Old 10-15-2009, 06:08 PM   #1
330Lover_
My Ride: 2001 330i bk/bk step
Trouble getting the fan out...help
I was going to replace the ac/Serpentine belt but got stuck on the fan part. The fan nut was so tight that I couldn’t move it with the Fan removal tool with the 32mm wrench.
Should I turn clockwise or counter clockwise to loose the fan nut?
The following is the DIY for E46 Fan Clutch Removal & Engine Belts Change For Automatic/Step Cars. Thks
http://forum.e46fanatics.com/showthr...8#post10581818
01' 330i, step, bk/bk, moon, xenon, cd, 18x8 ASA AR1, 225/40/18 all around, Koni Yellow shock, Eibach Pro-spring, Axxis brake pads, 20mm rear spacers
330Lover_ is offline   Reply With Quote
Old 10-15-2009, 06:43 PM   #2
snowie007
My Ride: 2000 323i
the fan clutch is reverse thread... therefore, righty loosey lefty tighty
snowie007 is offline   Reply With Quote
Old 10-15-2009, 06:49 PM   #3
ejamin73
My Ride: '04 325i Sport Pkg
Yep!
Be careful not to break the T-stat
I just can't imagine the world without the smell of burned gas coming out of a well tuned engine:drool:
Originally Posted by zhp pilot View Post
nice try on the sig you tard. unfortunately, when you click the link you see the actual quote.
you are on a roll with the FAIL tonight. :lmao:
ejamin73 is offline   Reply With Quote
Old 10-15-2009, 08:19 PM   #4
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
righty loosey and a little bit of elbow grease
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 10-15-2009, 08:28 PM   #5
Bodo61
My Ride: 323i
But why remove the fan to change out the belts when you just need to move the tensioners.
Bodo61 is offline   Reply With Quote
Old 10-15-2009, 08:30 PM   #6
00bmw323
My Ride: 00 323/91 integra RS
fan is in the way...he has an auto
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 10-15-2009, 08:32 PM   #7
ejamin73
Because you need to remove the fan to be able to do it
Old 10-15-2009, 08:34 PM   #8
Bodo61
My Ride: 323i
That is BS I have done it with the fan in and I have an auto.
Old 10-15-2009, 08:54 PM   #9
Hartman
My Ride: 2000 323i
I don't know how the hell you pulled that off.
Hartman is offline   Reply With Quote
Old 10-15-2009, 09:00 PM   #10
giver13
My Ride: 01 330 ci
Its much easier to remove the fan and quicker. No need fot the tool , just whack it with a hammer to the right. comes right off
giver13 is offline   Reply With Quote
Old 10-16-2009, 03:20 AM   #11
imlostathome
My Ride: Black 06 m3 manual
well if the fan is an issue you can do it with out taking out the fan... just work your way around the fan... pull it between the fan and fan shroud. You will need to spinn the fan and work it out but it will work. You just gotta sit and picture it. Just put the belt around one fan fin at a time.
imlostathome is offline   Reply With Quote
Old 10-16-2009, 10:12 AM   #12
nathancarter
My Ride: 02 330i
It's possible to do the belts with the fan on, but it's a helluva hassle. If you have the right tools, it's less work to just remove the fan and shroud.
nathancarter is offline   Reply With Quote
Old 10-16-2009, 10:12 AM   #13
330Lover_
Thanks guys, I got it!
May be you did it under the car?
Old 10-16-2009, 10:22 AM   #14
Kubica
My Ride: 2003 325xi
Yeah I put my ac belt back on from underneath without taking out the fan. I have a manual though.
Old 10-16-2009, 10:28 AM   #15
dtuuri
My Ride: 323it
I went from underneath to replace both belts, a bit of a hassle but easier than taking the fan off. 50mm torx socket and a long handled rachet worked well....be careful under the car though, jack stands are a must!
dtuuri is offline   Reply With Quote
Old 12-28-2009, 05:28 PM   #16
gSP33D
My Ride: 330i
Alright...just found this thread as I'm in the garage with my coolant drained and I cannot get the fan clutch to break loose! I've got the fan clutch tool, 32mm socket and I'm banging the wrench with a rubber mallet to the right (reverse thread) and the MF will not budge!!! Any ideas or tricks to get this thing to break loose?!?!? Do these things seize up?
gSP33D is offline   Reply With Quote
Old 12-28-2009, 08:22 PM   #17
Hartman
My Ride: 2000 323i
Try a regular hammer. The rubber mallet is absorbing some of the force. Just be careful swinging obviously.
Old 03-26-2010, 02:55 PM   #18
BimmersGarage
My Ride: E46 330i
For future reference - Here's a DIY video for anyone that needs to remove their Radiator Fan/clutch (with automatic trans.) to work on their belts, pulleys, water pump, thermostat(s), or any other component near the front of their motor...
BimmersGarage is offline   Reply With Quote
