Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 03-17-2010, 05:31 PM   #21
kensou
My Ride: ///M3 E46 cab
Send a message via MSN to kensou Send a message via Yahoo to kensou
Originally Posted by Buzz Leightyear View Post
I thought the reverse camera neeeded to have a NTSC output, Im sure I read it somewhere on the forums?
you may be right...being that my camera seems to output a NTSC video signal ...
kensou is offline   Reply With Quote
Old 04-18-2010, 04:09 PM   #22
cream
My Ride: 330xi
Doesn't the video module supports both NTSC and PAL standards? I know you can code it with navcoder for example.
Anyway, I'm having the same problem as nah33m. Video module works correctly, it switches to RV camera input when in reverse, but the image is distorted, out of sync. I've tried 2 cheap cameras and two video modules. No winning combination. The cameras were tested before on a TV. What could be the problem? I'm guessing signal incompatibility? Does anybody know the OEM camera signal specs?
cream is offline   Reply With Quote
Old 05-11-2010, 02:59 AM   #23
kensou
After have got a lot of pm messages about the installation i did for the reverse camera, here is a electrical diagram of the relay to be installed to display the reverse camera video on the nav screen when reverse shift is engaged, hope that's clear.
ps : i'm sorry, i promised a DIY but i forgot, and now all is already mounted. cannot take photos anymore ^^ but someone needs help, post a reply there, and I or someone else would be pleased to reply.
Old 05-11-2010, 07:45 AM   #24
DBS06MSBm3
My Ride: 2006 BMW M3
i have an oem backup camera if anyone is interested,never installed.
DBS06MSBm3 is offline   Reply With Quote
Old 05-29-2010, 12:31 AM   #25
zbi701
My Ride: E46 318i
I'm having the same problem. Anyone know the solution? At the moment I'm using the AV input pins 6 and 15. Image flickers if I use proper Reverse Cam AV input on pin 13 and 14.
zbi701 is offline   Reply With Quote
Old 06-25-2010, 05:12 AM   #26
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
BRo I need a DIY. can you post the wiring diagram again please?
What about this...........
http://www.mobilecentre.co.uk/av-rev...1676c895a57021
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 06-25-2010, 10:20 AM   #27
zbi701
My Ride: E46 318i
Make sure you buy NTSC camera. The video module input only accept NTSC signal (dedicated for Reverse Camera). The other AV input is for video which can be configured for PAL/NTSC or SECAM.
Link to DIY: http://www.bimmerboard.com/forums/posts/122321
Old 06-25-2010, 12:11 PM   #28
0-60motorsports
My car is Euro Spec (PAL). The US models need NTSC or do the Euro model need NTSC too?
Old 06-26-2010, 10:38 AM   #29
zbi701
My Ride: E46 318i
My car is a EURO spec as well but it require NTSC reverse camera. First I bought PAL camera it didnt work - image flikers but when I changed it to NTSC type, it works perfectly. Please read the 8th or 9th post before this to confirm.
Old 06-26-2010, 03:23 PM   #30
0-60motorsports
Ok I will try it with my pal Camera and report back! As i already have a PAL camera i dont mind trying it out.
Old 06-29-2010, 07:15 PM   #31
zbi701
My Ride: E46 318i
Did it work?
Old 06-30-2010, 01:07 AM   #32
0-60motorsports
I will try it ASAP but it wont be very soon as my car is going in for TMS subframe kit and some nice maintenance so i'll be busy doing that
Old 09-27-2010, 03:09 AM   #33
aznbeayst
My Ride: TiAg M3 Vert
Send a message via AIM to aznbeayst
if the dynavin unit supports both pal and ntsf can i use this pal camera? and to OP, did u replace the keyhole with the camera?
GOODBYE: turbo RSX... HELLO: M3!
aznbeayst is offline   Reply With Quote
Old 09-27-2010, 04:15 AM   #34
Darkoz
My Ride: E46 325Ci
I'm pretty sure from what I've read that a dedicated reverse camers needs to be NTSC otherwise you'll get the flicker you're experiencing.
As zbi701 mentioned.........
Make sure you buy NTSC camera. The video module input only accept NTSC signal (dedicated for Reverse Camera). The other AV input is for video (to watch movies) which can be configured for PAL/NTSC or SECAM.
Darkoz is offline   Reply With Quote
Old 09-27-2010, 05:02 AM   #35
0-60motorsports
Yeah i sent back my PAL camera and waitnig to get my NTSC camera shipepd back.
Old 12-03-2010, 03:28 PM   #36
KurtBee
My Ride: 2002 BMW 320i
Would it be possible to set this BMW TV Tuner Module in my 2002 BMW 320 and if so where would i pput my climate control (the one with the knobs)
KurtBee is offline   Reply With Quote
Old 12-03-2010, 07:02 PM   #37
kensou
all what i can say is that the camera needs to output ntsc (or ntsc/pal capabilities).
I bought an other reverse camera for my M3, will install it and revert you back to confirm that.
Old 12-12-2010, 06:41 PM   #38
kensou
I tried to install my reverse camera this week end but i gave up because i cannot remove the trim on the trunk which has the 2 bulbs for the license plate.
Here is the type of camera i have. It's replacing one of the license plate bulb.
I can remove the 4 screws fixing the trim round in green below,
but something is still stucking the trim at the emblem area (rounded in red below).
Can anyone confirm that i have to unmount all the interior side of the trunk to access to a screw for the BMW emblem ?
Thanks for your help.
Old 01-10-2011, 05:59 PM   #39
seongstyle
My Ride: 2004 BMW M3 Coupe
hey guys, this is my first post on this forum so please excuse my unintentional lack of etiquette.
i did a rear camera install on my keyhole this weekend (http://www.amazon.com/Boyo-VTB180-Sm...ata/B001PYFSVQ) and got the wiring hooked up so that (1) my camera is powered by the reverse wire and (2) my Dynavin v5 is triggered by the same wire. It works, but the camera is only powered when the car is in reverse.
I want the camera to be on so that I can view it at any time (triggered by the reverse wire AND through the menu interface when I'm driving forward). I've read other posts about relays and switches, but was wondering if the following connections would work:
(1) Camera power connected to accessories wire (like the standard angel eyes install, so it's on whenever the car's on)
(2) Camera video cable connected to Dynavin video input
(3) Dynavin trigger wire connected to car's reverse wire
That way the camera is always on (which may not be desirable for some people) and accessible via the Dynavin interface, but also able to be triggered when the car is in reverse. It seems too simple to be true, but I don't (yet) understand why this doesn't make sense.
seongstyle is offline   Reply With Quote
Old 01-12-2011, 05:50 PM   #40
Blue Mesa
My Ride: 2006 M3 convertible
Yes. Pop off the emblem. There is then a screw under it holding the trim to the car. Then get ready to sand down the back of the camera/led a lot or it won't fit in the enclosure. You also don't have to separate the painted trim from the plastic (black) part underneath. Just pry off the cover to the light and take out the light parts. Once I sanded down the back of the camera/led I also had to use two small screws to hold it in place. A bit of a pain but nice once u get there.
Blue Mesa is offline   Reply With Quote
