Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 09-21-2009, 08:56 AM   #1
David F
My Ride: 323i, 740iL, 633CSi
Alternative aux-in, usb charging port installed (OEM BMW)
I installed a BMW aux-in/USB port over the weekend. My car has a new gen headunit that can accept the aux-in port. I spliced this alternative port into the BMW standard aux-in cable (standard port installed in glove box). Let me know if you have any questions.
ID:	332144   Click image for larger version
Name:	Break off plastic fitting.jpg
ID:	332145   Click image for larger version
Name:	cut back metal tube.jpg
ID:	332146   Click image for larger version
Name:	wire usb cable to usb port pins.jpg
Name:	usb wired up.jpg
ID:	332148   Click image for larger version
Name:	usb port wiring complete.jpg
David F is offline   Reply With Quote
Old 09-21-2009, 08:58 AM   #2
David F
more photos....
Name:	assemble audio wiring.jpg
ID:	332150   Click image for larger version
Name:	wiring complete.jpg
ID:	332151   Click image for larger version
Name:	aux-usb port installed.jpg
ID:	332152   Click image for larger version
Name:	cover plates installed.jpg
Name:	usb power supply.jpg
ID:	332154   Click image for larger version
Name:	power supply circuit.jpg
Old 09-21-2009, 08:59 AM   #3
David F
final photos...
Name:	splicing into BMW aux-in cable.jpg
ID:	332159   Click image for larger version
Name:	splice complete.jpg
ID:	332160   Click image for larger version
Name:	splice wrapped.jpg
Old 09-21-2009, 09:10 AM   #4
David F
Part numbers:
61.31.3.129.652 Aux-in/usb port
61.13.8.380.696 universal socket (connector) housing (4 place)
61.13.0.006.663 wiring contacts with wire pigtails (need 3)
51.16.8.236.252 single position switch cover (blank). BMW makes 1, 3, 4 place covers, no 2 place covers for some reason.
All USB power source components were sourced from the Shack (aka Radio Shack). I wired the usb power supply to the cigar lighter...always on. I would recommend that any device be disconnect from the USB power socket whenever the car is started or switched off to avoid dirty power spikes from potentially damaging any connected device.
If anyone has a part number for the BMW usb connector, please let me know....
Old 09-21-2009, 05:39 PM   #5
Orion329
My Ride: MKV GTI
nice install, looks very well done. if only i had a an aux in in my head unit....
Orion329 is offline   Reply With Quote
Old 09-21-2009, 09:11 PM   #6
blk04zhpcpe
My Ride: 2004 330ci zhp coupe
Hi David_F. What kind of features does this item have ? Does it offer what the Grom usb unit is supposed to do ? Playback from memory sticks ?
blk04zhpcpe is offline   Reply With Quote
Old 09-22-2009, 01:08 AM   #7
Orion329
My Ride: MKV GTI
he's simply using the aux in from the head unit, the usb is solely for charging in his application. you'll need to get a GROM and do some wiring to get this usb port to work for you. the part is only a jack and usb port that is designed by BMW--wired for aux/power.
Old 09-22-2009, 10:42 AM   #8
lamb.chop
My Ride: MCS R53
The connector used is called HSD (High Speed Data),
see here :-
http://www.rosenberger.de/en/Products/40_HSD.php
lamb.chop is offline   Reply With Quote
Old 09-26-2009, 07:24 PM   #9
blk04zhpcpe
Thanks for the info guys. guess i'm grom bound. that outlet does make for a nice looking install.
Old 11-03-2009, 03:39 PM   #10
subliminalaudio
My Ride: 325ci
hey greattttttt wooork ...
im interested on doing the same but im very bad with circuits
can you sell me the whole item pre made and i can wire it up ?
thanks !!!
subliminalaudio is offline   Reply With Quote
Old 11-03-2009, 09:18 PM   #11
Sean S
My Ride: 2001 325i
Gah I wish I knew about this part number before purchasing my USB panel.
Just out of curiosity, how much was each part and where can we purchase them?
Sean S is offline   Reply With Quote
Old 11-03-2009, 11:39 PM   #12
Orion329
My Ride: MKV GTI
hey David F, where did you purchase the Aux/USB port? it doesn't come up on getBMWparts.com.
Old 11-05-2009, 11:16 AM   #13
CoconutPete
My Ride: E90 330i
The part # works on pelicanparts.com.
The word "there" can appear as a pronoun, as in “over there."
"Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.”
”They're” is a contraction of “they are.” “They are” should always be able to replace “they're.”
Extra Credit: It's "I'm looking for an M3"
not "I'm looking for a M3".
CoconutPete is offline   Reply With Quote
Old 11-05-2009, 03:14 PM   #14
Orion329
My Ride: MKV GTI
thanks Coconut Pete, but it doesn't seem like the part number 61313129652 is coming up there either for the Aux-in/usb port he used.
i hadn't heard of them before....of course they do seem to have about a 30% mark-up over Tischer.
Old 12-03-2009, 10:00 AM   #15
KrisL
My Ride: 03 330i ZHP
Send a message via AIM to KrisL
David,
Thank you for this!!
KrisL is offline   Reply With Quote
Old 04-13-2010, 09:25 PM   #16
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
I like how stock and how much utility you get from this mod?
1. Are you able to charge and use AUX input at the same time?
2. Where did you get the parts; I haven't been able to pull the part numbers from Crownauto, Pelican or Tischer.
3. Is there anyway to improve or avoid power spikes when turning the car on of off?
4. How much in parts did it cost you?
phamine is offline   Reply With Quote
Old 04-14-2010, 10:21 AM   #17
starsky
My Ride: 2001 325i
Thanks for bumping this thread, I would love to add a clean looking port like that to my carpc project but is something like this available for the single button style (not individual buttons)? Also I have not been able to find the part using the part number as well.
starsky is offline   Reply With Quote
Old 02-12-2011, 09:17 AM   #18
mjweimer
My Ride: 1995 M3 - 2001 325iT
Updated Info
I have done a little more research after not finding the 61.31.3.129.652 part number currently listed. It seems that the following part numbers will work for this retrofit (thanks again David F!) including the correct plug housing for splicing in the USB cable. I plan to order the parts shortly and will report back.
Diagram #9
USB/AUX-IN socket - 61 31 9 129 651
For vehicles with:
USB/audio interface (S6FLA) = Yes
And:
Preparation, mobile phone, Business (S633A) = No
And:
Preparation f mobile phone w Bluetooth (S644A) = No
And:
Prep., Smartphone Bluetooth USB/audio (S6NFA) = No
Diagram #
10
Plug housing on request - 61 13 3 333 333
For vehicles with:
And:
And:
And:
mjweimer is offline   Reply With Quote
Old 02-14-2011, 04:25 PM   #19
phamine
^^^Nice Due Diligence=]
Old 06-01-2011, 03:19 PM   #20
naginalf
My Ride: 325XIT
Oh how I wish I had seen this before I hacked up that exact same spot in my dash. Although I don't think it would work in mine, I don't have removable panels. Mine doesn't look bad tho. I had this monoprice ipod adapter that plugged into the lighter socket and had an audio output and FM transmission (don't need it with aux in, much better), but the darn plastic pos broke in 1 day, so I hacked it up and installed it into my dash. Worked pretty well. But I like this better, perhaps I'll look into this. Thanks!
naginalf is offline   Reply With Quote
