E46 Convertible
Old 10-16-2009, 09:15 PM   #1
burntass
My Ride: ///m3 vert, 05 MCS
center console cutting for the convertible
I just received a brand new console, and it doesn't fit my convertible. then I noticed a set of instructions which indicates some cutting might be involved. has anyone ever re-cut their console to fit their convertible? if so what tools did you use? a table saw?
here is the console:
2005 ///m3 cb/cinnamon vert: weekends
2005 Mini Cooper S/jet black hardtop: daily
1988 e30 325ix/gray hardtop: gone
2002 e46 tiag 325ci vert: gone
burntass is offline   Reply With Quote
Old 10-16-2009, 09:31 PM   #2
Acarder
My Ride: 69' M3
You should have gotten a template with the console, you're supposed to line it up and then dremel the shape out. Kind of budget I guess, but on the other hand BMW generally doesn't assume that people will be installing these things themselves so its understandable.. its just a little more work for your mechanic.
Acarder is offline   Reply With Quote
Old 10-16-2009, 09:59 PM   #3
BobSC
My Ride: 01 330Cic, 12 750Li
I just did this last weekend! I used the template that came with my console to mark where it need to be cut....and I used a battery operated jigsaw to cut it. Very easy to do, and came out great.
I also think most people use the dremel tool.
Good luck
2016 X5
2012 750Li (Sold)
2012 X3
2007 750Li (Sold)
2004 X3
2001 330Cic
2000 328i (Sold)
BobSC is offline   Reply With Quote
Old 10-16-2009, 10:30 PM   #4
burntass
thanks for the advice guys, will goto home depot first thing in the morning to buy a tool
Old 10-17-2009, 09:37 AM   #5
rebmo
My Ride: 2006 BMW 330Cic
I did the same just recently as I needed to do a cutout also for the rear vert alarm sensor cover (06 vert). The alarm sensor template also includes the vert cutout section. I cut out the template (the section that gets cut out) and scotch taped it to the new console. I used a dremel with a cutting wheel since there is other plastic right behind what you are cutting away and you don'd want to go too deep. Once the cutout was finished I used an X-acto knife to cut away any plastic in the corners still holding the cutout in place, and the used a sanding block to clean up the edge. It came out perfect. BTW, the template does not stick too well to the console, so that's why I used clear Scotch tape. It holds it in place better and it protects the surface from scratches while cutting.
Reb
rebmo is offline   Reply With Quote
Old 10-18-2009, 10:45 AM   #6
cgj
My Ride: 2006 325CIC
Just curious, why are you (and everyone else on this thread) replacing the console in your convertible?
cgj is offline   Reply With Quote
Old 10-18-2009, 08:27 PM   #7
BobSC
I replaced mine because I was two toning the car and replaced a beige one with a black one.
However, I have seen a lot of fanatics replace them just because they are old and scratched up.
It is VERY easy to do.
2016 X5
2012 750Li (Sold)
2012 X3
2007 750Li (Sold)
2004 X3
2001 330Cic
2000 328i (Sold)
Old 10-19-2009, 06:53 AM   #8
BavLar
My Ride: 330Cic 5spd & 330i
What should we expect to pay for a console assuming we are able to cut and install DIY? Is the ashtray cover and the sunglass tray cover just as simple to replace?
BavLar is offline   Reply With Quote
Old 06-04-2010, 08:03 PM   #9
Maveric
My Ride: 2004 M3
Question
I have to cut my new center console for my convertible. Unfortunately, I don't have any power tools.
Can I just use a box cutter heated up every 30 secs. or so with a candle flame?
Thanks!
Maveric is offline   Reply With Quote
Old 06-04-2010, 08:05 PM   #10
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
i used my dremel. takes less than a minute and looks great.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 06-04-2010, 08:13 PM   #11
AHEAD OF THE CLASS
My Ride: M3, Ducati 848, RR
Send a message via AIM to AHEAD OF THE CLASS
I also used a dremel very easy an i felt like Tim the tool man Taylor lmao.
AHEAD OF THE CLASS is offline   Reply With Quote
Old 06-04-2010, 08:59 PM   #12
iansanderson
My Ride: 2001 330CiC
convertibles get a lot more sun than the average 3 series. The sun makes the rubberized coating look faded and dirty after a few years.. plus normal use scratches it up and makes it look like poop especially around the parking brake handle.
then BMW really screws you because the don't sell a console specific to the convertible, so you have to order one from the coupe and cut the back so it fits the higher hump profile of the body.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 06-04-2010, 10:51 PM   #13
jfoj
My Ride: 330CiC, M5, X5, E93
I used a Fein Multimaster to make the rear cut out for the rear most motion sensor cover.
Was unaware that you would need to cut a coupe console to fit the Vert, but now I know if I ever need to swap it out!
Old 08-04-2010, 12:52 AM   #14
Maveric
My Ride: 2004 M3
Question
Guys, did your template fit properly? My template doesn't seem to align correctly with the edges of my console!
2004 Silver Gray/Black M3 Convertible
Old 01-27-2011, 01:13 PM   #15
Maveric
My Ride: 2004 M3
Lightbulb
Since my template didn't align well with the new center console, I removed the old one and used it as a template. I put masking tape on the new console and used a pencil to trace a cutting line.
Since I don't have a dremel, I flattened the tip of a soldering iron with a hammer and used it as a hot knife. It didn't produce the best results, but it worked. I used 100 grit sand paper with a sanding block to clean up the edges.
Replacing the console itself was easy with these DIYs:
http://www.pbase.com/jeffwong/centerconsole
http://e46fanatics.com/forum/showthread.php?p=11183388
Old 12-19-2012, 10:48 AM   #16
McGary911
My Ride: 2004 M3 Convertible
I wish I had seen this thread before I tackled this last night. Luckily it was pretty easy to put 2 and 2 together once I saw the template in the box. Like others, I cut it with a hacksaw and Dremel wheel. I used a deburring tool to clean up the edge, and I'm good to go. I got a eurotray as well to replace the cup holders. The car looks a LOT nicer now.
McGary911 is offline   Reply With Quote
Old 12-28-2012, 12:30 PM   #17
jpvale93
My Ride: bmw m3
Can anyone take pictures of how it came out and looks installed thanks if u can email them to me I would appreciate it juanvalencia2@aol.com
jpvale93 is offline   Reply With Quote
Old 04-09-2014, 10:17 PM   #18
DropTopKingM3
My Ride: All German
Thanks to everyone in this thread for all their help. I was going nuts trying to figure out why my new center console wasn't fitting. My friend used the saw and dremmel method and did it for me. He didn't like the template so he used the old center console as his template and drew around the new one. Once the new console was installed you can't even tell it was modified
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
center console, e46
