Old 10-08-2009, 06:16 AM   #21
chriskuta
My Ride: M3
I read the TIS and answered my questions thanks It seems from the TIS that the cavity foam is only there to seal the channel at each end for the structural foam.
chriskuta is offline   Reply With Quote
Old 10-08-2009, 07:30 AM   #22
Matt Q
My Ride: Jezebel
thanks for the cool pics and the informative post
M3. ONLY BETTER
Matt Q is offline   Reply With Quote
Old 10-08-2009, 03:26 PM   #23
JeppeJ
My Ride: E46 M3 SMG SEDAN
That's right
JeppeJ is offline   Reply With Quote
Old 10-10-2009, 08:27 PM   #24
dub325i
My Ride: 2001 LSB M3
Awesome!
Another alternative when using the TMS kit would be to DIY the epoxy reinforcements on the bottom, and then take your car to a pro to weld up the inside of the trunk. I'm extremely mechanical and have no issue with the mechanics of things, but I've never welded in my life. Then no need to fuss over the foam and tools needed for that.
dub325i is offline   Reply With Quote
Old 11-20-2009, 11:09 AM   #25
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
Or you could buy the plates pull your subframe and have a mobile welder do the welding for you.
I don't care how strong your epoxy is. Something that can rip the metal frame sure as hell can shift those plates and probably make them useless
bimmer07 is offline   Reply With Quote
Old 11-25-2011, 09:39 PM   #26
SweTurbo
Banned User
My Ride: 323i -98
Bump for great thread , so if you're doing both then i guess there would be no need to inject foam into hole #2 ?
Old 02-24-2012, 11:56 PM   #27
macming
My Ride: 05 Mystic Blue ZCP
Sorry to bump an old thread, but what is the difference b/t cavity foam and structural foam?
macming is offline   Reply With Quote
Old 02-26-2012, 05:19 AM   #28
chriskuta
My Ride: M3
Cavity foam is a light filler normally used for acoustic dampening. Structural foam is a two part high strength rigid filler designed to fill and expand to reinforce.
In the case on the subframe the cavity foam is just used to plug each end of the small chambers where the subframe mounts are welded in. So when you inject the structural foam it fills and expands in the area that requires strengthening.
Old 03-21-2012, 05:02 PM   #29
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Another bump...
Anyone in the US buy the cavity foam and structural foam? My normal parts places can't get it. Tischer said they aren't able to get it, either. They said BMW doesn't want to sell it unless you're having the work done.
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 03-21-2012, 06:14 PM   #30
Nervous
My Ride: 01 330CI 6MT ZSP EU3
You can find much more info here:
http://www.m3forum.net/m3forum/showthread.php?t=287849
http://www.m3forum.net/m3forum/showthread.php?t=251279
http://www.m3forum.net/m3forum/showthread.php?t=152000
The possible replacements for those foams are also discussed in these topics. BTW, try to ask Mike from www.thebmwpartstore.com, maybe he can get it for you. Also may try www.bmwmercedesparts.com. Let me know what you find, as I am planning to do this as well.
Nervous is offline   Reply With Quote
Old 03-21-2012, 06:22 PM   #31
Nervous
BTW, www.thebmwpartstore.com has the structural foam, p/n 83-19-0-445-721 listed for $152, and www.bmwmercedesparts.com for $129. Contact both and ask if it is true or not (since it still might be not available).
Added: http://ebmwparts.com has it for $127.
Old 03-24-2012, 02:01 PM   #32
Crack_Fox
My Ride: BMW 325i M Sport
Just to let you know that Audi sell the 2 part epoxy foam for about half the price of the BMW dealers (in the UK anyway!)
Audi use the same stuff for the RS4 battery tray in the spare wheel well which is known for cracking. BMW quoted me £170 for the stuff but Audi is £95 So essentially you can repair both sides for half price.
The part number of the Audi branded stuff is D 506 110 A3
Crack_Fox is offline   Reply With Quote
Old 02-13-2013, 01:59 PM   #33
KrasivataSabine
My Ride: 323Ci
Thread bump for good info
So if I'm not mistaken, the TMS plates are placed between the subframe and the differential carrier to distribute the load, yeah? The diff MUST be taken out to have the kit installed?
KrasivataSabine is offline   Reply With Quote
