Old 10-05-2009, 04:41 PM   #1
Defjam
My Ride: 2004 M3
17x9 or 18x9 for track?
Hi all,
I'm starting to setup my old BMW for not only daily use but track use 6-8 times / year. I'm starting out by replacing the suspension with AST 4100 and new tires / wheels.
I've been looking at D-Force either in 17x9 or the 18x9 sizes. Any advice / experiences with these? What tires would you recommend for good track performance and decent real world use?
-Def
Defjam is offline   Reply With Quote
Old 10-05-2009, 05:13 PM   #2
n2Bimmer
My Ride: Loves Corners
Whatever is cheaper. Also if you dont plan on using a HUGE BBK then the 17's will do just fine.
Old 10-05-2009, 05:39 PM   #3
mrshelley
My Ride: 2004 330i
I'd stick with 17X9. There are plenty of used Hoosier tires out there that work great on a 17X9. They are 225/45/17. I sell my used ones for $100/set and they last most BMW club racers for a few weekends. I know of at least one Koni team that has those tires stacked to the ceiling.
Old 10-05-2009, 05:46 PM   #4
murph1379
My Ride: 2006 M3
why would you put 225's on an E46? Way under-tired.
Go 17x9 and 255/17's. Unless you're competing, the extra cost of 18x9's to fit 265's isn't worth it.
murph1379 is offline   Reply With Quote
Old 10-05-2009, 05:56 PM   #5
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Just currious, what qualifies you to disagree with Mr.Shelley's recommendations?
Please take that as just a question.
Old 10-05-2009, 06:26 PM   #6
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
Those are the same people who install 19 inch wheel thinking they're gonna gain performance.
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
Old 10-05-2009, 06:31 PM   #7
murph1379
My Ride: 2006 M3
Actually, my question was stupid because I know the answer, they run 225's because they're rules-limited.
The E46 is heavy, and needs more tire than that, especially if not stripped. 245's at a minimum. I'd run 285's on the track if I could fit them. I run 265's for autocross because that's the largest I'm allowed by rules. (which is good, because fitting much more would be a stretch)
I used a set of 255 star specs for a track weekend earlier this year and they were brilliant. When I let my instructor drive, he said they felt like his R-Comps. 255's will fit all around even without careful spacing or lots of camber.
Also 225's won't take full advantage of a 9" wheel. 245-255 will fit perfectly, 265 being a hair wide for 9". I know some of the track guys like to put a skinny tire on a huge wheel, but that's usually (AFAIK) because they're limited by rules on tire width, and a wider wheel will still help for a skinnier tire.
Old 10-05-2009, 06:42 PM   #8
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
+1 for 17x9 with 255/40-17 tires if it is a dedicated set of track wheels. Go with 18x9 with 255/35-18 though if they are going to be used mixed street/track since you'll probably want a slightly larger wheel for aesthetic reasons. 17" is perfect for performance though.
SpeedDemon is offline   Reply With Quote
Old 10-05-2009, 07:16 PM   #9
n2Bimmer
Im going to try my 255's on the front, no spacer, 1.2 neg camber. See what happens.
Old 10-05-2009, 07:52 PM   #10
vaio76109
My Ride: Race Cars
For DE use go with 17x9s because they're cheaper initially and 17" tires are cheaper.
vaio76109 is offline   Reply With Quote
Old 10-05-2009, 11:24 PM   #11
SpeedDemon
-1.2 camber... why not more?
Old 10-05-2009, 11:48 PM   #12
paintpro21
My Ride: e30 M3 , e34 540i/6
Both sizes are good. It just depends on your budget, or if you had breaks you needed to clear. 17x9" with a square 255/40/17 setup would work great. You wouldn't have to roll fenders, and spacers wouldn't even be needed up front unless you ran r-compounds.
Here's a 255/40/17 on 17x9's all the way around on a lowered car with no other mods for reference (no camber plates or anything else done to it besides springs). If you wanted to be a little more conservative you could go with 245's all the way around. that is an ultra easy setup, and would probably make for a lightly more convenient daily driver tire size. Although I don't think I could really defend that arguement if the 255's fit without issue.
paintpro21 is offline   Reply With Quote
Old 10-05-2009, 11:51 PM   #13
paintpro21
It's going to work no problem. You and I talked about this already
Old 10-06-2009, 10:33 AM   #14
n2Bimmer
1.2 is for Daily use. Track use is above 2.5. Currently im working on getting more neg camber.
Old 10-06-2009, 10:41 AM   #15
SpeedDemon
All you have to do is sacrifice caster
Old 10-06-2009, 12:25 PM   #16
n2Bimmer
yup and maybe the mason bar
Old 10-06-2009, 01:57 PM   #17
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I'm running 255s up front with no spacer, no problem.
Old 10-06-2009, 03:02 PM   #18
vaio76109
My Ride: Race Cars
Why would that effect caster?
Old 10-06-2009, 03:30 PM   #19
n2Bimmer
Well you have coupe, its a little harder on a sedan
Old 10-06-2009, 03:31 PM   #20
n2Bimmer
Not the castor but camber, Since the Mason race bar is one piece i dont have any room to move the camber plate studs to gain more neg camber.
