Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Old 09-27-2010, 03:40 PM   #81
SprChrg328
My Ride: 1999 328i
Incase noone ever told you...im kind of a big deal!
SprChrg328 is offline   Reply With Quote
Old 09-27-2010, 04:07 PM   #82
Rickna
My Ride: '01 330xi - '09 IS-F
Originally Posted by BimmersGarage View Post
Funny.
Well.. just remember to have a cold beer then.
That's the reason-beer!
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 09-28-2010, 01:11 PM   #83
Riverbmr3
My Ride: MB E350 & BMW 325i
I replaced my FSR from Pelican and then problem still the same, called Pelican and they sent me a new FSR and sent them back the first one cause we thought it was defective. After installing the new FSR problem still the same.. anybody encounter same problem and what the solution be?
Riverbmr3 is offline   Reply With Quote
Old 09-29-2010, 06:49 PM   #84
jeffmr
My Ride: 2003 325xi
Done here. A magnetic screwdriver and the bmw flashlight are pretty helpful. You can actually alternate between kneeling on a floor mat outside the car and looking in and laying on your back with your feet out the door to get it in. No screws for mine. One question though. I can't remember if it was this way before the replacement but when I hit auto and any temperature is selected, the fan goes to one notch before all the way high. I thought it turned on full speed before. Has anyone seen this?
jeffmr is offline   Reply With Quote
Old 09-29-2010, 09:32 PM   #85
madrv1
My Ride: 323ci 2000
That's normal... the Auto will sort of reset the fan speed and adjust it to the necessary speed to get the cabin temp to whatever setting you selected.
UUC Shortshift w/ DSSR, UUC RK6A-L Shift Knob, Staggered 18" Breyton's Inspirations, Smoke Corners, 76" Dual Tip Remus Catback, Conforti CAI and Shark Software, H&R Sport Springs and Sway bars, and Bilstein Sports Shocks, 3.46 diff, UCC Pulleys.
madrv1 is offline   Reply With Quote
Old 09-29-2010, 10:05 PM   #86
jeffmr
My Ride: 2003 325xi
I was just wondering though because I set it to the lowest and highest temperatures in 70 degree weather and it never went to complete high which it should have if it was using the full range. I seem to remember it doing this before.
Old 10-03-2010, 09:24 PM   #87
truajb
My Ride: 2002 325xi
Open things up again today to probably install the new FSR. With the help of a screw driver and some luck, I was able to complete the job in about 20 mins. One tip is to tape the parts that sits in front of the FSR up so that it's not in your way. It will still be there but at least it becomes easier for you to reach the FSR. Good luck to other DYIers.
truajb is offline   Reply With Quote
Old 10-09-2010, 02:26 PM   #88
hockey_fan
My Ride: 2000 323i
Thanks to sycE46, for the great DIY. The only things different were that I had Phillips screws holding in the glove box. I did manage to lose one of the torx screws holding in the FSR unit...it fell behind the carpet and as I tried to retrieve it it worked it's way deeper. A note to add would be that the air vent just wiggles right out...that gives you access to the module that you have to unscrew. I paid $67.42 for the FSR with shipping from autohausAZ. It is a Behr unit and a lot smaller the OEM. Took about an hour to replace...that included coming back in the house a few times to look at the DYI and pictures. The fan works like new again, I can hit 'auto' and it adjusts now. Previously the fan was either on high or off...no in between speeds. I have to figure I saved at least a couple of hundred dollars with this...so many many thanks !!!!
hockey_fan is offline   Reply With Quote
Old 10-09-2010, 08:18 PM   #89
wildcat293
My Ride: 325xi
According to the bentley manual you can get that duct out of the way if you remove the heater control panel and attack it from the top. I was real close to trying it but finally was able to maneuver the old FSR past the metal tube down there. Wasn't able to wiggle the air vent out from below.
wildcat293 is offline   Reply With Quote
Old 10-16-2010, 04:20 PM   #90
kuzimmer
My Ride: BMW 325i
Thanks for the DIY.
This would have taken me about 20 minutes if I hadn't ^%$#^ up and broke the clip on the top of the flap actuator, Its the cream colored cap like thing shown in pictures 3 and 4. Its not terribly expensive, as it looks like it comes with the actuator bracket part number 64 11 6 979 467 in real OEM. About $10 with CCA discount, but unfortunately, I can't get my hands on one until next week Wednesday. Grrr. I'm really good at turning simple jobs into colossal jobs... For anyone else who reads this. Its true you don't have to disconnect it completely, but you have to make sure when you push it out of the way that you are not stressing the clip. I didn't have light in the right place until AFTER I heard the crack.
Kurt
kuzimmer is offline   Reply With Quote
Old 11-10-2010, 01:37 PM   #91
Rick C.
My Ride: 2000 323i Sedan
Originally Posted by sycE46 View Post
Here's my DIY on replacing the Final Stage Unit (Resistor).
I know there's other DIYs on this, but i tried to create one with better pictures. It can be a little confusing when you're trying to replace the unit.
A failing Final Stage Resistor will cause the cabin fan to blow at sporadic speeds. It usually shows up as the fan blowing at a faster speed then it is set to.
http://www.bokchoys.com/differential...stage_unit.htm
Parts Needed:
Final Stage Unit (Part # 64116920365)
(Check BMW for latest part #)
Tools Needed
T-20 Socket
Philips Screw Driver
1. Remove Glove compartment. (6) Philips Screws. Unplug light and flash light wires.
2. Remove the lower tray holding footwell light. Unplug light.
3. The final stage resistor is located behind the footwell air duct as seen in the picture. There's a module blocking it, you'll need to move it out of the way before you can access the Final Stage Resistor. Move this module by removing the (2) T-20 Screws. There's a hose that's connected to this module that you don't need remove. Just let the module dangle.
4. You should be able to see the Final Stage Resistor now. Remove Final Stage Resistor by unscrewing the (2) T-20 screws. Unplug the wire. Un-clip unit and pull out.
5. Reconnect everything in reverse order and you're done.
Picture of a new final stage resistor
Thanks so much for that detailed DIY! My blower motor gave me only one warning before it stopped working altogether. I found my part at AutohausAZ.com for $70...followed your steps...and now I'm back in business! It's a little tricky contorting yourself into position and trying to get a light on things, but if you take an occasional break to stretch out...you will get it done.
Rick C. is offline   Reply With Quote
Old 11-10-2010, 02:41 PM   #92
CylonRed
My Ride: '01 E46 330i sport
subscribe
CylonRed is offline   Reply With Quote
Old 11-10-2010, 02:47 PM   #93
Ivanhoe
My Ride: BMW 330 xi 2005
Very Usefull
Ivanhoe is offline   Reply With Quote
Old 11-11-2010, 04:17 PM   #94
JosephZ
My Ride: 2001 325i
Got my BAHR FSR from http://www.rmeuropean.com. I only paid $59.17 and received Free shipping.
It is a little bit of a pain, but everyone should be able to complete this DIY in 1 hour or less.
My story: 2 months ago my blower did not come on, all I did was turn the car off and back on, like magic the f'n blower came to life. Blower worked perfectly until 1 week ago. I started the car and turned on the heat, blower never came on. I did a few check steps (disconnected Negative terminal, checked fuses) nothing worked. Today I Replaced FSR and everything is working fine.
JosephZ is offline   Reply With Quote
Old 11-21-2010, 01:44 PM   #95
CylonRed
I am having major difficulty - I can only get to one screw, of the module in the way, and even then - only to see. Can't use a screw driver T20 because it is tucked up behind the center console. Can't use a socket because the top of the module I have to get out of the way, prevents the socket from getting close to the screw. Any extension and the socket will be to long and will hit the fuse box.
I can't see how this can be done in any way, shape, or form.
How in the F&*K do the wires come off?!?!?!?!!? There is zero play - there has to be a latch that can't be seen.
I finally figured out the FSR is lower than the original part I saw. Like someone else here - there is no getting the vent out of the way - it does not just wiggle off in any way. The Bently shows that it is clipped on and would need to take apart many pieces in the engine bay.
Only one screw holding it in but it won't budge - there was a plastic clip as well - had to force it aside but the unit still does not move.
Old 11-21-2010, 04:33 PM   #96
CylonRed
Well - found out how to take the wiring out - had to pry the retainer clip up and it slipped tight out. FSR got reclipped BACK in - could not budge the clip. Starting to break the plastic clip and the housing for the module that was in the way. Decided to reclip the wires back in since the FSR was not going to come out - nothing to grab onto. Still could not get the clip holding the FSR on, to move out of the way. Decided to take the wires out again - broke that clip and now the wire hardness will NOT come off. NO idea why - wires are inthe way to see, can't get enough light to see the clip that broke off - it looks like it completely broke off all of the way across.
I don;t see how this is even possible to work out. How it can be done in 20 minutes is beyond me.
Old 11-29-2010, 01:04 PM   #97
NerdCore
My Ride: 02 325i
Just did mine and it worked! My symptoms were hat regardless of what I did the fan would stay on even after the car was off. If I turned it on I wouldn't get hot or cold air but warm and it would be blow heat. One I turned the system off it would go full blast. Doing this solved everything.
2002 BMW 325ish - Soon to be slammed, blackened, blown, and still daily driven
Click4Facebook
NerdCore is offline   Reply With Quote
Old 12-04-2010, 11:17 AM   #98
hristoff325ci
My Ride: BMW 325 CI
I am about to replace the FSR in my 325ci, hope everything goes smooth
http://picasaweb.google.com/iliya.hristov/BMW325CI#5416050224914299250
(OO=||=OO)
hristoff325ci is offline   Reply With Quote
Old 12-04-2010, 02:57 PM   #99
hristoff325ci
My Ride: BMW 325 CI
thanks everyone for the info on FSR, just replaced mine and the blower is working now
(OO=||=OO)
Old 12-14-2010, 03:08 PM   #100
manilaboy1vic
My Ride: 2002 330Ci
thank you for the write.. up.. completed yesterday.. my ac was intermittent then everything just stopped working, AC, heat, defrost.... i had the part for the day.. yesterday was it., definately not as easy as chaging the oil.
For sale
Stock Headlight Halogen Housings for prefacelift E46
manilaboy1vic is offline   Reply With Quote
fan surge, final stage, fsr
