Old 09-28-2009, 12:46 PM   #1
fieldsc
My Ride: 330i
Drivetrain kicks when I shift
I have a 2001 e46 330i with 125 thousand miles. When I shift gears, the back end of the car thumps. It's definitely not the transmission. I can control how hard the car kicks by how quickly I engage the clutch. Its far more noticeable in the lower gears then it is in 4th and 5th. What bushings should I be inspecting?
fieldsc is offline   Reply With Quote
Old 09-28-2009, 12:47 PM   #2
inlinesicks
My Ride: E46, Jeep, Subaru
Diff bushings and subframe mounts
inlinesicks is offline   Reply With Quote
Old 09-28-2009, 12:58 PM   #3
fieldsc
My Ride: 330i
Do you know of a diagram showing where the rear subframe mounts and bushings are? thanks
Old 09-28-2009, 09:52 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Guibo.
Old 09-29-2009, 09:41 PM   #5
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I'd say it's most likely the rear differential bushing. When it goes bad, the diff can move upwards and bump in to the rear floor, causing that clunking sound.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 10-20-2009, 11:27 PM   #6
motostar508
My Ride: 2000 323CI
Send a message via AIM to motostar508
I just bought a car and I kinda think I hear the same noise... its not horrible bad sounding and when I control the clutch good its less noticeable.. My 323ci has 128k on it, is this something that goes bad commonly, and is it hard to fix?
motostar508 is offline   Reply With Quote
