Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.80 average.
Old 07-08-2011, 07:47 PM   #1041
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
when you install the rokkors, dont take anything out. install everything because trust me, this coilovers kit goes LOW and im not kidding when I say that. Keep all the helper coils and rear pads, trust me. If you want to go lower, then take it out, but I seriously doubt you will want to go that low because it will look ugly. And your probably going to need the spacers. Dont quote me on the spacer advice, i'd suggest buying the spacers from a local shop just in case, if not, just return them. I know the offset is really high on the zhp wheels so im almost positive you'll need em. You can also ask someone that has this setup on zhp wheels.
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 07-11-2011, 01:37 PM   #1042
tegboi
My Ride: 323i
170k on car, had the rokkor coilovers on for approx 6k. Between a high ride, to a slammed (rears bottomed, and front having 5 threads remaining on the coil sleeve) I recently raised the car back up an inch from the lowest point I've ever had it in.
Recently, I started hearing and feeling some type of wheel bearing type of sound from the front left. Will be taking the wheel off and inspecting everything today.
Can be between a wheel bearing/bushings/top hat/ or the suspension itself.
I'll report back if there's anything wrong with the rokkors
teamULTRASPEED
tegboi is offline   Reply With Quote
Old 07-14-2011, 02:47 PM   #1043
tegboi
My Ride: 323i
The plastic dust guards were chewed up, and looks like the spacer between the helper spring & main spring was rubbing against the threaded area of the shock.
Swapping front wheels around the vibration went away. Think it's possibly my tires which were causing it from riding low for a week, then raising it up..
teamULTRASPEED
Old 08-09-2011, 09:15 AM   #1044
IrocThe325i
My Ride: is turning japanese
Does anybody have pics of there car on roks or RLs at FULL HEIGHT...
i dont like slammed i just want a stiffer suspension that i can make the exact stance i want.
Anyone riding at full height?
IrocThe325i is offline   Reply With Quote
Old 08-09-2011, 10:43 AM   #1045
DSeyf
My Ride: b6s4
Disagree. Take the helper spring out.
Sent from my Desire HD
DSeyf is offline   Reply With Quote
Old 08-09-2011, 12:16 PM   #1046
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
What's funny is the OP of this thread has long been on a High Quality GROUND CONTROL SUSPENSION.
That should tell you something.
"If you want steak,......then don't go to McDonald's."
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 08-09-2011, 01:20 PM   #1047
Jkim
My Ride: needs work...
Not FULL height but up there
Sent from my HTC Glacier using Bimmer
Jkim is offline   Reply With Quote
Old 08-29-2011, 09:44 PM   #1048
xialguire
My Ride: 2001 330xi
Do they sell a coil over for a 330xi 2001 im looking at geting them
xialguire is offline   Reply With Quote
Old 09-01-2011, 12:13 PM   #1049
choleaoum
Ceiling missing!
choleaoum's Avatar
My Ride: BMW 330Ci
Send a message via AIM to choleaoum
I vouch for racelands, just installed some yesterday for a customer. They feel real good for the price tag. Seriously, the rear can get a bit bouncy and the spring rates could be stiffer. Migs Motorsports might be able to help with getting stiffer spring rates. Better then ground controls on stock shocks thats for sure lol.
choleaoum is offline   Reply With Quote
Old 09-01-2011, 03:37 PM   #1050
Rob43
Rob43's Avatar
I guess I just don't get it.
Who in the HELL would want to spend $500 plus dollars to get a new suspension installed, and then drive down the road with a "Bouncy Rear". I wouldn't want to drive through a medium or high speed turn knowing that the rear end is not fully planted.
But then, that's just me.
Old 09-01-2011, 05:24 PM   #1051
Confisk8d131
My Ride: 2004 330i ZHP
Check in here.... 30K on my racelands, and I'm still really happy with the set. 3 Track days and they feel VERY solid. Only long term recommendation is to get stiffer spring rates in the rear, only if you track the car.
2004 330i Silver Met. 6 Speed ZHP
Full Race Suspension // RL Coilover's // UUC Sways // UUC 6speed shifter // VR Endlinks // Umnitza Orion's V2 //
FXR Retrofit // Chris Brown Mod // ACS Strut Brace // Smoked Corners // iPod Interface // HID Fogs //
Confisk8d131 is offline   Reply With Quote
Old 10-02-2011, 06:13 PM   #1052
///Mostarac
had mine on for about 10 months. no problem. I swapped out the rear shocks for koni adjustables. next im swapping out the rear springs! too bouncy for my aggressive offset
-Benny
Old 10-02-2011, 06:21 PM   #1053
DSeyf
My Ride: b6s4
Order me a set while your at it.
Old 10-02-2011, 06:34 PM   #1054
///Mostarac
lookin to get some 600+ lbs springs that will fit the RL adjuster
-Benny
Old 10-02-2011, 09:54 PM   #1055
DSeyf
My Ride: b6s4
You don't need an adjuster...
Old 10-03-2011, 08:24 AM   #1056
///Mostarac
why? Do they sell them with adjusters already?
-Benny
Old 10-03-2011, 05:24 PM   #1057
RuffRyder32
My Ride: 32.5speed
I have read the 50 earlier pages in the past and know im going to need new endlinks and such but can someone please sum it all up for me?
Looking to buy these sometime soon but what will i need to have a safe, low ride(kinda doesnt go together haha) i just dont want to be unsatisfied after purchasing rokkors or racelands
Thanks!
RuffRyder32 is offline   Reply With Quote
Old 10-03-2011, 05:34 PM   #1058
DSeyf
My Ride: b6s4
No, but they should be all thr way down.
Old 10-03-2011, 06:09 PM   #1059
Rob43
Rob43's Avatar
Thanks!
Then I guess you'll be purchasing a better quality suspension.
http://forum.e46fanatics.com/showpos...&postcount=936
Old 10-03-2011, 07:22 PM   #1060
///Mostarac
lol
-Benny
coilovers, ebay, raceland, review
Rate This Thread
