Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Ask a Site Sponsor
Ask a Site Sponsor
Ask a site sponsor a question, request pricing on products or suggest a group buy!
Old 09-29-2009, 05:50 PM   #1
TrippinBimmer
My Ride: Just Fast!
Cooling System Overhaul 330i System Package
I am looking to Overhaul my cooling System. I know, I will be removing my Mechanical Fan and not reinstalling it. I am going with a Stewart Water Pump to help offset this. The Lower and Upper Hoses will be replace with Silicone Hose that is under works... I have a 330i Auto ZHP. I know, I am missing something else...
OEM Parts:
Thermostat w/ housing/gasket (11537509227)
Expansion Tank (17117573781)
Radiator Cap (17111742231)
Engine drain plug crush ring (07119963200)
Lower hose temp sensor (13621433077)
1 gallon BMW antifreeze (82141467704)
Accessory Belt (11281706545)
A/C Belt (11287512762)
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-29-2009, 07:53 PM   #2
Many330i
My Ride: e90 M3
Tensioners! I replaced both of them when I did mine.
Gallon of distilled water...
Many330i is offline   Reply With Quote
Old 09-29-2009, 10:35 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Told you on aim
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-30-2009, 05:18 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
OEM Parts:
-TrippinBimmer
Sounds like you have most of it listed there... I only see a few things that I would consider doing while I'm in there...
* Water pump - Check
* Water pump pulley - Suggest changing
* Fan switch - Suggest changing
* Thermostat & housing - Check
* Sealing gaskets - Suggest changing
* Expansion tank & cap - Check
* 1 Gallon Coolant - Check
* Upper & lower radiator hoses - Check
* Accessory drive belts - Check
* Radiator drain plug - Check
* Coolant level sensor - Check
* Level sensor clip - Suggest changing
I did my entire cooling system (including radiator) a while ago prior to working here, and the piece of mind if gave me was well worth the work and costs.
Hope everything goes well for ya! Let me know if I can be of any help! Great looking car btw, love the wheels and trunk. They really complete the look!
Old 09-30-2009, 05:41 PM   #5
TrippinBimmer
My Ride: Just Fast!
Why Change Pulley?
Alpine White M3
MaximumPSI Stage4
Old 09-30-2009, 07:11 PM   #6
Many330i
My Ride: e90 M3
Why Change Pulley?
They make an unbearable noise, at least one of mine did! They are not expensive, just change them while you are at it!
Old 09-30-2009, 07:48 PM   #7
TrippinBimmer
My Ride: Just Fast!
Idler Pulley is Understandable but not Water Pump Pulley...Which I already have.
Alpine White M3
MaximumPSI Stage4
Old 10-01-2009, 08:20 AM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Why Change Pulley?
I recommend changing them because are prone to cracking at higher milage, and you already will have taken the old one off.
So while your in there taking the old one off why not put a new one on. For me the piece of mind I got for less then $30 was worth it. But no you do not have to.
Hope that helps!
Cheers,
Joe
Old 08-14-2010, 11:54 AM   #9
stapler12345
My Ride: Mineral White F30
How do we check whether we need to change out the Lower hose temp sensor (13621433077)
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-14-2010, 12:07 PM   #10
BimmersGarage
My Ride: E46 330i
The lower auxiliary fan sensor/switch rarely goes faulty... and really doesn't need to be changed. Unless, it's been physically yanked or damaged some how.
BUT, it's mainly for the tiny green O-ring around it that goes bad, which can cause a leak that's hard to diagnose later. See image below -
So, it's worth the few dollars to have it replaced, if you are changing out the lower rad. hose anyways.
BimmersGarage is offline   Reply With Quote
Old 08-31-2010, 05:32 PM   #11
beauch3
My Ride: BMW 325
I did the cooling system upgrade. I can't get rid of the low coolant light. Car runs fine. Doesn't overheat. I have driven it 5,000 miles. I just put in a new sensor and the light still won't go out. Anyone have any ideas?
beauch3 is offline   Reply With Quote
Old 09-01-2010, 12:37 AM   #12
BimmersGarage
My Ride: E46 330i
That is odd.
Old 09-06-2010, 06:41 AM   #13
TrippinBimmer
My Ride: Just Fast!
Did you reused your old sensor or order a New one? You can't used the old one from other Expansion Tank. Due to the Black Tube is missing from the Sensor.
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
