Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 04-17-2014, 07:50 PM   #441
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Also if you disassemble the valve body, do not mix up the accumulator parts (the 4 large round cylinders) the springs are color coded and are supposed to go back in the same place based on the attached bulletin.
ddaniel1 is offline   Reply With Quote
Old 04-17-2014, 09:00 PM   #442
lszlszx
My Ride: 1.8T, XC70
^^ Thanks! That's a nice shot of the check ball locations!
^ I didn't know that about the accumulator springs, but my intuition was to keep them in order.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-17-2014, 11:15 PM   #443
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
In addition to the mechanical failure, the solenoids also fail electrically, below are shift solenoids, the coil failure caused me to lose 4th gear:
The fourth gear solenoid that was bad, at only six months the coil had failed, 10.2 ohms:
Here is a good one, 15-17 ohms for the shift solenoids:
Here is a chart with the ohm values and pins so you can check your solenoids from outside of the transmission, I would do this before opening the pan, TCC solenoid discussed in this thread should be 10-11.5 Ohms:
Old 04-18-2014, 08:46 AM   #444
CORVAIRWILD
My Ride: Diesel Subrban 325xi
This is so cool!
In a junkyard, under a Teeruk!
CORVAIRWILD is offline   Reply With Quote
Old 05-03-2014, 10:31 AM   #445
fraserp
My Ride: 2006 e46 Cic
Originally Posted by sweetbro858 View Post
Abrasive... insulting? Probably.
You shouldn't take anything personal on the internet/forums. Use the positive comments/recommendations and disregard the negative stuff.
Your car is old and you should be able to find out anything you need to know by searching forums and reading. Anything you think about posting has probably already been asked numerous times.
Also, if you have some basic tools... you are highly capable of replacing parts yourself.
+ 1
And if I may say that sometimes the truth can be a little painful. But not necessarily disrespectful. ---- look at it this way -------- I was blind but now I see
fraserp is offline   Reply With Quote
Old 05-03-2014, 02:29 PM   #446
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by lszlszx View Post
Experience shows that the problem is the valve body.
To be specific, it's the wear of the lockout bore.
If replacement of the solenoid didn't fix it, my next step would be to install the reverse lock out bore repair kit.
See picture above!
I agree with this. I did not know of the bore kit when my car would not select R with any degree of reliability, but I did know of the solenoid. My car was cured with a new solenoid and fresh fluid, but it makes sense to clear the bore while the transmission is open, instead of opening it twice.
I think the bigger point is that if you have the GM5L40E and it will not go into R, you can cure it for less than $100 in parts, plus the price of fresh fluid.
Old 05-03-2014, 02:35 PM   #447
jdstrickland
Neil isn't active right now on the forum.
The forward gears aren't problematic on these transmissions.
+1, the forward gears are not a problem.
I think it was Joy that asked what GM stands for. GM stands for General Motors.
GM used this transmission on some of its cars and issued a recall for No Reverse. BMW elected to not issue a recall.
Old 05-03-2014, 07:14 PM   #448
CORVAIRWILD
GM just recalled some cars for non-functioning or improper reading fuel guage. There must be many issues that surface on the internet, and manufacturer chooses to ignore, but knows about, plays the "let's wait and see" game
Old 05-06-2014, 08:15 PM   #449
pistonhead76
My Ride: 2000 323i
Hello everyone. Im about to buy another e46 as posted here:
http://forum.e46fanatics.com/showthr...1#post16143400
and Im wondering has there been any reverse failures in the 03-04 ZF's?
pistonhead76 is offline   Reply With Quote
Old 05-20-2014, 02:23 PM   #450
Solo118
My Ride: '17 750i, MDX
Send a message via AIM to Solo118
Hey guys
I am actually debating between 2 cars- but something does not seem right.
03 330ci, has GM A5S 390R, great as I want to avoid the ZF tranny.
Now I am also looking at an 04 330ci, but the vin decoders are saying it has the ZF A5S 325Z! How is this possible if they used GMs from 3/2003 and up? Build date on this one is 7/2004 so it strikes me as a bit odd!
Solo118 is offline   Reply With Quote
Old 05-20-2014, 04:49 PM   #451
lszlszx
My Ride: 1.8T, XC70
We don't see many failures with the later model transmissions, GM, or ZF.
Old 05-21-2014, 08:30 AM   #452
CORVAIRWILD
take a peak underneath, and try the pan bolt count?
Old 06-12-2014, 10:26 PM   #453
Mikey1952
My Ride: E46 Coupe
Auto problem
I am experiencing the same problem and this post has given me some clues now tho find out what goes
Mikey1952 is offline   Reply With Quote
Old 06-12-2014, 11:45 PM   #454
CORVAIRWILD
Keep us posted!
Old 06-13-2014, 11:36 PM   #455
riverjamie
My Ride: 528i
Update on GM 5L40e trany leaking out of breather on 2000 e39 528i
I ended up taking it into a good German Trany shop. They rebuilt the forward pump (it's located behind the Torque Converter inside the trany, by replacing two solenoids on it. Also had them replace the Torque Converter and Rear Main Seal. So far so good, no more blowing ATF out of breather on GM 5L40e trany on my 2000 528i.
riverjamie is offline   Reply With Quote
Old 06-14-2014, 12:26 AM   #456
Mikey1952
My Ride: E46 Coupe
Mike is a ZF for a 6 cylinder 330ci I have had it diagnosed and I heard the clutch or bearing spinning around when revved up it's definitely knackered
Old 06-14-2014, 12:15 PM   #457
Akip
My Ride: Nothing for now
Same thing happened to my old 98 auto e36 320i but in drive it doesn't engage to first gear. But when knob is in 2 I was using first gear. I changed oil and filter, filter was terribly choked up. I didn't want to repair and used it like that for a while. One day I shifted to n and shut the car in downhill when it's moving at 10mph. Then shifted to d. It harshly engaged to first gear and after it works like it should. never did this again for 10k miles. Maybe this can help you guys too.
Sent from Tapatalk with my G2
Akip is offline   Reply With Quote
Old 07-04-2014, 06:48 AM   #458
Brucifer325
My Ride: 2007 Ford Edge
Just wanted to throw my $.02 in here.
I'm having the reverse issue, too, at 140k. Going to replace the TCC. HOWEVER, since it's a GM tranny, I've found the GM part number: 24227747
It can be found here by Rostra: http://www.makcotransmissionparts.com/74418E.html
Or get the AC/Delco version just about anywhere: http://www.amazon.com/ACDelco-242277.../dp/B000IZ3NVU
This is the way I am going with mine. I see this as a GM problem, not BMW, so I don't see the point in paying BMW prices. I'm going to make sure the mechanic takes care in removing the solenoid so that if there are any missing parts, we might be able to fish them out though I'm sure they would have worked their way into the valve body by now.
Originally Posted by SPDSKTR View Post
I'm doing something wrong with my life.
"Love Us with Money, or We'll Hate you with Hammers!" - Milk & Cheese
BMWCCA# 147961
Brucifer325 is offline   Reply With Quote
Old 08-20-2014, 09:44 PM   #459
shredstar
My Ride: E46 328Ci, E36 ///M3
May as well add my experience to the list. My teenager's 2000 328Ci began the 100% random no reverse at 190K. It would fail once or twice a week. Before we parked we would op check the reverse. If it worked, we parked with confidence because we knew it would work when we left. If it didn't, all we had to do was run the car up to highway speed a few miles and it would come back. It seemed to fail more frequently if the car sat for a few days not driven. It never failed cold....unless it was not working when we parked and let the sit overnight. In that case it still would not work. After spending two months trying to come up with any kind of trend (which we never did because it was totally random, other than only happening when warm and at low pressure) we decided to fix. Upon removal of the pan and the TCC solonoid we found that the filter/screen was completely detached and blocking the reverse lockout bore. By driving the car to highway speed after reverse failed, it would dislodge the filter enough to allow reverse to work until it got in the way again. Disassembled and cleaned valve body, replaced wiring harness, replaced TCC solonoid, seals, gaskets, filter and fluid. Problem completely fixed and no issues since.
shredstar is offline   Reply With Quote
Old 08-20-2014, 10:34 PM   #460
lszlszx
My Ride: 1.8T, XC70
It's exactly what happened to mine, I documented it.
Even if the fix didn't work, getting 190K out of the box is something.
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
