323ci hid light or d2s, 35v or 55v - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-26-2009, 01:03 AM   #1
loulou657
My Ride: 2000 323ci
323ci hid light or d2s, 35w or 55w
Hi, i have a 2000 323ci non-project head lights(stock) and i was planning to buy hid kit and i was wondering which bulb to order h7 or D2S and 35w or 55w. Any other recommendition or suggested website to purchse.
loulou657 is offline   Reply With Quote
Old 09-26-2009, 06:46 AM   #2
ATF
My Ride: plows snow.
No no no.. you do not put HID's in non-Projector, reflector bowl style headlights. That's dangerous and illegal.
Nick | BMWCCA 403399 | flickr
ATF is offline   Reply With Quote
Old 09-26-2009, 09:48 AM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
eh, some cars come with them from the factory without projectors.
but if i was you i'd just order the depo lights from one of our sponsors...they look a million times better
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 09-26-2009, 11:04 AM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Your car does not have xenon headlights, you need H7 replacement bulbs if you want to just upgrade the factory bulbs.
I suggest looking into the Xenesis Tru Match Bulbs which are hyperwhite replacements for your car.
If you want a true xenon output, then your best option would be a set of Projector46 Headlights which are complete projector based headlight replacements to swap out the entire assembly for a xenon setup with preinstalled angel eyes.
Old 09-27-2009, 10:51 AM   #5
loulou657
My Ride: 2000 323ci
i know my car doesnt have xenon light and that what i want to do.. i wanna buy hid conversion kit but i dont know which kind of bulb to order and how many V 35 or 55....because some guy told me if i put the 35 i will get a lamp out warning and the lights will flash and shut off and the computer sees less power and causes the warning and tries to shut the power to the circuit off.
Thanks all for the replying
Old 09-27-2009, 11:35 AM   #6
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
don't do it bro
firefirefire90 is offline   Reply With Quote
Old 09-27-2009, 01:16 PM   #7
ATF
Education time.
You'll pick 35 or 55 watts, not volts.
Those values will adjust your brightness measured in mcd.
You'll most likely want error cancellers regardless unless you choose to drive around with your HIDs on at all times.
P46's are a bare minimum to utilize HIDs efficiently and safely. Using HIDs in a reflector style headlight will spew very bright light and blind oncoming traffic.
Old 09-27-2009, 06:14 PM   #8
loulou657
My Ride: 2000 323ci
Originally Posted by firefirefire90 View Post
don't do it bro
Why ?
Old 09-27-2009, 06:17 PM   #9
loulou657
My Ride: 2000 323ci
Originally Posted by ATF View Post
Education time.
You'll pick 35 of 55 watts, not volts.
Thank you for the information
Old 09-27-2009, 06:21 PM   #10
firefirefire90
Banned
I used to work in the lighting business; HID's in non-projector housings and in reflective halogen housings put the amount of light given out by an HID bulb(lets say... halogen brightness x5) and you get this big sloppy mess that blinds other drivers and does not give you the full effect that the HID is designed for.
Why do you think they are called "projector" lights? They project the light(much like a projector) in a much cleaner, detailed beam rather than a bulb surrounded by shiny bits used to reflect the light off and create the inefficient beam.
Old 09-27-2009, 10:08 PM   #11
loulou657
My Ride: 2000 323ci
Thank you so much for the information. i didnt know about that. i think im going to order projector headlight and hid as well,but which hid ballast would i get 35W or 55W, would the 55w affect my battery or the wires?
Old 09-27-2009, 10:15 PM   #12
firefirefire90
Banned
it just depends on how bright you want it to be. 35W is more than adequate... but a lot of folks like the brightness of 55w!
example of 35w vs. 55w(halogen)
(on a plane but same deal)
35W HID on left, and 55W halogen on the right
to make it even more clear, your High beam is, if I'm not mistaken, a 50W Halogen...
The 55w will not affect your wiring or battery. Initially, HID's take a little bit more power to turn on, but they take less to run while in use.
323ci, 35v, d2s, hid, light
