Old 09-29-2009, 05:15 PM   #1
LLCoolJeff
My Ride: '99 323i 4d
rattling only with ac on
so i have narrowed down a rattle to only when the ac is on which leads me to believe it is the compressor that is rattling and not the a/c belt system because that is spinning even when the a/c is off. am I correct? or could it still be one of the pulleys in the a/c belt system?
If it is the compressor, is there any way around buying a new compressor? they're ridiculously expensive and ill just live with it if it comes down to that.
I live in arizona so the a/c had been perpetually on since i bought the car. Now that im experimenting what happenns when it off I have noticed that it shifts a lot rougher with the a/c off. Is this normal?
LLCoolJeff is offline   Reply With Quote
Old 09-29-2009, 09:52 PM   #2
eweis
My Ride: 1999 328i
I also have this problem on a '99 328i. When I turn the a/c on, it rattles, as you say, or chatters or knocks as I would describe it. First, thing I did was replace the a/c belt tensioner (and the other tensioner and pulley) but that didn't resolve it and the old a/c belt tensioner didn't seem to be worn out.
It makes this sound upon a/c startup and most typically when sitting at idle. Not dedectable while driving.
The a/c works fine and there are no codes being thrown.
Anyone else have this problem or know of a solution or way to investigate further?
eweis is offline   Reply With Quote
Old 09-29-2009, 10:02 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I get quite a bit of noise from it as well.
Old 09-29-2009, 11:52 PM   #4
LLCoolJeff
3 people so far with the same problem, i was thinking of changing my tensioner as well, but if it doesnt fix it then i guess im glad i didnt waste my money on it. Anyone know what is causing this common problem?
Old 09-30-2009, 01:11 AM   #5
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
I had this same problem, a rattling noise only when the A/C compressor was on. I lived with it for a little bit but it started to trigger my SES light. I eventually ended up replacing it. The noise is being caused by a bad pulley on the A/C compressor. Unfortunately, the only fix is to replace the entire compressor.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-30-2009, 02:41 AM   #6
LLCoolJeff
im not positive myself but isnt that called the comrpessor clutch? cant that be replaced without replacing the whole compressor unit?
Old 09-30-2009, 05:37 PM   #7
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
The A/C compressor is all or nothing. I suppose you could find a shop to tear it down and rebuild it for you, however. I'd save that headache and just buy a new one.
-Gary
Old 09-30-2009, 05:43 PM   #8
mick22589
My Ride: 2001 330i, 72 cutty
yeah my compressor clutch went. it would click when i turned on the ac and also when i hit the brakes because it was shifting. just got a new compressor, although a guy did say he couldve just replaced the clutch for me.
mick22589 is offline   Reply With Quote
Old 09-30-2009, 06:02 PM   #9
LLCoolJeff
how much did you pay for the new compressor?
Old 09-30-2009, 06:19 PM   #10
mick22589
got one out of a junkyard...paid 60 bucks for it and 100 for the install.
Old 10-01-2009, 12:14 AM   #11
LLCoolJeff
when you buy that from a junkyard, you are really just gambling that a) it works, and b) it too doesn't rattle when turned on like the current one.
Am i correct? or can you return them if its not performing right?
Old 10-03-2009, 09:30 AM   #12
mick22589
nope no guarantees...but wth it was 60 bucks ya know? no biggie
Old 10-27-2009, 03:20 AM   #13
maxi
My Ride: BMW E46 328I, 1999
I have the same prob in 99 328i, it's caused by bad Pulley, you're right. And I agree for not rebuild the comprosser, just buy a new one, sence rebuilding will cost aproxmitly same price of new one, and may wont last long with you like the new.
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
