Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 10-19-2009, 03:40 AM   #21
EDawg
My Ride: :/
are e36 m3's notorious for subframe failure as well. i wouldn't mind getting 1 as a toy/track car.
EDawg is offline   Reply With Quote
Old 10-19-2009, 06:30 AM   #22
griffon252
My Ride: 01 325xi
yeah, if your gonna track it then it is highly recommended you reinforce the subframe. Just pick up the reinforcement kit from turnermotorsports.
griffon252 is offline   Reply With Quote
Old 10-19-2009, 09:50 AM   #23
Mark M
My Ride: e30 M3 / e90 335d
Respectfully I disagree with the above statement.
The early e36 3 series suffered issues with subframe failure, however the ///M models had beefed up subframe mounting points from the factory.
Quote from BimmerWorld
"The rear chassis at the point the rear subframe attaches is a failure point on heavily tracked E36 cars. All M3s have reinforcement plates welded in from the factory to solve this problem. But if you track your non-M E36, chances are at some point you will need to repair this area. Our reinforcement plates are a factory fit and can easily be installed when subframe bushings are added. Welding required."
http://www.bimmerworld.com/html/e36-...cement-kit.htm
Mark M is offline   Reply With Quote
Old 10-19-2009, 12:50 PM   #24
griffon252
My Ride: 01 325xi
ah i misread his post, im at work and was typing in a hurry haha.
But, on that point, read through these two threads:
http://www.m3forum.net/m3forum/showthread.php?t=266861
http://www.m3forum.net/m3forum/showthread.php?t=269234
There are people who have reported both, their subframe and suspension points tearing out on tracked cars. This specific case is a buddy of mine's 95 M3.
Old 10-22-2009, 02:05 PM   #25
Jake_928
My Ride: 2005 325xi
If I didn't need a truck at the time I would still have my 1997 328i 5spd fun and practical. I see it once in awhile, it did not go to a good home
2005 325xi
Jake_928 is offline   Reply With Quote
Old 10-22-2009, 08:03 PM   #26
MagnumX
My Ride: E46 M3 & E36 325i
Some of these posts are funny. Get what you want OP, an e36 m3 will be a nice addition to your stable.
MagnumX is offline   Reply With Quote
