Old 10-05-2009, 12:46 PM   #1
JeppeJ
My Ride: E46 M3 SMG SEDAN
Subframe reinforcement epoxy/foam method.
Here I will show you how I did the subframe reinforcement using epoxy glue to mount the turner subframe reinforcement plates. And then reinforcing the subframe using the BMW foam method. The good thing about this method is that you can do everything yourself and you don't need to weld your chassis which can cause rust problems later.
In the BMW TIS they only inject structuring foam on the left side. I did the right as well just to be on the safe side.
What you need:
Turner subframe reinforcement plates
3M Epoxy Glue 08115 x1
BMW TIS download here: e46_subframe_tis.pdf
Cavity foam 83 42 9 410 694 x1
Structuring foam 83 42 0 307 530 (x2 if you want to reinforce the right side as well)
Thinner or similar for cleaning the surface
Applicator gun. One for the Epoxy and one for the foam. I made my own.
The applicator guns are really expensive and you need two. So I made my own from a regular applicator gun. This can be used with both the epoxy and the foam cartridges. But you can probably borrow the guns from a body shop.
Here I have sanded the plates down using a angle grinder with sanding plate.
Subframe sanded down.
Test fitting the plates.
Apply the epoxy using this type of tool.
Epoxy applied on the car.
And on the plates.
Mount the plates and lightly tighten the bolts. Don't tighten to hard cause you will squeeze out all the epoxy. I think the epoxy needs a layer of 0.5mm-1mm thick layer of epoxy to get max strenght. You should see some epoxy squeezing out evenly around the edge of the plate. Make sure you don't block the small drainage holes with epoxy.
Use your hands with rubber gloves to spread out the epoxy around the edge of the plate. This is how it should look.
Then let it dry for 24hours +. I let it dry for 48hours before I painted the plates with rust protective paint. Finished!
Then it's time for the foam. It's good to have a print of the BMW TIS when doing this.
First drill a hole in the middle between the holes that are alredy there. You can see that I have made cuts in the floor, this is not necessary when doing the foam method. I was going to do the welding, thats why its cut.
Here you can see the hole hiding underneath.
Then remove the sound deadening to find this hole.
If you plan on doing the right side as well you don't need to look for this hole on the right side. It isn't there, I have looked..
Then fill the two holes with cavity foam as explained in the BMW TIS. Make sure you empty out the rest of the can somewhere or else it will explode!
Preheat the structuring foam to about 60C in a water bath.
Wait 10min then inject the structuring foam as explained in the BMW TIS.
After injecting two cartridges of structuring foam into this hole. The foam expands a lot and fills up your subframe. Some foam will protrude out of this hole and the small drainage holes under the car. Inject two cartridges into the right hole also if you want to reinforce that side as well like I did.
Let it dry for 24hours. Car must not be moved during the hardening period.
Good luck!
JeppeJ is offline   Reply With Quote
Old 10-05-2009, 05:59 PM   #2
oh2fly
My Ride: 2004 M3
Thanks, I've been looking forward to this DIY! There's a great debate about the efficacy of this approach going on over here: http://www.m3forum.net/m3forum/showthread.php?t=280165
oh2fly is offline   Reply With Quote
Old 10-05-2009, 06:07 PM   #3
neil1138
win
neil1138 is offline   Reply With Quote
Old 10-05-2009, 07:50 PM   #4
Hit_Apex
My Ride: 2006 M3 ZCP
Awesome contribution to the community. Thanks for sharing.
2006 SG ZCP M3 6MT TCKline/Ground Control-SS Stepped-Crackpipe-Borla-4.10
2008 AW E90 335i 6MT Quaife-3.46-PSS10-Code3IC-RissDP-BBSCH-245/275 RE01R-JB3 2.0B
Hit_Apex is offline   Reply With Quote
Old 10-06-2009, 02:04 AM   #5
chriskuta
My Ride: M3
Cheers JeppeJ - I'm interested in the foam injection part at this stage. Thanks for sharing! Once filled and set this will be pretty hard I reckon and should help reduce and even stop further stress.
chriskuta is offline   Reply With Quote
Old 10-06-2009, 07:11 AM   #6
Focal E46
My Ride: is a DIYer
Great thread. But I would recommend checking to see if your subframe is already cracked before buying that stuff because you might have to end up welding anyway
Focal E46 is offline   Reply With Quote
Old 10-06-2009, 07:24 AM   #7
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Was it really necessary to use the Turner plates, too?
Thanks for the write-up. Where did you get the foam? I searched the PN a few places but couldn't find a place to buy it. Did you just go to a dealership?
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 10-06-2009, 07:41 AM   #8
Focal E46
My Ride: is a DIYer
That would save sooooooooooooooooo much time.
Old 10-06-2009, 08:20 AM   #9
Hartman
My Ride: 2000 323i
AWESOME alternative. Now we just need to find a good way to apply the foam without purchasing the ridiculously expensive gun.
Hartman is offline   Reply With Quote
Old 10-06-2009, 09:01 AM   #10
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
Very nice write up.
zhp pilot is offline   Reply With Quote
Old 10-06-2009, 09:12 AM   #11
djnekkon
My Ride: MB3ci Regensburg Bav
THis....But Def something I will do next. Cheap and easy. Thanks
Old 10-06-2009, 10:20 AM   #12
JeppeJ
Thanks, hope it helps.
When dry the foam feels like very hard plastic. It will expand inside the subframe and make the area around the bolts rock hard. Preventing the bolts from moving and tearing apart the top mounts and the subframe. At least thats the theory.
Good point.
You probably don't need the plates if your subframe is ok. But my car will see a lot of hard track driving so I did it just to be sure.
Any BMW parts store should be able to order it for you, mine did. It's BMW part numbers. Otherwise try your dealer.
This is a problem. Maybe it does exist somewhere but I didn't find anything online or at the shops we have here where I live. Maybe I should start mass production of the gun I made...
Old 10-06-2009, 10:52 AM   #13
nite-stalker
My Ride: 325Ci
3M 08571 applicator gun
http://www.autobodytoolmart.com/3m-m...1-p-15298.aspx
nite-stalker is offline   Reply With Quote
Old 10-06-2009, 11:17 AM   #14
aggieE46
Keep it clean
aggieE46's Avatar
Thanks again. I'll definitely be doing this ASAP.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 10-06-2009, 12:38 PM   #15
n2Bimmer
My Ride: Loves Corners
So if you have a torn subframe you just use the epoxy and sandwhitch the plates on to the ripped sheet metal. Dont get it.
Old 10-06-2009, 12:48 PM   #16
Focal E46
My Ride: is a DIYer
I doubt it. I think this is more of a preventitive measure.
Old 10-06-2009, 01:11 PM   #17
aggieE46
Keep it clean
aggieE46's Avatar
Yep, this is preventative.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 10-06-2009, 01:15 PM   #18
n2Bimmer
oh, okay. but damn its alot of work
Old 10-06-2009, 01:20 PM   #19
aggieE46
Keep it clean
aggieE46's Avatar
I'll quote you on that when your subframe tears and you're having to pay to have it fixed and THEN have the kit welded in
It's not that bad. Might as well redo all your rear suspension and subframe bushings while it's out. Much easier than while it's in the car.
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 10-06-2009, 06:41 PM   #20
chriskuta
My Ride: M3
So you didn't get access to the front right area?
When you say two cartridges you mean one lot of Structuring foam 83 42 0 307 530, not two lots?
Question, where you cut into the frame on each side, how come the foam didn't piss out from these openings.. or does the foam go into a deeper channel?
