Old 09-26-2009, 04:31 AM   #1
Tankzor
My Ride: 2002 325i
EML Light, Yellow Brake Light, Car wont accelerate
Today on my way home and I was stopped at a stop light and when I took my foot off the pedal to accelerate, the EML light started flashing, the brake light came on (yellow instead of red), and my car would not accelerate. When I pushed the gas my car would buck and would roll but not accelerate. I had to put the car back in park, shut off the engine and start it again inorder to get it to accelerate. This happened twice on the way home and it makes me nervouse because im a student and I dont have much money just lying around.
I searched around and there seems to be alot of similar experiences, however I have not seen a follow up as to what was actually wrong and how the problem is solved. Any help I would appreciate it, Hopefully its DIY-able. If not, i gotta start saving. Thanks - Tank
Tankzor is offline   Reply With Quote
Old 04-01-2011, 06:39 AM   #2
gaBeamin
My Ride: E46 325i
I am gettin all the lights: Yellow EML, Brake, Service engine soon and Its crazy and I gotta take it to the shop today. I hope it ain't nuthin serious but I will update the post none the less.
gaBeamin is offline   Reply With Quote
Old 04-01-2011, 08:15 AM   #3
SPDSKTR
My Ride: Needs a'fixin'!
For the EMIL, sounds to me like bad ignition coils. It happened in my Acura and my VW when I had them. Brake light? Not sure.
SPDSKTR is online now   Reply With Quote
Old 04-01-2011, 08:56 AM   #4
gaBeamin
My Ride: E46 325i
The car still drives, it just when i shift into gear there is a thump as well as the lights being on. It don't pick up as quickly but it still picks up. I just don't know wha's goin on with my ride. I have no mods just an intake.
Old 04-01-2011, 09:07 AM   #5
shanneba
My Ride: 2003 330Ci
The EML light normally indicates a problem with the electronic throttle control, electronic accelerator pedal or the Idle speed actuator.
The Brake and DSC lights may also come on because the DSC system uses the electronic throttle to increase/decrease engine torque for stability control.
Have the codes read from both the emissions and DSC systems as a start to diagnosing the issue.
http://www.bmwmotorsports.org/BMW_docs/m54x5.pdf
Emergency Operation of Idle Speed Actuator:
If a fault is detected with the idle speed actuator, the ECM will initiate failsafe measures
depending on the effect of the fault (increased air flow or decreased air flow).
If there is a fault in the idle speed actuator/circuit, the EDK will compensate to maintain idle
speed. The EML lamp will be illuminated to inform the driver of a fault.
If the fault causes increased air flow (actuator failed open), VANOS and Knock Control are
deactivated which noticeably reduces engine performance.
The earlier MS42 ECM E46s had a throttle cable but still used an electronic throttle. They had two failure modes for the EML:
http://www.beisansystems.com/misc/SE...ROL_SYSTEM.pdf
MDK EMERGENCY OPERATION
If a fault is detected in the system, the following modes of operation are:
• Emergency operation 1 - Faults which do not impair safety, but which adversely affect
the functioning of the MDK.
• Emergency operation 2 - Applies when faults are encountered which might impair safe
driving operation.
• Emergency operation of idle speed actuator.
Join BMWCCA
Old 12-23-2011, 01:39 PM   #6
Mrmegaducky
My Ride: 04 e46
EML and yellow brake light possible fix
Ok I understand ur pain here bc today it happened to me. During my oil change , btw, DIY only costs $80, I removed the sensor above the oil filter and forgot to reattach it. After a bit of driving I remembered and car immediately went into idling and those lights came on. What I immediately did was pull over and reattach the sensor and reset the battery. Y detaching it and waiting about a minute and attaching it again. Reset it all and ran normally after that. Hope this helps someone
Mrmegaducky is offline   Reply With Quote
