Technik Headers and Header Install Kit Part #'s - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-26-2010, 03:55 PM   #41
bigseth2468
My Ride: 2002 325Ci
I found mine used. Watch the forums closely!
bigseth2468 is offline   Reply With Quote
Old 06-07-2010, 11:03 PM   #42
TrickTizzle
My Ride: 325i
Im thinking about getting some headers on the stock exhaust aswell. Can you post some videos of the sound? Thanks
Old 06-29-2010, 11:36 PM   #43
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Nice thread on miscellaneous header install parts - Thanks
phamine is offline   Reply With Quote
Old 06-30-2010, 07:13 PM   #44
Jackcat559
My Ride: 2003 530
Where's a good place to purchase the o2 sims?
Jackcat559 is offline   Reply With Quote
Old 06-30-2010, 08:22 PM   #45
bigseth2468
My Ride: 2002 325Ci
I would pm Anthony@BimmerBrakes for your O2 sims. Tell him bigseth2468 sent you and he will hook you up! Good luck!
Old 07-12-2010, 06:49 AM   #46
lkstaack
My Ride: 04 330iZHP, 05 325iT
Do Technik Headers prevent access to the cooling system drain plug? Are O2 Simulators 100% effective at preventing EMLs and passing Smog?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 07-12-2010, 01:04 PM   #47
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
In my case, they are 100% effective in preventing an SES. If you live in a state with a sniffer, you won't pass.
Old 07-12-2010, 01:18 PM   #48
lkstaack
Unless you have an aftermarket Cat, right? Do your pipes interfere with the cooling system drain plug?
Lars
Old 07-12-2010, 02:57 PM   #49
Jackcat559
My Ride: 2003 530
That does bring up a good question. Which aftermarket cat works best for a header set up? Mine trows a code every so often
Old 07-12-2010, 03:09 PM   #50
aggieE46
Keep it clean
aggieE46's Avatar
Correct. I dunno, I'd have to look. I'll be under the car in a few days, I'll let you know, then.
If you're going to run aftermarket cats (for the sake of the environment), I suggest just installing them but still running a simulator. A lot of aftermarket cats will still throw codes. I ran the Magnaflow cats.
Old 07-12-2010, 03:54 PM   #51
Jackcat559
My Ride: 2003 530
I picked up a sim, and still want to run a cat. Just curious which one mught work better than what I have, the system is coming out anyway to add a resonator
Old 07-12-2010, 04:51 PM   #52
aggieE46
Keep it clean
aggieE46's Avatar
Magnaflow is your best bang for the buck.
Old 07-12-2010, 05:32 PM   #53
Jackcat559
My Ride: 2003 530
thanks hopefully that didn't thread-jack too much
header, install, kit, part, technik
