Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 01-28-2010, 09:37 AM   #81
BigMikeE46
My Ride: 02 325i, 03 SC COBRA
Send a message via AIM to BigMikeE46
Well...I was going to buy a second car today..a 323i 2000...But now I'm a bit worried. Well, at least I know what to check for when I see the car later today.
Engine is bone stock, rims and tires, 7000k Angel eyes, 7000k Low beam/Fog, Tinted windows ??%....may the mods begin!!!
Below is a pic taken on 1/16/10
Photobucket
BigMikeE46 is offline   Reply With Quote
Old 02-09-2010, 04:15 AM   #82
Jaryn26
My Ride: 330ci
so has anyone actually done this to their transmission?
Jaryn26 is offline   Reply With Quote
Old 02-11-2010, 04:34 AM   #83
LOCUST1978
My Ride: 325ci sport converti
Hi, what a brilliant forum, this thread is the reason i have signed up,my 1st post.
I have a 2001 325ci auto convertible uk spec, and i have been suffering with an intermittent reverse problem.
As described, it comes and goes, it hasnt failed on me, but sometimes when cold, it will rev and move slowly, after a min or so it will engage reverse fine.
I find the table a little confusing as to which gearbox mine has, can anyone help to diagnose if its the solenoid problem ?
Thanks in advance.
LOCUST1978 is offline   Reply With Quote
Old 02-11-2010, 01:34 PM   #84
Jaryn26
My Ride: 330ci
just go under there and look at the tranny itself it will tell you
i think you have a zf not sure i also have a 01 and its zf so this solenoid doesn't pertain to us
Old 02-16-2010, 07:52 PM   #85
leopoldoguti
My Ride: E46 328i
Send a message via MSN to leopoldoguti
Originally Posted by pyo View Post
Damn, it happened again after working all day yesterday. Crossing my fingers that it will come back after some driving, I'm geting tired of pushing my car back and then hopping in before I rolls away from me.
Actually i have the same issue, 328i reverse only works sometimes, and if before i park the reverse works then the reverse will work when i get back in the car.
So every time i park i make sure the reverse works, if it doesn't i look for a different spot...
leopoldoguti is offline   Reply With Quote
Old 02-16-2010, 08:37 PM   #86
thisguy408
My Ride: 2000 Bmw 328i
this just happen to my 328i car last week i wonder if i hav ethe ZM or GM thingy transmission BMW is such a harsh car to fix OMG... i think i might just sell my 1999 bmw 328i with 120,000 miles for 4300 grand you guys think that is a fair amount???
thisguy408 is offline   Reply With Quote
Old 02-16-2010, 08:55 PM   #87
neil1138
You'll be glad to know it's an easy fix!
You have the GM transmission, woot
neil1138 is offline   Reply With Quote
Old 02-17-2010, 11:48 AM   #88
leopoldoguti
My Ride: E46 328i
[QUOTE=neil1138;11333947]You'll be glad to know it's an easy fix!
Yeah, my car is in the Shop right now.
My mechanic will check every solenoid and replace the reverse one, and while he is there put some new fluid and filter... should be good by this afternoon
ill let u guys know how it goes
Old 02-17-2010, 01:09 PM   #89
pyo
My Ride: Z4 3.0i '04
Send a message via AIM to pyo Send a message via MSN to pyo
Got the solenoid replaced as well as fluid and filter. Was working fine for 2 days then it stopped working after all day of driving. Drove 10 min and everything was fine again. No hiccups since. Hope it stays that way
2000 328i [Sold]
2004 Z4 3.0i 6spd
pyo is offline   Reply With Quote
Old 03-26-2010, 04:38 PM   #90
Toad21
My Ride: 00' 328CI
Son of a monkey. My reverse didn't work today. It just started working again, but I know I need to do something now.
I have a GM transmission. Is there a link to a full tutorial? Ill keep reading and if I find one I will link it.
Toad21 is offline   Reply With Quote
Old 03-27-2010, 01:21 AM   #91
DaHammer
My Ride: 2003 325i
Neil or anyone else that cares to chime in. Everything in this thread is specific to no reverse. Could one of the solenoids be the cause of a slow to engage drive? Same symtoms as the no reverse with the GM trannies, except it takes a few seconds for drive to engage also on a GM tranny. I know there is a TSB for this and BMW was replacing the trannies at first under the TSB, but later changed the TSB to update the software. Also, (bare in mind I know very little about the internals of trannies) if it's just a clogged screen in the solenoid, why can't you just clean the screen instead of replacing the solenoid?
DaHammer is offline   Reply With Quote
Old 03-28-2010, 03:21 AM   #92
maxi
My Ride: BMW E46 328I, 1999
+1 regarding cleaning the solenoid. Also I have Q, You said that it's clogged, What is making this solenoid clogged?. is it somthing in the fluid?! and could we clean the other solinoids as a maintenance every time we change the fluid?
I have anther problem in trans. ( harsh shift from 1-2 during warm up ) I dont know what causing this prob.
But you Mr. Neil open the ideas to me to think about my problem.
Thanks for you.
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 03-29-2010, 08:46 PM   #93
Pipebomb
My Ride: E39 E46
This happened to me so I replaced the solenoid Saturday. Everything worked fine the rest of the weekend until today. It failed to go into reverse twice today so far. Drive it a bit and everything seems normal again. Here is my thinking.... I believe the valve itself is the problem. I think the solenoid can go bad but there is also the possibility that debris is causing the valve to stick. Anyone else feel free to chime in with any other ideas.
Pipebomb is offline   Reply With Quote
Old 03-30-2010, 02:57 PM   #94
Toad21
My Ride: 00' 328CI
Where is a good step by step tutorial to do this yourself?
Old 03-30-2010, 02:58 PM   #95
Toad21
My Ride: 00' 328CI
What tutorial did you use?
Old 03-30-2010, 03:16 PM   #96
pyo
Same situation as you. Replaced solenoid, worked fine for a few days and then started acting up once in a while. Haven't found a solution yet, but if you a post wouldbe much appreciated. I'll do the same.
2000 328i [Sold]
2004 Z4 3.0i 6spd
Old 03-30-2010, 05:09 PM   #97
neil1138
If the solenoid didn't fix it, that could be troublesome. Cleaning out the valve body isn't easy, if you decide to take it apart, best of luck getting it back together properly. I honestly don't have advice for doing valve body work, that's over my head. For what it's worth, you could try cleaning it without taking it apart but I don't know how well that would work. We could move to simpler things like taking a look at the electronics behind the gear engagement. Take a look at your internal transmission wiring harness, I know when I took mine out, it was so brittle who knows if it was going to go bad at some point. Have you guys tried fluid changes, at the very least a filter change? Maybe the whole problem is behind there being too much gunk in the valve body and when you put a new solenoid in there, it just gets gunked again? I kinda confused here because I've never heard of this failing for so many people, there must be another underlying problem causing your no reverse
Old 03-31-2010, 12:11 AM   #98
Toad21
My Ride: 00' 328CI
Neil, could you so kindly give me a list of things to do? I have read this entire thread and there is no 1st step that I know of.
Should I just use the regular transmission flush tutorial, and then when the pan is off replace the solenoid?
http://forum.e46fanatics.com/showthr...ighlight=trans
Old 03-31-2010, 11:59 PM   #99
Pipebomb
My Ride: E39 E46
UPDATE: Car still shifting fine. Have been driving it the past couple days to work and everywhere else and reverse still works. If it comes down to it and I do pull the valve body, I will definitely take pictures. I have a couple very knowledgeable people at my disposal when it comes to rebuilding them.
Old 04-01-2010, 09:28 PM   #100
Toad21
My Ride: 00' 328CI
Pipebomb, what was the step by step procedure you used?
I find it hard to believe that is not in this thread somewhere.
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
