Sponsored by The Tire Rack
Old 05-20-2002, 10:43 AM   #1
BAVARIAN323i
Ballin'
My Ride: 1999 323i
Send a message via AIM to BAVARIAN323i
I have a slight rapid shutter in my steering wheel, is that just because i'm on 18s
& New England roads suck,
BAVARIAN323i is offline   Reply With Quote
Old 05-23-2002, 10:29 AM   #2
BAVARIAN323i
Ballin'
My Ride: 1999 323i
Old 05-23-2002, 01:23 PM   #3
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
Did you get it right after you got the 18s on?
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
Old 05-23-2002, 07:23 PM   #4
cb's/328ci
My Ride: 2003 M3
you need to get them re-balanced...
2002 M3
Imola red
cb's/328ci is offline   Reply With Quote
Old 05-23-2002, 07:40 PM   #5
BAVARIAN323i
Ballin'
My Ride: 1999 323i
no about a month or 2 after
Old 05-23-2002, 07:46 PM   #6
cb's/328ci
My Ride: 2003 M3
one of the weights may have been kicked off...Its happened to me a few times...I dont know, something to check I guess
2002 M3
Imola red
Old 05-24-2002, 08:20 AM   #7
Jano
My Ride: 2001 330i
I noticed that my car is more prone to lateral movement even on what appears to be smooth roads. With 18's I have 235's in front and 255's in back so I am guessing that the increase width along with brand new S03's are following the road imperfections too closely. I've never had excessive vibration though. If they are the same size rotate them and see what changes. And as the others said, of course have the balance checked.
Jano is offline   Reply With Quote
Old 05-24-2002, 09:01 AM   #8
eddie@tirerack
Police Officer
My Ride: 03 Dodge Intrepid
Could be roads.. I notice on some roads on my jaunts to Chicago it can shake EXCESSIVELY. more than likely your balance is off. BMWs are the most sensitive to balance. You could have a wheel weight off a bit, or have slightly bent a wheel.
You should have a shop attempt to rebalance your wheels, hopefully that will take care of it.
eddie@tirerack is offline   Reply With Quote
