Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 10-12-2009, 02:28 AM   #1
Snik
Snik's Avatar
My Ride: IR M3 Vert.
One sick motor
The S63, BMWs new twin turbo 4.4 liter V8 motor that is powering the new X5 and X6 M.
whats so special about it. how about the turbos being between the bank, instead of outside.
The S63B44 engine represents the latest innovation coming out of the Motorsport Division steel gates. The 4.4 liter V8 engine uses an an amazingly engineered and of course patented, exhaust manifold. The dual twin-scroll turbochargers are positioned together with the catalytic converters in the V section between the two rows of cylinders. According to BMW engineers, compared to a typical V engine configuration, the cylinder heads have been reversed with the exhaust going towards the inside of the V. The cylinder head uses the same aluminum alloy as BMWs diesels.
The two cylinders for each scroll are 180 degrees apart in firing order, yielding better performance and most important, very minimal turbo lag. The turbos also have two liquid-to-air intercoolers.
The engine produces 555 horsepower, five more ponies than the Cayenne Turbo S and also an impressive 500 lb-ft of torque at only 1,500 rpm.
Do you ride a sportbike?
Old 10-12-2009, 02:37 AM   #2
k7780446
My Ride: 323i
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 10-12-2009, 01:36 PM   #3
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
Thats an incredible design!
I wonder how they deal with so much heat in the center of the motor, under what usually is covered by a plastic engine cover. I always thought turbos were mounted down on the sides of engines because there was decent airflow there...
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 10-12-2009, 01:39 PM   #4
Snik
Snik's Avatar
ive also read that putting them on the sided, the plumping from the turbo has to be much longer to get to the intake manifold, and that by swapping them around this could be shorter. quicker warm up time for the cats, and less lag.
Old 10-12-2009, 01:40 PM   #5
poynter
My Ride: RAV4
Those turbos look tiny. I bet that thing would be a ***** to work on.
I love that bottom rendering.
-tony
poynter is offline   Reply With Quote
Old 10-12-2009, 01:42 PM   #6
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
damn, those pics are sickkk!!!!
Devious1 is offline   Reply With Quote
Old 10-12-2009, 03:09 PM   #7
Mark M
My Ride: e30 M3 / e90 335d
Amazing engineering and capabilities......but pray go God you'll never own one used and have to wrench on it!!!!
Mark M is offline   Reply With Quote
Old 10-12-2009, 03:12 PM   #8
Blocked Out
My Ride: Imola 330i M-Sport
That motor is super sick in every aspect. But those cats are SOOOOO restrictive, just imagine how much power it'll make without them.
4.4 v8 twin turbo is capable of 1000 (safe) horses with the right tune. BTW turbos in between the cylinder banks is super (It'll make or brake the design) .... just reverse the cams ..... what a brilliant idea.......
Anyway the motor is sick, but dont forget it's not BMW's thing>> meaning they're just getting into the Turbocharged business, they still have a long way to go and this is a HUGE step up.
Original BMW Teile ///
IMG_1725
Old 10-12-2009, 03:40 PM   #9
patdeezy
My Ride: a grey e46 sedan
Send a message via AIM to patdeezy
goddamn my monitor is too small
-m330-
EUROPROJEKTZ
REALIE CLUB 2007 - I'M KEEPIN IT REAL!
SPONSORED BY
|SGC Godfather|
KOBE in 2012
patdeezy is offline   Reply With Quote
Old 10-12-2009, 06:52 PM   #10
Snik
Snik's Avatar
BMW has been doing turbos for years, with the diesels, and since the 70s, with the 2002 turbo from way back, i think they have a thorough understanding of how turboes work.
Its cooling things they suck at.
Old 10-12-2009, 07:47 PM   #11
///Orient3
My Ride: can't be defined
Awesome. Cats are required, but I was kind of hoping to see them not so far forward in the exhaust stream like they are in most of the BMWs. I guess I shouldn't have expected different, but it probably would have gotten me excited for the future of BMW engines.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 10-12-2009, 07:51 PM   #12
Snik
Snik's Avatar
theyve been moving them closer and closer for emission purposes. cold start up really hurts their pollution output ratings.
Not, when supersprint or whomever makes headers for this puppy, my god, the price is going to be just absolutely maddening, but should make for bigger than normal gains.
Old 10-12-2009, 09:51 PM   #13
VillanovaGrad
My Ride: M3 M5 X3
whats the big "cork" like thing located at the down pipe?
VillanovaGrad is offline   Reply With Quote
Old 10-12-2009, 11:06 PM   #14
///Orient3
Of course they do it for emissions purposes, cats are more effective when hot and moving them closer serves an obvious purpose, but that doesn't mean I can't hope we will eventually get an emissions system more like those of the European market BMWs. My point was really: imagine what kind of numbers the engine could produce stock with cats not choking down the turbos and exhaust flow so much.
Old 10-12-2009, 11:54 PM   #15
Snik
Snik's Avatar
Its wishful thinking man, the restrictions are only getting tighter and thighter. Its one of the main reasons bmw went back to gasoline turbo engines after such a long time.
Old 10-13-2009, 03:10 AM   #16
Presns3
My Ride: E46|2.0T
cat
Presns3 is offline   Reply With Quote
Old 10-13-2009, 05:20 AM   #17
roastbeef
My Ride: 325ci
how much for a crate turbo 4.4?
roastbeef is offline   Reply With Quote
Old 10-13-2009, 05:54 AM   #18
Snik
Snik's Avatar
^ lol
Old 10-13-2009, 09:34 AM   #19
kz330xi
My Ride: 04 330xi...
wow
kz330xi is offline   Reply With Quote
Old 10-13-2009, 10:20 AM   #20
///Orient3
Yeah, thats why I used the word hope. I know its a pipe (more like piping) dream.
