Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 11-12-2013, 04:24 PM   #401
lszlszx
My Ride: 1.8T, XC70
Originally Posted by cwithbmw View Post
A lot of inaccurate info posted recently. This is almost always a case of the GM Valve Body. You can buy re-manufactured bodies with the Sonnex kits pre-installed.
That's the problem. You don't know for sure until a lot of $$$ is spent.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 11-12-2013, 04:41 PM   #402
cwithbmw
My Ride: 2002 330Ci 2009 335i
You are certainly correct, sorry for sounding like it is always the problem. As I did my research for my GM transmission, I found that replacing the solenoid or drum rarely fixed the problem for an extended amount of time. Whereas a new valve body helped consistently (also since GM recalled this transmission for this issue, it is most often the case).
cwithbmw is offline   Reply With Quote
Old 11-12-2013, 04:57 PM   #403
lszlszx
My Ride: 1.8T, XC70
I agree, when I had the no-reverse problem I read this whole thread.
It's an overstatement to call it "no-reverse solution", there have been maybe 2 or 3 owners who were able to fix the problem by replacing the solenoid.
What did GM say about the valve body? Do the bores wear out?
Old 11-12-2013, 06:28 PM   #404
cwithbmw
Now that I am looking it up again, I don't see the recall mentioned. However, Sonnex did a full case study on this transmission and the mis-design of the bore hole placement.
http://www.sonnax.com/publications/t...reverse-or-tcc
Old 11-12-2013, 11:27 PM   #405
CORVAIRWILD
My Ride: Diesel Subrban 325xi
Sure is technical!
In a junkyard, under a Teeruk!
CORVAIRWILD is offline   Reply With Quote
Old 11-19-2013, 02:38 PM   #406
Skeens43
My Ride: 2000 328i (4dr/auto)
For all those interested in what happened to the 2000 328i I own that we replaced the solenoid in a few months ago (with the ZF tranny), it started losing reverse again and I just can't own a car that I can't count on working properly. It's in the shop this week getting a remanufactured tranny installed - another $3,000 spent on this car... Funny, I though these were supposed to be some of the best engineered cars in the world, yet in my 49 years and a list of Dodge, Ford, GM, Honda products, I've spent almost as much money on this BMW than the rest combined... I don't get it.
Skeens43 is offline   Reply With Quote
Old 11-19-2013, 08:11 PM   #407
CORVAIRWILD
I have found that the rattiest rustiest greasiest cars usually run the best the longest. I've had lo miles cars have engine or tranny probs, and some with double or triple the miles go and go and go. I think it's cause stuff just gets worn in together. Kinda like an old timer that's just fading slowly. Used cars or trucks are a crapshoot, sometimes you win, sometimes you lose.
These forums really help... Example; A friend bought a junker '99 Subaru from a scammer dealer on ebay. So he finally had a good used engine installed, (not easy to find, Subbys have serious engine probs, and many are improperly repaired), so the repair guy is 100 miles away, totally honest, but even tho the car is running like new, the factory alarm flashes the parking lamps and dash lamps. The mech has never seen the prob, and the dealer mech says it may take 2-3 hours at $95 an hour to diagnose. A Google search has a simple 30 second solution...
Keep us posted on the prob w the tranny. Is it a rear drive? Mine is an xi, so ZF tranny.
Here's the video of my friend pkng up the Subby
Old 11-19-2013, 10:06 PM   #408
Skeens43
Thanks to all of you for the great comments! I totally agree with the remark that buying a used car is a crap shoot. I thought I did my homework on this car, drove it, talked the mechanics who'd worked on it, talked to the last previous owner, it seemed to all check out, yet it didn't take long for this car to start falling apart. You wouldn't think it either, meaning it looks like one the cleanest (inside and out) BMR's around. I paid $6,000 for it, have $2,000 in just trying to chase motor issues including plenum hoses, mass air flow sensor, idle control valve, all the vacuum hoses, plugs (just to mention a few things) just to get the check engine light to go out! Now I'm replacing the transmission, which by the way IS a ZF tranny because I looked at the tag myself, which will be another $3,000, yet this still doesn't fix the car! One of the windows stopped working so now I need a regulator, one ball joint is going bad so I need that, both sway bar links, both steering rack boots, a new blower motor (started chirping Friday), and waiting to hear if I need more engine work to either clean the VANOS, replace the MAP or the cam position sensor to get the cold idle problem repaired. Oh, forgot I've still got to get the ABS pump rebuilt or replaced to get the traction control light to go out. I'm thinking I'm going to have about $14,000 invested in this car before I get it fixed where all the issues are fixed and everything is working like it should. So tell me people, did I just buy the biggest lemon in the history of cars or is this just a typical story for a BMW owner? Right now I would say this is the one and only BMW I will ever own and won't recommend anyone buying one either. However, I'm hoping that if the car will behave and I stop the bleeding it will turn out to be a car I love and will love me back with some quality and trouble free thousands of miles still left in it. This certainly has been an experience I won't forget.
Old 11-19-2013, 10:50 PM   #409
CORVAIRWILD
My wife's 64 Corvair is the same thing... PIA
Old 11-20-2013, 09:46 AM   #410
My Ride: Lexus
I can pick apart your "story" in so many different directions.
First of all, you say you had to replace "xxx" part and "yyy" part to get the check engine light to go off.
What you really meant to say is that you let a "mechanic" diagnose your car and tell you what needed to be replaced and you swiped your credit card and said OK? Yes that's exactly what happened. Those parts you mention don't usually go out. You take your car to a mechanic and of COURSE you will spend $14,000 in maintaining it... especially when they're getting you to replace things like the idle control valve.
Learn how to work on your car, buy some tools, read the forums. you can use that $14,000 to build an absolutely bulletproof car with higher handling limits with perfection inside and out. (like mine) But your $14,000? It got you your check engine light off and clean oil and maybe a working driver's side window.
Have to use high intelligence to correctly spend your money using the best sites on the planet.
No "mechanics" that wrench on tractors and drink bud light.
Old 11-20-2013, 09:47 AM   #411
My Ride: Lexus
^oh also the first mistake you made was buying a 328. You could have used that 14k to buy two nice 330s. and you would've been far far ahead of the game.
323/328=abs failures among others
Old 11-20-2013, 01:30 PM   #412
CORVAIRWILD
Harsh... possibly/probably true, but harsh...
Old 11-26-2013, 07:25 AM   #413
CORVAIRWILD
Update?
Old 11-26-2013, 11:37 AM   #414
Skeens43
Mango, I want to give you the benefit of doubt realizing there are individuals whom sometimes don't weigh how abrasive and insulting their comments can be in attempt to be direct. Did you mean to be insulting to me? Did you mean to imply that I'm not of "high" intelligence? Good for you that you can spend your day's with your head under the hood of a car, but I can't because I'm an architect with a family who has more than my car to live for. (Virginia Tech graduate - not bad for being of less than "higher" intelligence, dont you say?) Granted, I've made some mistakes with this car and the intial mechanic I used and I'm humble enough to admit it. Yet, NO CAR should be this much trouble no matter whom is working on it! I'm 50 years old and have been fortunate enough to own some very fine cars including Chevy's, Ford's, Dodge's, even the Lexus I drive now, and without a doubt this BM'r has been the biggest turd I've ever owned. So Mango, it's your prerogative to criticize me for how I've chosen to solve the problems I've had (having) with this car, but I think I have a very valid point to question why can I put 200,000 miles on a Honda accord with just basic recommended service, yet this "superior" engineered BMW can't get out of the driveway without something falling off it? It's just a fact Mango that not everybody is a mechanic and that's ok. Humbly, I think you (and anyone else who happens to agree with your insulting post to me) should do a reality check and decide if it's my mistake being conceded to believe I shouldn't have to be a mechanic to own a BMW or more your mistake having to be one just to make your car reliable enough to compare to many equally and capable cars? I would appreciate any future remarks to me be made with respect and consideration. Thanks.
Old 11-26-2013, 09:16 PM   #415
CORVAIRWILD
Well said... I'm a gear head, and I can't stand to watch folks beat on their car, and mechanics that change parts to be make a buck. I see both all the time, this sounds like bad luck. My wife's '91 Honda Accord has 325k. I bot it ten years ago for $1000. It needed new tires muffler and seat covers. Ten years later, and no winters), little has gone wrong, a broken axle boot, muffler, tires, brake pads, the usual. Some cars runs and drive reasonably well, but are in need of extensive repairs. I used to see that in my garage repair business.
My xi is kinda like that, needs rear calipers, shocks, two leaky tires, broken intake hose, sludged up oil filter, two corroded lamp sockets, fuel pump etc, but it was looking good, ran real well, and was priced accordingly.
There's a reason folks buy brand new
Old 11-27-2013, 09:04 AM   #416
Skeens43
Corvairwild, THANK YOU for you're honest yet always thoughtful remarks. I hadn't looked back at this thread for a while till I got notified you wanted an update. That's when I seen the post from Mango and it flew all over me. I joined this forum to get answers not insulted and I just couldn't bite my tongue this time and it wasn't so much what Mango was trying to say (I think) but the careless way he went about saying it.
It's ironic that my dad was a great mechanic and spent my youth helping him do everything from rebuilding engines to restoring old lawn mowers, so I feel comfortable under the hood of a car (Maybe it would warm Mango's heart to know I still do my own brakes, oil changes, etc.). My point about this BMW is why do you have to be a mechanic to own one of these cars in the first place? Why do you have to buy your very own scan tool and constantly have a "to do" list of repairs just to keep these cars on the road? I keep repeating, I've owned plenty of other brands of cars and never had to buy a scan tool or join forums just to get answers of why do all these things keep going bad?
Mango was right to bring up the point about mechanics who are just "part replacers" which ironically is why I thought by taking it to a BMW mechanic it would alleviate that since (more than likely) that's all I would have been doing myself (considering my limited knowledge of the BMW).
It's really narrowed down to where I was merely asking is the type issues I'm having typical for a BMW or is it just THIS particular car? Honestly, I'm still not clear on what the answer is since I hear people talk about getting long life out these cars, yet it's mostly just people who have time, tools and mechanical knowledge to work on themselves whom say it. In my heart I want to believe this car of mine is just a victim of lack of care and maintenance and it's just landed on my lap to repair and get the car back into shape and when I do, this will be as good a car as I've ever owned. I can dream, right?
Can I assume you own (or owned) a classic Corvair? My dad owned one these cars for several years and LOVED it! It's ironic we're talking about the reputation BMW's have considering the negative things said about the Corvair (at the time). Thanks to Ralph Nader, right?
Thanks again Corvairwild for your support and kind words. It's people like you that give forums like this a good reputation and a place you can seek assistance like it's intended.
Old 12-06-2013, 02:33 PM   #417
mikeetastic
My Ride: lots of 3
Hi guys, bought a cheap 2001 323CI Vert a few days ago with a broken reverse transmission since i'm planning a Manual Swap..
is it normal for the car to be really slow accelerating? throttle is not responsive and even if i press the pedal hard it's still the same.. car is fine on a freeway though it's just slow on the street and stop lights.. or transmission is totally unrelated and i have a different issue?
Thanks all for the inputs.
mikeetastic is offline   Reply With Quote
Old 12-06-2013, 09:55 PM   #418
fire730
My Ride: 01 325iT - 04 Burb
It may be transmission related. Is the car actually taking off in first gear from a stop? It may be in a limp home mode and taking off in a higher gear.
01 325iT ZSP - Koni - Hotchkis - Stoptech
01 525iT - TiAg - Koni - B&G
04 Chevy Suburban - SLP - BlackBear - Belltech
01 330Ci - parts car
16 Chevy Tahoe - Wife's Daily
fire730 is offline   Reply With Quote
Old 12-06-2013, 10:30 PM   #419
mikeetastic
My Ride: lots of 3
how would i know? i can do the manual and its doing S 1-5? sorry no idea because this is my first bmw automatic.
i have no cel lights or anything, its just the car has a hard time pulling.
Old 12-06-2013, 10:44 PM   #420
fire730
Does the take off feel different if you have it in full automatic or M 1st gear?
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
