2013, 11:26 AM   #365
Skeens43
My Ride: 2000 328i (4dr/auto)
I bought a used 2000 328i in July. We've owned it 58 days and it's been in the shop for 43. I've about had it! Right now I don't know if it's the car or mechanic and would like to get some educated opinions. It's been a list of problems, but now it's the tranny. I talked to the previous owner and I know this: About 100,000 miles the car lost reverse and he had a pressured fluid change (with filter) that was supposed to flush valves, etc. Said the car never had another issue. He traded it with 128,000 miles and after three months on the lot, we bought it. During this time I just found out (after the sale) it once failed to go in reverse for the owner of the car lot, but started working again. We get the car and guess what? With no rhyme or reason, reverse works, then it doesn't. Turn the ignition off, restart, guess what? Reverse is working again. Works for a couple weeks and same thing, this is with the car warm and at the end of a 30-mile trip, no reverse. The mechanic drives it and says he drops it into reverse 10 or more times, no problem. Takes it home, gets in it coming to work, no reverse. Little while later, its working again. Here's my confusion - I mention to him if it's a GM tranny and he says it isn't. Of course I don't have the car to check myself either. In most post I've read it seems if it's NOT a GM tranny and the other kind, no one talks of it coming and going like this car, that it's always the reverse drum and reverse is gone. Get this too, they called to tell me they can't promise it will fix the trouble, but they're going to replace the reverse solenoid in the valve body. Can anyone weigh in here on what's going on? Does the FZ tranny loose reverse for good or can it be intermittent like this? Can it also be repaired with solenoid replacement? Did my mechanic miss quote and it can only be a GM tranny? Is my mechanic a dork and needs to find another occupation? Please tell me what going on!
Skeens43 is offline   Reply With Quote
Old 09-12-2013, 12:16 PM   #366
CORVAIRWILD
My Ride: Diesel Subrban 325xi
I'm just the gofer when it comes to trannys, but MOST mech's are dorks, and with cars going electronic, it's game over. Parts replacers will eventually solve the prob... But at a sig waste of time and money.
What's the answer in your case? Troll all the BMW forums, and there will be someone that works/worked at a tranny shop/dealer, and help you with your prob. You could try call a tranny parts wholesaler, like Rich at Winners Choice Tranny supply in Pa, he walked me thru all the probs with my "freshy" rebuilt 4L80E in my Silverado diesel pickup as I lined the burned up parts on a card table. Maybe he can recommend a shop??
http://www.winnerschoicetransmission...ign/Categories
In a junkyard, under a Teeruk!
CORVAIRWILD is offline   Reply With Quote
Old 09-12-2013, 12:16 PM   #367
CORVAIRWILD
I'm just the gofer when it comes to trannys, but MOST mech's are dorks, and with cars going electronic, it's game over. Pars replacers will eventually solve the prob... But at a sig waste of time and money.
Old 09-12-2013, 05:14 PM   #368
jrcarter_2000
My Ride: 323i
solenoid will not fix it, need to replace the valve body......had the exact same issue as you, mine is a GM tranny, pretty sure yours is too or your reverse gear is trashed and you don't get reverse intermittently......better to replace the valve body and be done with it. Even if it is just the solenoid it is not going to cost that much more labor wise.
I replaced the solenoid first and paid for the part/labor and the reverse went out again 3 weeks later.
jrcarter_2000 is offline   Reply With Quote
Old 09-12-2013, 05:43 PM   #369
Mr Podman
My Ride: E46 Coupe
Here is a link to help determine what transmission you have.
2000 328i has a GM Transmission.
2001 325i has a ZF Transmission.
Mr Podman is offline   Reply With Quote
Old 09-12-2013, 06:37 PM   #370
jrcarter_2000
My Ride: 323i
More info:
http://www.bimmerfest.com/forums/sho...d.php?t=458451
Bought my new valvebody from http://valvebodyxpress.com/
Old 09-12-2013, 08:48 PM   #371
CORVAIRWILD
Should I consider changing the valve body on my '03 325xi? 158k and seems to shift very well in my limited driving. Just got the tags, but no time to play with the "new" toy I bot in May, and Mrs drove home w "borrowed" tags
Old 09-12-2013, 10:53 PM   #372
CORVAIRWILD
Valve body ex doesn't have much info, just trans model number, no prices or year/application
Old 09-13-2013, 05:11 AM   #373
jrcarter_2000
My Ride: 323i
once you click on distributors and find one in your area they can give you price and other info
Old 09-13-2013, 07:13 AM   #374
CORVAIRWILD
I was just curious... I have 3 vehicles to sell b4 I can tinker with this one, and it needs a water pump, so may do the whole cooling system $$$... OT, but isn't the heater core plastic? I guess if the rad is fatigued, so would the HC? How hard is that to change? '03 325xi
Old 09-13-2013, 10:04 AM   #375
CORVAIRWILD
I think all the AWD xi's have the ZF
Old 09-13-2013, 10:06 PM   #376
BMWCaptain
HC is not plastic. Radiator sides are though.
Rarely hear of HC going bad.
BMWCaptainE46.com
Old 09-15-2013, 08:28 PM   #377
boostjunkie92
My Ride: 2004 330ci
Glad I found this
boostjunkie92 is offline   Reply With Quote
Old 09-17-2013, 10:27 AM   #378
Skeens43
It's a long story, but the dealership I bought my 2000 328i from is paying to have the reverse solenoid replaced for me. They admitted the tranny hadn't gone in reverse with them a couple times too and didn't tell me about it when I was buying it. I still don't have the car back so I have no way of determining which tranny I have for sure. I noticed once of the replies said the solenoid will NOT fix the problem and I should replace the valve body. Just wondering if someone could give me an idea of what a new or rebuilt valve body for either the GM or ZF tranny would cost me? Thanks!
Old 09-20-2013, 08:47 PM   #379
dogdaysunrise
My Ride: Sechsundvierzig
I got mine done for 800 for a friend.
It didn't work at first. He couldn't even back out of the shop after replacing the solenoids. Then next morning and days and weeks after it worked but only on occasion. Over time it engaged more and more often.
Now 6 months later it works all the time.
I got a 2000 323ci with GM.
love is the absence of fear
dogdaysunrise is offline   Reply With Quote
Old 09-21-2013, 08:25 AM   #380
CORVAIRWILD
Sounds depressing, but at least it works now
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
