Miscellaneous
Old 09-23-2009, 07:53 PM   #1
Dreamliner330
My Ride: 330xi
PC: 2.66 Q9450, 4GB RAM, 896MB GTX 260, 1280GB in RAID
PRICE: $950
High-End Desktop PC Quad Core 2.66Ghz, 4GB RAM, 896MB GTX 260, 640GB HD (Raid 10), DVD/RW, MODULAR 650W PSU, ANTEC CASE & COOLING + TONS OF SOFTWARE
INCLUDES: MAXED OUT PC WITH ALL THE EXTRAS
About This Listing
This listingis for a like new desktop computer. This computer is my personal desktop computer that I have owned for just a few months. I am going to describe in detail what the computer consists of. There are many elements that separate this pc from your 'standard box order,' and I will describe them here. I have A LOT of pictures, trying to show all the detail possible.
When I built this PC, there were a few things I had in mind. I wanted it to be FAST, ORGANIZED, WELL COOLED AND SILENT. This computer achieves this. All of the fans are set in such a fashion that everything in the computer is cool to the touch, ensuring longevity. This is because there are many fans constantly spinning at a slow speed to remain silent. They still move large volumes of air, keeping it very quiet. There is an Arctic Cooling CPU cooler on the processor, this has a much larger fan, and also helps to keep everything cool and quiet. I also spent A LOT of time to make sure all of the cables are well organized in the case. You will see in the pictures below, there are not giant bundles of cables everywhere to connect power and signal to the 4 hard drives, 2 DVD drives, 4 fans and Dual Power video card. it is well organized, allowing high air flow.
  • The Q9450 2.66 Ghz Quad core chip has a massive 12MB of cache, this is the heart of the computer and really, provides for a massively fast computer.
  • The motherboard is an ASUS P5Q-E, I ONLY use Asus motherboards now, I have have ZERO reliability issues with them, and they always have many features. The EPU-6 control power management and allows the PC to operate in a reduced power state.
  • The memory is the top of the line OCZ Reaper 1150 Mhz Memory. They have large cooling pipes for heat dissipation and are very reliable.
  • To make sure the hard drives keep up with the rest of the system, this computer is utilizing 4 HARD DRIVES in a RAID 10 ARRAY. This means, 4 Hard Drives are working together as 1 to provide data at blazing fast speeds to eliminate slow downs.
  • The Optical Drives include a SATA DVD Burner as well as a standard DVD-ROM
  • A 896MB GTX 260 Video card was installed, this card honestly is incredible. I can run Far Cry with all settings on MAX and its smooth as can be.
  • The Antec P150 Case is my favorite, it is subtle, and has cooling and components in all the right places. the hard drives are separated with fans mounted in front to keep the drives cool to the touch, and the case has really thick steel with rubber grommets, eliminating rattles and buzzes. It also includes an air filter to stop dust before it gets inside your pc.
  • The Power supply is a Modular ANTEC NEO 650W. This means you only have to plug in the power cables for the devices you have and not have a giant bundle of unused cables with it.
  • If there was a place to put a fan, I installed one, everything is cool to the touch and I have resistor modules installed so that the fans are not extremely noisy. This keeps airflow up, with noise and temperature down.
Of course this computer maxes out the Vista benchmark utility, with a score of 5.9 across the board. (See pic below). This Everything is impeccable and looks absolutely brand new as it has only been used for a few months.
It is so difficult to find a desktop that has the right combination of features, this computer has all those features. All of these components on Newegg are a bit over $1300. This is without the software or having everything put together (you can see from the pictures how meticulous I was running the cables). I have this computer ready to go and I will ship it the day payment is received.
There is also a good deal of extra components (drive trays, screws, cables, etc) that will all be included with this as well.
BELOW YOU WILL SEE A LIST OF THE MASSIVE AMOUNT OF GAMES/SOFTWARE I AM INCLUDING WITH THIS LISTING.
You will enjoy this computer, if you have any questions send me a email and I will reply as quick as possible, Bid with confidence, thanks for looking and good luck!
ABOUT THE COMPUTER AND PACKAGE INCLUDED WITH THIS COMPUTER:
FULL SPECS
ITEM BRAND DESCRIPTION
Processor
Intel
Intel Core 2 Quad Q9450 (2.66GHz/1333MHz FSB/45nm/12MB Cache)
  CPU Cooler Arctic Cooling Freezer 7 Pro
Operating System
Microsoft
Windows Vista Home Premium 32Bit
Motherboard
Asus
Asus P5Q-E (P45 Chipset/EPU-6/DDR2 1200)
Memory
OCZ
OCZ Reaper 4GB DDR2 SDRAM 9200 (1150MHz) (4 DIMMs)
Hard Drive
Western Digital
(4 Hard Drives in Raid 10) 320GB (640GB Usable in Windows) Western Digital SATA Hard Drive (7200RPM, Single Platter)
Optical Drive
LG
LG 22X CD/DVD Burner w/ double layer support
  Optical Drive 2 TEAC DVD ROM
Video Card
EVGA
896MB GeForce GTX 260
Power Supply
Antec
NEO Power 650w Modular Power Supply
Case Antec P150 (Silent Case)
  Cooling Antec 2x 92mm fans in front, 1x 120mm fan in top back, 1x 80mm fan low back
SOFTWARE INCLUDED
Far Cry 2
Call of Duty: World at War
Half Life: The Orange Box
Knights of the Old Republic
Ghost Recon: Advanced Warfighter
Half Life 2
Untreal Tournament 2004
Photoshop Album 2.0
--COMPONENT HIGHTLIGHTS & WEB REVIEW LINKS
PROCESSOR - http://www.overclockersclub.com/reviews/intel_q9450/
With four processing cores, 12MB of shared L2 cache and 1333 MHz Front Side Bus the Intel Core 2 Quad desktops processor delivers amazing performance and power efficiency enabled by the all new hafnium-based circuitry of 45nm Intel Core microarchitecture.
Whether you're encoding, rendering, editing, or streaming HD multimedia in the office or on the go, power your most demanding applications with notebooks and desktops based on the Intel Core 2 Quad processor.
MOTHERBOARD - http://www.tomshardware.com/reviews/intel-p45-chipset,1961-6.html
  • Intel LGA775 Platform
  • Intel® P45 chipset
  • ASUS 8-phase Power Design
  • Dual-channel DDR2 1200/1066/800/667 MHz
  • 100% High-quality Japan-made Conductive Polymer Capacitors!
  • ASUS EPU-6 Engine
  • ASUS Express Gate
  • ASUS Drive Xpert
  • VRD11.1 CPU support (backward support VRD10.X CPU)
MEMORY - http://www.dvhardware.net/review139_ocz_reaperhpc_9200.html
  • The Reaper HPC is an innovative patent-pending cooling solution developed by OCZ to effectively minimize heat produced by high-speed memory. As heat rises into the thermo-conductive copper heat pipe conduit, it is dissipated through the strategically-placed compact aluminum fin array. By guiding performance-robbing heat away from key memory components, the unique Reaper HPC design helps facilitate improved overclocking performance, while improving longevity and stability of the modules.
    The first modules to be incorporated with the new Reaper heatsink are rated at 1150MHz and run at CL 5-5-5. As part of OCZ's line-up of premium memory, PC2-9200 modules are backed by a Lifetime Warranty and industry-leading technical support.
HARD DRIVE - http://www.silentpcreview.com/article819-page1.html
The Caviar SE16 series will lead this new 320GB platter into the market starting with a single-platter 320GB desktop hard drive, model WD3200AAKS, that will feature a 16MB buffer and Native Command Queuing. All of the other specifications of this drive adhere to the Caviar SE16 line with a SATA 3.0 Gb/sec interface and a maximum buffer-to-disk transfer rate of 972 Mb/sec.
The hard drives are setup in RAID 10, this means that 2 drives are 'striped' together for maximum speed, and then 'mirrored' on the other two for reliability. This is how the drives are logically setup:
VIDEO CARD - http://www.tomshardware.com/reviews/nvidia-gtx-280,1953.html
Beyond the field of play, GeForce GTX 260 seamlessly shifts tasks from the CPU to the GPU, allowing you to dive into the latest Blu-ray movie, surf the web in 3D, or transcode video to a personal video player up to 7x faster than traditional CPUs1. Now you can work and play at full speed.
MID-TOWER CASE - http://www.silentpcreview.com/article272-page1.html
This case is Silent & very sleek/clean looking with air filters to reduce dust inside the PC.
Model
P150
Case Dimensions
17.5"(H) x 8.1"(W) x 18.5"(D)
Drive Bays
- Front Accessible
- Internal
8
3x5.25", 1x3.5"
4x3.5" or 3x3.5" with HDD suspension
Expansion Slots
7
Cooling System
- 1 rear (standard) 120mm TriCool Fan with 3-speed switch control
- 2 front 92mm fan mounts (fans not included)
Main Board Size
12"(W)x9.6"(L)
Weight (net/gross)
25.3/30.3 lbs
11.5/15.7 K
Motherboards
Standard ATX
Special Features
Internal mounts with rubber grommets
Optional HDD suspension system
Poly carbonate side panels to reduce noise
Advanced cable management system
Front USB/FireWire Ports
Package Includes
1 Tower Case
1 NeoHE 430 installed
1 set of screws and motherboard standoffs
1 Installation manual
PICTURES OF WHATS INCLUDED IN THIS LISTING
WHATS INCLUDED IN THIS AUCTION
INTEL Q9450 2.66GHZ PROCESSOR
ARCTIC COOLING FREEZER 7 PRO
ASUS 95Q-E MOTHERBOARD
OCZ REAPER 4GB DDR2 9200 (1150MHZ)
4 HARD DRIVES - 320GB WESTERN DIGITAL, 640GB USABLE IN WINDOWS
896 BM GEFORCE GTX260 VIDEO CARD
LG DVD BURNER
TEAD DVD ROM DRIVE
ANTEC NEOPOWER 650W POWER SUPPLY
ANTEC P150 CASE
2X 92MM FANS, 1X 120MM FAN, 1X 80MM FAN
WINDOWS VISTA HOME PREMIUM
FAR CRY 2
CALL OF DUTY: WORLD AT WAR
HALF LIFE: THE ORANGE BOX
KIGHTS OF THE OLD REPUBLIC
GHOST RECON:ADVANCED WARFIGHTER
HALF LIFE 2
UNREAL TOURNAMENT 2004
PHOTOSHOP ALBUM 2.0
HURRY AND CONTACT ME TODAY!!!
Dreamliner330 is online now   Reply With Quote
Old 09-23-2009, 07:53 PM   #2
Dreamliner330
My Ride: 330xi
