Sponsored by The Tire Rack
Old 10-09-2009, 08:33 PM   #1
mvrk10256
My Ride: E30 325i
Question Tires too tall?
Hey guys i need help. So i bought 235/55/17 Pirelli Pzero tires and Voxx 17x8 wheels for a killer deal. Everything is just about new. the problem is that the wheels+tires stick out the sides just a little, but thats ok, its just in the back its right at the fender, its so "tall" that the back end rubs, and a speed bump is scarry as hell. I put em on and drove around the neighborhood and decided to put stocks back on for now until i figure out what to do.
So i need help...... is there anyway to lift the back end? or any other solutions
Old 10-09-2009, 08:40 PM   #2
cheech320
My Ride: Is TiAg
The side wall is much to tall for your car. The proper size would be 235/45/17. Apart from buying new tires your best bet is to get a thicker set of rear spring pads. You can also stack a couple if you need to.
or
just get the right size tires since the added height is going to look
-Anthony
Photobucket
cheech320 is offline   Reply With Quote
Old 10-09-2009, 08:42 PM   #3
mvrk10256
My Ride: E30 325i
Will the rear spring pads affect performance? higher center of gravity? i got these wheel/tires for better grip at autox and such. dont care too much about looks
Old 10-09-2009, 08:46 PM   #4
cheech320
My Ride: Is TiAg
Raising the center of gravity will create more lean/roll in corners. I doubt it would be noticable if it's only a few mm's though
-Anthony
Photobucket
Old 10-09-2009, 08:59 PM   #5
mvrk10256
My Ride: E30 325i
so if i order the 14.5mm ones for my car and put them on top of the original 5mm ones it should give me the clearance to run the wheels. It only rubs on the bumpy stuff, i just dont want to damage the body.
Old 10-10-2009, 10:35 AM   #6
CirrusSR22
My Ride: E36 318ti, E46 323it
Get rid of the tires.
CirrusSR22 is offline   Reply With Quote
Old 10-10-2009, 10:58 AM   #7
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Agreed. That is just a silly tall tires size to use on the car.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 10-10-2009, 12:40 PM   #8
BartenderPlease
My Ride: '03 540i/6 M-Sport
DO IT RIGHT DUDE. don't raise the car just to make it look uglier, grab some 235/45/17's
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 10-10-2009, 01:13 PM   #9
mvrk10256
My Ride: E30 325i
Oke. well i dont have the cash to go buy new tires. I ordered the spring seals, cause they were like 20 bucks, and i am going to double up with the stock 5 mm seal. that way its not going to affect the performance or the look. we are talking about 1.5cm. But it will allow me to fit larger tires with some real serious offset. I drove the car around and aside from the rubbing it handles great. but i am rolling on stocks atm.
Old 10-10-2009, 01:20 PM   #10
BartenderPlease
wow, you should just roll on the stockies until you can get the right tires. i mean, your speedometer isn't even going to be correct
Old 10-10-2009, 01:32 PM   #11
mvrk10256
My Ride: E30 325i
the spedo can be adjusted, both in car and in mind. i was really hoping someone on here would have a real solution. not jsut get new tires. I am a firm believer that there are ways to make anything work. plus if i was getting new tires i would get 245/40/17 or maybe 45s
Old 10-10-2009, 01:41 PM   #12
mvrk10256
My Ride: E30 325i
so when i did the speed calc, the appropriate replacement would be a 245/40/17 then the difference in diameter comes to about 1 mph in the end. 20.8 overall diamter vs the stock 20.4
Old 10-10-2009, 03:47 PM   #13
BartenderPlease
the real solution is get new tires, because the ones you have are way off when it comes to the size. but you already said that isn't possible.
sure there are ways to make anything work, but that doesn't mean they are the right way. plus a 235/55/17 on a lifted e46 will look horrible
Old 10-10-2009, 03:49 PM   #14
mvrk10256
My Ride: E30 325i
like i said performance is infinitely greater then looks.
but i am really f*cking p*ssed off about this. i think i am just going to sell the **** and get a different mod. maybe some lowering springs with the stock rubber. cause the stock rubber isnt as wide as i want it but the bfg gsports are great for grip.
Old 10-10-2009, 04:24 PM   #15
BartenderPlease
see, now you're talking. that would be the best thing to do. drop it on some stockies for a while and then get some new wheels. before you buy, post up the specs if you have any questions about fitment.
and yes, my bfg g-force sports STUCK to the pavement!
Old 10-10-2009, 06:43 PM   #16
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
+1! We are always here to help out, so feel free to post.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-10-2009, 10:49 PM   #17
mvrk10256
My Ride: E30 325i
spring rates for H&R springs?
Old 10-10-2009, 10:53 PM   #18
mvrk10256
My Ride: E30 325i
actually can someone explain to me the basics of wheels spacing? do lowering springs actaully give you width? ie allow you to run wider? how do you use wheel spacers and not rub on the fender upon compression?
Old 10-10-2009, 11:29 PM   #19
BartenderPlease
no you don't gain width. you just get the right size spacers by taking measurements so you don't rub
Old 10-11-2009, 11:56 AM   #20
mvrk10256
My Ride: E30 325i
right, forgive me if im a noob. but springs lower the body, and wheel spacers push wheels out....... so how do you avoid the top of your fender (the swoop) from hitting the top of the tires/wheel like was happening to me? ie. without body mods like rolling.
pirelli, tire rub, too tall, voxx
