#21 | |
See my previous thread http://www.bimmerfest.com/forums/sho...d.php?t=336475
#22 |
okay, maybe I'm just slow, but I'm not really seeing anything specific to MY02+ cars...
#23 | |
If I recall correctly cars with a either a 9/2002 (or 3/2003) and on built date have ribbon-type connectors thru out for the basic electrical circuit previously it was the pin-based style wire. The ribbon-type pretty much requires dealership programming for anything OEM you want to add to the car as in the case for Power Folding Mirrors or Memory and Heated Seats. I'm not 100% certain about the tail lamps but I do know when the ribbon type cars get upgrades from Halogen to Xenon headlamps the owners need to get the LCM re-programmed at the dealership. The easy and cheap way of doing it for you would be to still follow my DIY but in this way; 1. First check to see if there is a wire leaving Pin 49 on your current LCM body module. If there is a wire in PIN 49 then order the rear foglight LKM faceplate from a 2002+ European Car that had rear foglights from eBay.co.uk. Plug it in and if nothing happens then take it to the dealership for programing. The worse they will tell you is that you need the full LKM body. 2. Or if there is no wire at PIN 49 then you will have to follow my DIY exactly up until you get to the trunk lid area. Skip the steps for dremeling the socket holes. You only splice the wire from PIN 49 to whatever wire is powering the trunklid tail lamp driving bulb (aka the rear fog lamp bulb). This will give you rear fog ability with the press of the LKM rear fog and button (IE. the bulbs will already be on like normal with the normal driving lamps but pressing the rear fog button will make those bulbs very bright). This is how it works 100% OEM on European 2002-2005 E46 cars that have rear fogs.
#24 |
Thanks for this. I previously had an E36 and an E39 I added rear fog lights to, but I'd never found a way to add them to my E46. Your DIY worked perfectly on my facelift coupe.
#25 | |
Your doorhandle LED writeup was exhausting to read, this is pretty cool, and doable...I wonder though, my 325XI headlight switch has a setting for headlights on and A (automatic lights?) so when the conditions require light, they go on...point is, would I still be able to utilize this feature (auto lights) with the new switch plate? p.s. for those interested... here is an eBay Euro Switch plate for you all, same as Delmarco was using Auction Address: Euro E46 Switch Plate |
#26 | |
yeah. make sure you get a faceplate that comes with the A feature on it. see this picture: ![]() remember all you are doing is changing the LCM/LKM faceplate to get the rear fog button you are NOT changing the entire LCM/LKM module. So whatever your LCM did before it will keep doing after you add the rear fog lamp button.
#27 |
One note: a friend broke my left bulb holder while trying to help me drill out the socket for the bulb. When I ordered a replacement from the dealership, they told me my part number had been superseded (original part numbers ended in -09/-10 for left/right; updated part numbers end in -07/-08, respectively).
As it turns out, the updated part numbers are the Euro versions that come with the fog light bulb socket. They even come with new bulbs for the reverse and rear fog lights. For <$25 each, I'd just buy new Euro bulb holders if I had to do it again. Anyone experimented with non-standard 1156 bulbs in their rear fogs? I have a pair of LEDs that I'm going to try and I just got in some halogen 1156's that should be super-bright, but I'm afraid the halogens might get too hot.
#28 |
I have the LED tails for the sedan, which look great except for the headlight section that still lights up (which is your new rear foglight)... I'm wondering if I could "shut off" that section with this rear fog light switch?
![]() | 2011 328i xDrive | Titanium Silver [B]| Past: | 2004 330xi | Titanium Silver |
#29 |
just remove the bulb
#30 |
As usual great write-up. Demarco you come up with great ideas and implementation.
#31 | ||
Basically all rear fogs are useful for is a tailgater. It does add function, useful or not. I get why people do it. Activate a kind of hidden feature, a light in the cluster, and function of the car. Last edited by Brilliant; 03-14-2010 at 11:58 AM. |
#32 | ||||
I make it no secret that the idea of the rear fog DIY has been around a long time but the fact is it ONLY became popular when prefacelift cars were getting modded to Depo RCRs tail a few years ago and some folks had issues with the trunk lid bulb not being there at all and wanted to add it to complete the look of the RCR tail. This is how I became interested in adding rear fogs. So I spent about a month reading thru several DIYs from several countries and various BMW forums before I united all my research into one clear precise thread seen here: http://forum.e46fanatics.com/showthr...ight=rear+fogs Quote:
So obviously I did not think of this idea myself, but alot of the praise I get is not for my ideas but making old ideas clear, accessible for anyone to easily read, see the pictures and Do-It-Themselves. Quote:
Even on eBay the carriers that have the rear fog lamp hole are super rare and would most likely be bought from www.ebay.co.uk or ebay.de and you would have to pay more than$12 USD just to get them shipped to the USA. The 5/8" Dremel bit cost me about $3 and the skill required for drilling/dremeling can be taught to a third grader in wood shop class. So there is absolutely no need to severly mess anything up in this DIY via dremeling the hole for the rear fog. If you have $100 to burn on new brackets at the dealership then by all means do it that way. But my DIYs try to keep everything clean, simple and cheap so it is available for anyone to do. Quote:
E46. So this DIY also follows the logical progression of the E46 evolution. And in New York City traffic down in midtown Manhattan it works to ward of annoying tailgaters and idiots that roll up on your tail with high beams on. That said it isn't a critical function for the car like a gas pedal or brake lamps but it is more of a convenience function for the car like bluetooth, a CD player, air bags, etc...
#33 |
[quote=Brilliant;11464050]This wasn't delmarcos idea, its a very old DIY. I like to cite where I got ideas from in DIY. Not to diminish delmarcos write up, but to give credit to figuring out the pin location to one who made the knowledge public.
quote] Uh...whatever, still a great write-up.
#34 |
#35 |
Nice writeup. Thanks.
#36 |
I was able to activate my facelifted sedan's rear foglight by another route. I installed the appropriate LKM (thank you Tischer). Then I had my dealer reprogram it.
This was easier said than done for the following reasons: -I had to contact UK BMW's homologation office (all British autos must have rear fogs, etc. This office manages the conversion of imported (North American) vehicles). This office kindly directed the home office in the fatherland to transmit the code patch required by my dealership for reprogramming. I don't think that BMWNA would consent to this (I am in Canada). -European LKM's are not imported by BMW Canada, and now Tischer will no longer ship to Canada. |
#37 | |
I also modified the coding slightly so that both lights come on instead of just the driver side. I did this on a US Spec 330i ZHP.Rear fogs Off & Off w/ Brake Lights ![]() Rear fogs On & On w/ Brake Lights ![]() Rear fog indicator ![]() Now I need to get myself the faceplate rather than using INPA to send the button signal to the car. Last edited by TerraPhantm; 06-16-2010 at 11:17 PM. |
#38 |
How did you reprogram this on your own sir? I have a 2001 w/ a reprogrammable light switch unit (OEM LED retrofited, so I updated the LSZ)
AST 4100s, plates & s-RSMs | Eibach sways | OEM brace | CSL rack | CSL rotors & calipers w/ ST lines | Genuine CSLs w/ BBS caps Euro headers & Euro cats | MILLTeK raspx | VAC pulleys | 3.91 M Gears | Z3 SSK Infinity Kappa 5 amp, 50.9s, 60.9is | AC LC6i | CD53 retrofit w/ Aux | USASPEC ipod | OEM Sirius OEM Euro folding mirrors | OEM LED retrofit & Euro LCM | V-CSL diffuser (fits like S) | misc cosmetics Soon: CSL Intake Last edited by Brilliant; 06-18-2010 at 12:59 AM. |
#39 |
Yes, I'd like to know how you did this reprograming as well....
#40 |
I changed the vehicle order of the car, and then used some dealer tools to reprogram it to euro-spec. I have a couple posts detailing the process over at the diagnostic forums at BFC. To use the rear foglights you will need a euro faceplate in addition to the programming.
I also do some programming/coding for people for a small fee for those who live near NY or NEPA. I haven't successfully changed the region on a pre-02 model yet... still working on figuring that out. Coupes/convertibles and prefacelift sedans don't need to be reprogrammed to activate the rear fogs though. Last edited by TerraPhantm; 06-18-2010 at 06:35 PM. |
