Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.80 average.
Old 03-22-2010, 08:36 PM   #401
stealth09
My Ride: 330Ci
Originally Posted by w0w View Post
ah u live in alberta, good luck finding spacers locally theres a ton of places u can order spacers from, i can find a number of places if u need that info. and i dont think ur tires are the culprit, i just think its the conservative oem wheel offset
Yea I have some coming in from ECS Auto, but they are still on order.
I noticed my spare tire had a width of 225, and it fit and cleared the coilovers with the 7mm spacers I have.
stealth09 is offline   Reply With Quote
Old 03-25-2010, 06:23 PM   #402
Citystars403
My Ride: 00 328Ci
Originally Posted by stealth09 View Post
Maybe if billet adapters were that easy to find, without having to order them in! And maybe if it didn't take so long for sponsors to get spacers in, my problem would be solved.
I already came to the conclusion that it is rubbing on the spring you idiot, that is why I can't drive my car. Obviously this guy installed his without spacers, and I want to know his setup...
CityStars what size tires do you have?
225's all the way around which leads to them being kinda sorta stretched in the rear.
Citystars403 is offline   Reply With Quote
Old 03-25-2010, 07:02 PM   #403
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Im going to buy a set. I've heard that 7 inch endlinks are perfect. Do i need to adjust them everytime I want to raise and lower the car? If not then Can I just get a regular set of non adjustable 7 inch endlinks? And do you guys have any other installation tips for a suspension newb like me?
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 03-25-2010, 07:56 PM   #404
TX_Bullet
My Ride: 2001 325Xi
As for the install your def. going to need a spring compressor, everything else is pretty easy.
Im also making my own adjustable end links for the front, I already have everything I need like the dies and taps. Just need a hour of time after work on the good ol' mill
Another note to a newb installer. When you set your adjustments:
I put the rear all the way down and as for the front.......I measured 1 1/2 from the top of the end link mount(on the strut) to the top of the top adjustment nut. Any thing lower you may bite a fender
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 03-25-2010, 08:03 PM   #405
RockLee
^Thanks, I want to make sure how low I can go without rubbing. I have a sedan with the sports package and the style 44 rims. Can any sedan owners tell me what to do also? And when if I need to change the height, is it easy to do? Can I do it in my driveway?
Old 03-25-2010, 09:17 PM   #406
TX_Bullet
My Ride: 2001 325Xi
I dont think you will be really adjusting the rear, but as for the front you just pop the tire off and get the spanner wrenches out(that come with the setup)
The Mods
Power Flex FCAB
Old 03-26-2010, 09:11 AM   #407
RockLee
I heared that if you adjust the ride height, you need to align the car again. Is this true?
Old 03-26-2010, 03:22 PM   #408
Simple SOHC
My Ride: 01' 330ci SGM / IR
Any time you adjust the car height...you should get an alignment.
-Nick-
"Simplicity in design while optimizing and achieving one's maximum potential."
Simple SOHC is offline   Reply With Quote
Old 03-26-2010, 06:38 PM   #409
zugellos
My Ride: '02 330i
Don't know if it's different between coupes and sedans...but I didn't need to use any spring compressor, for the rears I just used my car's jack.
However...you'll need to temporarily remove a small bolt that holds the brake line to the swing arm. This will allow the additional movement needed to free the rear springs.
zugellos is offline   Reply With Quote
Old 03-26-2010, 11:45 PM   #410
trippmann
My Ride: E30
Send a message via AIM to trippmann
for the rear springs "this is on a 2000 323i sedan" just use your foot and push down on the loser spring perch/rotor, this is if you wana do it dirty like i did. otherwise get a large prybar and bend it down. same concept in both methods but i found the foot method was much faster.
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 03-29-2010, 01:55 PM   #411
stealth09
My Ride: 330Ci
Well I guess I was an idiot. I didn't notice that the OEM wheels were staggered and that was the reason the coilover was rubbing on the wheel (Rear wheels up front). So it fits all good now with no spacers.
And to remove the rear spring like stated before. Just wedge in your factory car jack, and jack it until you have enough room to take out the rear spring. No spring compressor required. If you do it using the foot method, you can get your fingers caught in there if for some reason you don't have enough pressure pressing down on the rear assembly.
Old 03-30-2010, 11:51 AM   #412
lafabritto325ci
My Ride: 2008 E90 335i
After you guys install the coils..... how long do u wait to get an alignment ????
lafabritto325ci is offline   Reply With Quote
Old 03-30-2010, 12:50 PM   #413
TheRusski
My Ride: gone...
Let the coils settle a bit and thn get an alignment..so prolly 2 weeks
TheRusski is offline   Reply With Quote
Old 03-30-2010, 05:11 PM   #414
stealth09
My Ride: 330Ci
I installed these coilovers slammed, and it rides not too bad. Only driven it a few kms. Going to raise it up to the proper height I want and then let them settle.
Old 04-02-2010, 01:47 AM   #415
jenewein
My Ride: 323i
Okay I've got a question. I'm ready to pull the trigger on these but I want to see if I'll need spacers before. I'm running 225 all around on 8.5 width wheels. ET is 38.
jenewein is offline   Reply With Quote
Old 04-02-2010, 04:48 AM   #416
Kringkily
My Ride: e46 m3 convertible
hope racelands make coils for an m3
Kringkily is offline   Reply With Quote
Old 04-02-2010, 08:51 AM   #417
lafabritto325ci
I will be installing mine today.... pics will come later
Old 04-05-2010, 08:23 PM   #418
jenewein
My Ride: 323i
Bump, can anyone tell me if I can get away with et38 8.5" with 225 tires? I just wanna know if I should buy spacers in advance.
Old 04-05-2010, 10:48 PM   #419
lafabritto325ci
http://forum.e46fanatics.com/showthr...ight=racelands
review plus pics
Old 04-06-2010, 09:36 PM   #420
dogdaysunrise
My Ride: Sechsundvierzig
^^^ What wheelsize are those?
THX!
Now, do I understand this right......$250 for the ENTIRE kit of coilovers.....for one car!?
Is this true?
I mean I just can't believe this is true......My shop quoted me around $700 for my sport replacement, I know I can get the H&R Cup Kit for around $700.....so if the Racelands are $250, that's nuts! Ok...+100 for adjustable links but that's still killer.
Leaves me money for 19s or 20s if I wanna go slammed.....
love is the absence of fear
dogdaysunrise is offline   Reply With Quote
coilovers, ebay, raceland, review
Rate This Thread
