///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 09-25-2009, 11:47 PM   #1
love dodge
My Ride: soon m3
The R/T button on steering wheel doesnt work
Yes as the title says:My R/T button on the steering wheel does nothing when i press it...What this thing suppose to do?I have a 03 m3 btw.
I think is the mode button but im not sure....thanks a lot
love dodge is offline   Reply With Quote
Old 09-25-2009, 11:52 PM   #2
UTL1098
My Ride: DINAN 135i, T4R LE
You probably don't have the bluetooth kit installed in the car, or your phone is not properly paired. Check your trunk (left side behind carpet kit) to make sure you have a ULF.
Looks like this:
UTL1098 is offline   Reply With Quote
Old 09-26-2009, 12:00 AM   #3
Shuskan3
My Ride: 2004 M3
It displays the phonebook on the radio display if you have bluetooth.
2004 Carbon Black/Grey BMW M3
Hardwired V1 ~ Turner Motorsport Front and Rear Sways w/ Ground Control Endlinks ~ Powerflex RTAB’s ~ OEM BMW Performance SSK ~ ZHP Shift Knob ~ Painted Reflectors ~ Bluetooth ~ Satellite Radio ~ CDV Delete ~ Clutch Stop ~ Euro Tray ~ 19” CSL Wheels ~
18” OEM Wheels for the track
Shuskan3 is offline   Reply With Quote
Old 09-26-2009, 12:02 AM   #4
UTL1098
That's assuming his phone is properly paired. Doesn't seem like that's the case.
Old 09-26-2009, 12:13 AM   #5
Shuskan3
My Ride: 2004 M3
Correct.
Old 09-26-2009, 12:16 AM   #6
trudnick
My Ride: 2005 M3
The pairing code can be found on the Bluetooth unit itself (there's a couple stickers on the unit you can easily remove, I took one and placed it inside my user manual in the glovebox for future reference). You have to remove the left (driver's side) trunk lining to get to the unit.
Good luck.
2005 BMW ///M3 / Carbon Black / Black Leather / 6MT
OEM BMW Performance Short Shift Kit, Illuminated ZHP Knob, XM Direct, DICE iPod, Color Matched Reflectors, Hoen Fogs, Stealth Corners, V1 (3.872) Hardwire, Eibach Pro-Kit, RE 15mm-F/12mm-R Spacers, CDV delete, Clutch Stop, Summer OEM ZCP 19s: Vredestein Ultrac Sessantas (245/275), Winter OEM 18s: Dunlop SP Winter Sport M3s (225/255), Self-installed OEM Alarm & OEM Homelink UGDO.
trudnick is offline   Reply With Quote
Old 09-26-2009, 12:25 AM   #7
sahib
My Ride: Carbon/Cinnamon///M3
i have a r/t button but no bluetooth...how would i go about getting one?
sahib is offline   Reply With Quote
Old 09-26-2009, 01:35 AM   #8
2003 bmw m3
My Ride: 2003 M3 tiag vert
yeah i have the r/t button and i look at my trunk and it says that im prewired for bluetooth and oem alarm but i don't have any of these things yet just prewired
2003 bmw m3 is offline   Reply With Quote
Old 09-26-2009, 02:05 AM   #9
UTL1098
You will need to purchase a BMW bluetooth kit. Here's where I got mine:
http://www.bavariansoundwerks.com/pr...oth-Phone-Kit/
Old 09-26-2009, 02:58 AM   #10
trudnick
My Ride: 2005 M3
Call your local dealer and get the correct part number for the BT module for your model year and then give Tischer a call, odds are Tischer will have the best pricing for any OEM part. I believe the OEM BT part number is 84216958358, but this varies depending on the year. Install is a no brainer.
Old 09-26-2009, 06:03 AM   #11
love dodge
My Ride: soon m3
Question
Looks like this:
that's right I don't have the Bluetooth kit.But I do have the little talking face on the steering wheel plus the R/T button.I was checking on the manual and it says that the R/T button is the MODE button, meaning u can switch between CD and Radio(on my case).That's true?If it is something is wrong with my button because when I press it doesn't do anything.
Old 09-26-2009, 11:11 AM   #12
trudnick
My Ride: 2005 M3
R/T = Radio Mode / Telephone Mode. It's not wired to switch between the cd and radio. If you don't have Bluetooth the R/T button does nothing.
Old 09-26-2009, 04:53 PM   #13
WytLytnyn
My Ride: 2005 M3 6MT
Good luck.
Ironically, when I first got my car, I went to the dealer because I was erroneously told that they would have to do something in order for it to be paired. The service advisor kept telling me that the code was the last five numbers of the VIN! After that didn't work and no one in the service department had a clue, I laid rubber out of the place and never went back.
Since one of my friends works at BSW, I called him and he told me to pull back the liner and look at the code on the unit. Worked like a champ.
So that was the last time I ever go to a dealer for anything....
WytLytnyn is offline   Reply With Quote
Old 09-26-2009, 06:59 PM   #14
love dodge
My Ride: soon m3
Makes sense....
Old 09-26-2009, 07:02 PM   #15
love dodge
My Ride: soon m3
Wait a minute here....If i have the bluetooth kit when i press the button it should at least "say" anything...right?I dont understand this stuff man...im confused
Old 09-26-2009, 07:19 PM   #16
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
Call your local dealer and get the correct part number for the BT module for your model year and send Tischer an email, odds are Tischer will have the best pricing for any OEM part. I believe the OEM BT part number is 84216958358, but this varies depending on the year. Install is a no brainer.
fixed...send an email to bmwpartsdepot@mileone.com
bimmer07 is offline   Reply With Quote
Old 09-26-2009, 11:09 PM   #17
Darkoz
My Ride: E46 325Ci
That's correct, if you have bluetooth you press the R/T button to end the call.
Darkoz is offline   Reply With Quote
Old 09-28-2009, 12:16 PM   #18
WytLytnyn
Hold the button down for several seconds and there will be a loud beep with a guy's voice asking for your command.
At that point, you can ask for it to:
1) You can "Save Name" by which you record a name and save it then save the digits.
2) "Dial Name" (after you've saved a name in the system - after you've paired the phone with the car). It will ask you to verify the name and then call them.
3) "Dial Number" - you can read off the digits and it will call. The system always says "Continue?" after you've stopped speaking. At that point you respond, "Dial".
4) You can have it "Read Phonebook" by which it goes through all the names that you've saved. You can also "Clear Phonebook" to reload the contacts that you want.
Those are all the commands I know. I believe that some of the other car systems can also control the NAV system, but I might be wrong.
For some reason, there is a massive discrepancy between the volume of the local system (beep, voice) and the volume of remote callers/receivers in my car. Always catches me off guard!
I was kinda hoping that I could get the BT reprogrammed with the voice of Madeline Kahn's character, "Lilly Von Stupp" from Blazing Saddles!
Old 09-28-2009, 12:33 PM   #19
profM3
My Ride: 2005 M3 ZCP
To learn more about OEM bluetooth and BMW E46 cars start by reading this post
http://forum.e46fanatics.com/showpos...8&postcount=18
And then this one is good:
http://www.m3forum.net/m3forum/showthread.php?t=230898
2005 M3 Silbergrau Metallic on black; 6MT, ZCP, ZPP, ZCW, Nav, Dinan exhaust, two AR20 resonators in section 1, Autosolutions SSK, Fucy CSL diffuser, Intravee II, illuminated ZHP shift knob, stealth V1 install with ash tray remote, OEM first aid boxes under both seats, Ultimate pedals and more...
profM3 is offline   Reply With Quote
Old 09-28-2009, 01:52 PM   #20
jbcritch
My Ride: 2005 Steel Blue 325i
That's odd. I press the "talking man" button to make and end calls. I only use R/T to toggle between the Radio and Telephone.
2001 330Cic AW/Sand- ret.
2003 330i SB/Grey - ret.
2005 545i 6spd BLK/Black - ret.
2005 325i SB/Grey - ret.
2007 550i Grey/Black
Mods: M5 mats, M5 spoiler, tint....for now.
jbcritch is offline   Reply With Quote
