Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 09-23-2009, 05:29 PM   #21
kpmg08
My Ride: 2005 325it
intermittent reverse
Thanks for this thread, can I have some clarification. I have an '05 325iT steptronic transmission. 115000km it is still under warranty until 120000
last week I experienced a similar no reverse as neil1138, like a second neutral. restarted the car and no problem. I took it to the dealer and they couldn't find anything. Does the 325 of this year have a similar issue?
Should I mention the solenoid possibility?
I'd like to get this resolved prior to the warranty disappearing naturally.
THanks for your input
kpmg08 is offline   Reply With Quote
Old 09-23-2009, 05:31 PM   #22
neil1138
If you are experiencing the same issues, then I would naturally assume it's the same problem. Tell your dealer about this and don't let them push you around. Even if they don't replace it under warranty, it's a relatively cheap fix, labor aside.
neil1138 is offline   Reply With Quote
Old 09-23-2009, 05:54 PM   #23
burntass
My Ride: ///m3 vert, 05 MCS
good read
2005 ///m3 cb/cinnamon vert: weekends
2005 Mini Cooper S/jet black hardtop: daily
1988 e30 325ix/gray hardtop: gone
2002 e46 tiag 325ci vert: gone
burntass is offline   Reply With Quote
Old 09-24-2009, 09:04 PM   #24
kpmg08
My Ride: 2005 325it
Should i assume from the symptoms that i have a gm transmission rather than a zf?
Would i be better with the solenoid fix or a new transmission, considering that its still under warranty?
Is a 2005 commonly affected?
Old 09-24-2009, 09:24 PM   #25
neil1138
Of course you have a GM tranny if your reverse problem is an on and off occurrence. You don't need a new transmission, the solenoid fix is a cheap, easy fix. Unless you just want to buy a new transmission for $5000 there is no point. Happen to have the last 7 of your VIN on you?
Old 10-03-2009, 11:21 AM   #26
M Shark
My Ride: '04 M3
Wow, this is great info. Thanks for sharing! You've put a lot of work into the research and clarified things better for all members.
M Shark is offline   Reply With Quote
Old 10-03-2009, 07:39 PM   #27
mjez
My Ride: bmw
Unhappy What about ZF???
so is there a cheap fix if you have ZF trans other then rebuild???
has anyone in Chicago area done rebuild? if so where adn how much did it cost you???
thanks
MJ
mjez is offline   Reply With Quote
Old 10-03-2009, 08:13 PM   #28
neil1138
Thank you! If it can help the members of this site and other E46 owners, I'm humbled to have done my part.
thanks
MJ
What problems are you having? What kind of car do you have? Maybe explain the problem a little and I can try to help you a little bit more
As ZF transmissions generally dont have a cheaper fix than to just replace the broken reverse drum
Old 10-04-2009, 05:20 PM   #29
brianabbott
My Ride: BMW 328i SE
Send a message via AIM to brianabbott Send a message via Yahoo to brianabbott
Very useful info Neil.
Thanks!
brianabbott is offline   Reply With Quote
Old 10-07-2009, 11:49 AM   #30
BMW_Stu
My Ride: HPF 330ci
Neil =
auto = <img src='http://forum.E46Fanatics.com/images/smilies/greddy.gif'>
BMW_Stu is offline   Reply With Quote
Old 10-07-2009, 09:28 PM   #31
highline740il
My Ride: BMW 740, 330, X5
I have a 2005 330ci automatic/steptronic. What transmission fluid do I need for a filter & fluid change. Is it Texaco or Esso. My 2001 740i steptronic (ZF tranny) uses the BMW Esso "liquid Gold"
The 2005 330ci has a GM steptronic.
Thank you,
Mike
highline740il is offline   Reply With Quote
Old 10-07-2009, 09:42 PM   #32
neil1138
Thanks!
Glad to help!
Originally Posted by BMW_Stu View Post
Neil =
Thank you,
Mike
That question is not pertinent to this thread at all
If you need help, pm me, don't post random questions, haha.
(I think GM transmissions take the Texaco fluid though)
Old 10-14-2009, 03:50 PM   #33
wmaurer
My Ride: 1999 black bmw 323i
my reverse went out at like 104k, given it was 10 years old. Its at 109 now.
W.Maurer
99 323i
98 ///M3
wmaurer is offline   Reply With Quote
Old 10-14-2009, 03:52 PM   #34
wmaurer
now, when my car is on a lift the reverse is fine. when its on the ground and reverse just revs the engine, and does slightly push it back if im on a flat surface. what does this mean?
W.Maurer
99 323i
98 ///M3
Old 10-14-2009, 04:32 PM   #35
neil1138
I dunno really, looks like you have the GM tranny according to your build date. Never heard of that happening ever.
Old 10-14-2009, 06:12 PM   #36
JEFFEFECKS
My Ride: 05 IB ZCP
Send a message via AIM to JEFFEFECKS
Your such a bad ass neil
'05 IB ZCP AA Stg 2
JEFFEFECKS is offline   Reply With Quote
Old 10-14-2009, 06:16 PM   #37
neil1138
Jeff, I read that you are going back to Cali soon . I need to give you that keyhole cover before you leave!
Old 10-14-2009, 06:25 PM   #38
JEFFEFECKS
My Ride: 05 IB ZCP
Ahaha nahh man. I'll be stationed here in OK for at least 1 more year. I wont leave and go back home until my next deployment which will either be starting this Jan or Jul. Either way after that deployment thats when i'll be out. Im sending my E46 back to Cali thats all
'05 IB ZCP AA Stg 2
Old 10-19-2009, 03:31 PM   #39
gfeiner
My Ride: 2003 330i
The solenoid/pressure regulator part Neil quotes is only for the 360/390 tranny. Here are the solenoids/regulators for the A5S325Z tranny: Anyone know which one is the reverse solenoid?
http://www.realoem.com/bmw/showparts...94&hg=24&fg=15
No. Description Supplement Qty From Up To Part Number Price Notes
01 Solenoid valve (SOLV) 3 03/2003 24341423368 $63.85 +core
02 PRESSURE REGULATOR 3 03/2003 24341423369 $159.49 +core
03 Bracket 2 03/2003 24341423370 $1.22
04 Torx bolt M5X12 4 03/2003 24341219933 $1.12
05 PRESSURE REGULATOR 1 03/2003 24341423461 $126.71 +core
06 Bracket 1 03/2003 24341423374 $1.22
07 Torx bolt M5X12 1 03/2003 24341219933 $1.12
gfeiner is offline   Reply With Quote
Old 10-19-2009, 03:36 PM   #40
neil1138
^ The ZF transmission is a different ordeal. It isn't the solenoid that goes bad, it's the entire reverse drum gear. This thread is for the GM transmission, that's why I only listed the parts for that one.
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
