Thread Tools Search this Thread Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 10-07-2009, 12:14 PM   #1
Attacking Mid
My Ride: 99 328i MT, 08 X3
Leaking Coolant Temp Sensor?
Apparently the coolant temp sensor must be replaced (about 30 bones) whenever you replace the lower radiator hose. I didn't realize this until I had a leak following a complete cooling system overhaul. For some reason, the o-ring must shrink, as it is a very loose fit in the new lower hose fitting.
By luck, I had a package of cheap o-rings in the garage which were slightly oversize compared to the old one. I changed the o-ring out and end of leak. I can't say if this o-ring will last forever, but if it does fail, it's a pretty simple fix down the road.
Anyway, if you want to save the 30 bones, here's the details:
"Brasscraft" brand o-ring twin pack from Home Depot or Lowes (not sure)
Package number 0567
Dimensions: 5/16" I.D. (9/16" O.D.) x 1/8" Wall
This o-ring is a snug fit, so it takes a good push to get the sensor seated in the hose fitting.
AM.
Attacking Mid is offline   Reply With Quote
Old 10-07-2009, 12:29 PM   #2
Safar
My Ride: comes with blow
Yeah, good tip. I replaced everything except for the damn sensor, so I also found this out the hard way (and I didn't have spare o-rings sitting about)...
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 10-21-2009, 10:45 PM   #3
JSanders
My Ride: Breaks too often
Interesting, I wonder if this is where my coolant has been going. How fast was your coolant leaking out?
JSanders is offline   Reply With Quote
Old 10-22-2009, 02:05 AM   #4
Safar
In my case, fast enough that coolant levels would be too low after a couple of days...
But you can easily check; feel around the sensor location to see whether it's wet or not.
Vehicle history
1987 Suzuki VS1400
Old 10-22-2009, 02:39 AM   #5
JSanders
I am going to, just trying to get a little background info to see how similar the situation is
Old 10-22-2009, 12:05 PM   #6
nathancarter
My Ride: 02 330i
I did the same thing - used one from a pack of assorted O-rings that I had in the garage. Ideally, you should use a brown or green O-ring, as those will withstand the harsh environment better. but, I used a black one almost 50k miles ago, and haven't had a leak since.
Green = old hardened O-ring = leaks in new hose.
Black = new soft rubbery O-ring = no leaks.
nathancarter is offline   Reply With Quote
Old 10-29-2009, 02:44 PM   #7
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
I am glad someone started this thread.
The problem has always been finding the right o-ring for the coolant temp sensor and most folks ended up buying a new sensor.
Actually there is a BMW pn: 13.62.1.743.299
It's the same o-ring used for IAT sensor on the older E46 models.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 10-29-2009, 09:30 PM   #8
jeffb325
My Ride: 325ci
you can also try flipping the oring around backwards....it gets a flat spot on it from how it is installed and turning in around puts a
'fresh" part of the oring up against the seal area. Worked on my car.
jeffb325 is offline   Reply With Quote
Old 10-31-2009, 05:32 PM   #9
phade2
My Ride: 325i Sedan
good stuff guys...i just found the leak from my sensor this afternoon and logged on to see if anyone else had the same issue...bingo! thanks!
phade2 is offline   Reply With Quote
Old 11-02-2009, 09:02 AM   #10
agb1976
My Ride: 325i
I just replaced the hoses, thermostat, and expansion tank hoping not to need a new temp sensor. It leaked pretty good at the sensor. Tried different o-rings till it stopped leaking. So far so good. Saved a few bucks but drove myself crazy trying to stop the leak.
agb1976 is offline   Reply With Quote
Old 11-02-2009, 09:27 AM   #11
Chriztofor
My Ride: 2000 323i (Auto)
Excellent thread, subscribed. I love seeing threads that have solutions and not just complaints.
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
Chriztofor is offline   Reply With Quote
Old 08-27-2010, 08:37 PM   #12
stapler12345
My Ride: Mineral White F30
is that the sensor? i just replaced the lower radiator hose too.
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-27-2010, 09:18 PM   #13
Sansho
My Ride: 2001 325i
The sensor is in the lower radiator hose about a 8 to 10" from the radiator, on the left side bottom as you face the front of the car.
Sansho is offline   Reply With Quote
Old 12-02-2011, 11:59 PM   #14
shobbs
My Ride: 2000 328i
replacing coolant temperature sensor
I am trying to replace the coolant temperature sensor in my 2000 328i which is located in the lower radiator hose. As many other posts have stated, mine is leaking. However, when I went to do the "easy" swap, the old sensor won't come out. I pinched the 2 little levers on the side to release it and pulled but it won't budge. Any ideas how to get it loose? Also, does this sensor have any control over the electric fan cooling the ac?
shobbs is offline   Reply With Quote
Old 12-03-2011, 12:13 AM   #15
cvx5832
My Ride: 325Ci, 325Cic, C300
It does indeed just pull straight out. Use gloves so the "ears" don't cut into your fingers and you can tug harder. Rock it back and forth (it will only move a little each way) while pulling it out. Keep at it and the plasticized o-ring will eventually give.
I don't know about the AC thing.
cvx5832 is offline   Reply With Quote
Old 12-03-2011, 12:14 AM   #16
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Try squeezing the two tabs in and then push the sensor down before pulling it out.
Squeeze
Push
Pull
Out!
BMWCaptain is offline   Reply With Quote
Old 12-03-2011, 07:16 AM   #17
Sansho
My Ride: 2001 325i
... Also, does this sensor have any control over the electric fan cooling the ac?
Yes, that's one of the inputs the system uses to determine when to turn the electric fan on.
Old 01-07-2012, 03:21 AM   #18
zaharias
My Ride: M3 E46 6MT 3/2005
Bump!!
Is there another input..??
I mean is that the only temp sensor or is there another also on the engine..?? (that gives info to the fan)
zaharias is offline   Reply With Quote
Old 01-07-2012, 08:27 AM   #19
shanneba
My Ride: 2003 330Ci
Here are the inputs used for the electric fan:
The fan is activated based on the ECM calculation
(sensing ratio) of:
Coolant outlet temperature
Calculated (by the ECM) catalyst temperature
Vehicle speed
Battery voltage
Air Conditioning pressure (calculated by IHKA
and sent via the K-Bus to the ECM)
Page 36 of this document- http://www.bmwmotorsports.org/BMW_docs/m54x5.pdf
There is another coolant temp sensor in the block under the intake manifold (rear) it may be used in the ECM "calculations"
Join BMWCCA
Old 01-07-2012, 10:40 AM   #20
zaharias
(sensing ratio) of:
Vehicle speed
Battery voltage
Thanks for the reply..
That's the reason that i asked if there is another sensor..
Actually, i have a faulty (99%) fan (works all the time, even with A/C off) and i want to disconnect the sensor and see what happens..
And.. iam ready for some preventative maintenace and iam thinking of changing almost all sensors (cam, crankshaft, temp..).
