Please help! Eml+asc light=broken car!!!! - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 01-11-2011, 09:32 AM   #41
Bimbals
My Ride: e46 320i
Hey guys,
I used to have the same problem with codes P1580 and P1542. Other symptoms were: poor low end performance, engine stalled.
In my case, I manged to repair my old MDK.
It appeared, that the butterfly had a play (a minor play as it seemed to me). The butterfly did not reach the FULL CLOSED position because of a spring, that forces the butterfly to fully close, got weak. So what did I do? I installed a plastic "wire cover" (dimensions DxdxL: 2x0.8x10 mm) on the end of the spring. Now the butterfly fully closes.
The symptoms did not come back, and since then I have made >1000 km. The engine has better response in low rpms.
After this "modification" I was very surprised: the vanos rattle has gone!!!
That is my lucky story. I hope it will be helpful for somebody.
Bimbals is offline   Reply With Quote
Old 01-11-2011, 05:38 PM   #42
devansthedude
My Ride: BMW 323i E46 1999
Thanks Dephantn, ill buy a new throttle body and see how it turns out. The only issue is that i live one and a half hours away from the dealer so i'm trying to source a gt1 or equivalent so i can reset the adaptations, if i cant find one looks like ill have to get a car trailer.
devansthedude is offline   Reply With Quote
Old 04-05-2011, 12:59 AM   #43
Tom86951
My Ride: 323ci/951
2000 323ci has throttle cable or drive by wire?
Thanks...
Tom86951 is offline   Reply With Quote
Old 05-11-2012, 04:17 PM   #44
DrkSide_RbL
My Ride: 99' 328i Sport Sedan
Send a message via AIM to DrkSide_RbL
I eventually used Seafoam brand throttle body cleaner and lubricant to clean the throttle body up again and so far good for 2k miles...
Sent from my SAMSUNG-SGH-I777 using Bimmer App
DrkSide_RbL is offline   Reply With Quote
Old 05-14-2012, 07:42 PM   #45
DrkSide_RbL
andddd the problem is back... EML+ASC (traction control) lights that are on. It also seems to come and go....maybe the electronic module on the throttle body is broken and the whole thing needs to be replaced....
Old 05-18-2012, 02:40 AM   #46
DrkSide_RbL
my final conclusions...
There are only 3 things that could go wrong related to this problem: EML+ASC (traction control) lights are throttle body related issues.
1. Throttle flaps get stuck due to sticky residue which can be cleaned out.
2. Throttle position sensors are bad which is imbedded into the throttle body (mechanical cable set up).
3. Wire harness is not plugged into throttle body correctly or the wire harness itself is faulty.
If any of these issues occur it will send a signal to the computer which will put the car into limp mode.
Old 12-12-2012, 10:17 PM   #47
DrkSide_RbL
changed the throttle body. did throttle reset twice. give your ecu time to process new tb. didnt have to reset adaptations. car is back to normal. all lights gone.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 03-01-2013, 04:08 AM   #48
uberwheel
My Ride: bmw 328ci
it happened to me too. first time i stalled it (bad weather, tires were frozen to ground) Suddenly a limp bmr! idle fine, touch the gas and seemed as though the engine was misfiring. Read manual, says eml code is for engine timing out of sync and to "see your BMW specialist" no thanks, i like to save money. So, being the cheapo I am, I like to start every problem with a look a fuses. Pulled all fuses for engine control (27, 29 and 30 for my 328ci) fuses were ok, but somehow this reset the engine sync on the computer. VOILA! running great again! eml is gone. Try it. worked for me... saved me calling for a tow.
uberwheel is offline   Reply With Quote
Old 12-07-2013, 11:15 PM   #49
Jesse weller
My Ride: 99 E46
I'm having the same problem too. F**k this car. I've been working on it for a week. I put it back together and still same thing. I'm going to atemp one more time thanks for all the info. If i get it fixed ill report back. If not I'll put a list of parts. And belive this bit$h will be smashed. Good luck guys.
Jesse weller is offline   Reply With Quote
Old 09-02-2015, 04:11 PM   #50
jvidamins
My Ride: 2000 328i Manual
Sorry to resurrect an old thread, but I've got the same problem. I checked the resistance across all the pins as dephantn instructed and all the readings are as they should be. I gave it a good clean and also cleaned out the ICV, DISA, and MAF. Also, replaced a boot that had a tiny crack. Yesterday, I was out for a drive and the lights came on again (day before it was driving fine). I reset them and they came on 2 more times. After the last reset, I noticed my rpm's would climb a little on every shift (I have a manual) instead of dropping slightly. I made sure I wasn't holding down the gas pedal or anything. I then just left the clutch in and saw that the rpm's just weren't coming down hardly at all. My pedal didn't seem to be sticking or anything. Here's a video I took while it was happening.
When I got home, I revved it to 4k, and as it was slowly coming down, I gave the accelerator pedal a good yank backward (even though it felt like it was already) and the rpm's sudden came down like normal. Then I couldn't get the problem to resurface. Could this be the MDK's coil springs clogged with grime or something, or maybe the throttle cable sticking? Any ideas???
jvidamins is offline   Reply With Quote
Old 05-21-2016, 09:51 AM   #51
hussnainshakir
My Ride: BMW 525i 2002
2002 525i .. plz help. EML ASC issue
Hi guys. First time I'm writing here. Gotta problem with same eml asc issue... its been around 3 to 4 months since my eml asc lights off and on comes on when I switch the car on ...with same race( rpm)drop to 10% .. switch the car off ... then on. . It's gone. The problem comes one in a week or 10 days. I once changed the throttle body 2 months ago. the problem vanished for a month N returned back. The new thing that happened is that the eml asc lights get back during the drive N without the power cut or race (rpm) drop. I drove back with normal speed to home. Then switched the car off N then on.. they r gone . Now the car is behaving normally N I'm waiting when the next episode comes... any suggestion plz
hussnainshakir is offline   Reply With Quote
