Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 06-19-2012, 08:29 AM   #261
jonwrong
My Ride: 2002 325i
Originally Posted by johntrhodes81 View Post
Thanks, You can have a monitor not ready but still have no code set.
John
You lost me, but the goal of this mod for me was to delete the check engine light issue so when the light is on, I know there might actually be something wrong.
jonwrong is offline   Reply With Quote
Old 06-19-2012, 08:33 AM   #262
johntrhodes81
My Ride: 2004 325i Wagon
What I was trying to say was if you have an OBD2 reader hooked up it can show certain monitors as Not Ready, but no codes and CEL could be showing.
The BimmerBrakes 02 Sim will prevent a code/CEL from showing (it rotates between 3 voltages), but not all monitors will have a status of ready.
John
John
DIY BMW Performance Style Extra Air Intake
http://forum.e46fanatics.com/showthr...6523&highlight
johntrhodes81 is offline   Reply With Quote
Old 06-19-2012, 08:36 AM   #263
jonwrong
My Ride: 2002 325i
John
Ahh, 10-4. I had a local BMW only shop read all the monitors when I was getting a traction control, brake, abs light a week or two ago. It turned out to be the steering angle sensor. At that time, there were no emissions related issues, even with that ridiculous professional code reader.
Old 06-19-2012, 08:38 AM   #264
johntrhodes81
Cool. Good to know. John
John
Old 06-19-2012, 04:23 PM   #265
mattfarrington
My Ride: 04 325xi
I'll have to get this done soon, as I plan on removing my Cats.
I'd get the O2 sim, but in NH all monitors need to read ready. And all tests need to "pass" (no CEL)
mattfarrington is offline   Reply With Quote
Old 06-19-2012, 09:29 PM   #266
redlin'r
My Ride: (E46) 330Ci
I've been through all the pages on the thread and am wondering if anyone has put together exactly what you need. From what I read I just need the LC-1 with wide-band (gauge optional for read out) and two resistors, correct?
Can I just remove one post O2 sensor (replace with bosch sensor) and leave the other stock o2 sensor in?
I already have a o2 simulator wired in but still get P0420 and P0430 codes, do I even need a resistor wired since I have the sim?
redlin'r is offline   Reply With Quote
Old 06-20-2012, 05:17 AM   #267
johntrhodes81
Yes you can take out one o2. You don't need the sim. O2 work better than resistors.
John
Old 06-20-2012, 07:41 AM   #268
jonwrong
My Ride: 2002 325i
All the info you need to do this mod, both with and without resistors, is in this thread. I hate to see this thread continually cluttered by the same questions, it makes it harder and harder to find the actual meat of the topic. Please read through, and all of your questions will be answered.
Old 06-20-2012, 09:09 AM   #269
redlin'r
I didn't see a post about no resistors? I think a DIY with schematic and detailed instructions will help remove the clutter and constant questions
Anyone willing to do this for us?
Old 06-20-2012, 09:32 AM   #270
redlin'r
Here is the steps I have
1.) Install pre-cat o2's
2.) Install LC-1 wideband sensor into post cat (does it matter if its 3rd or 4th bung?)
3.) Plug other sensor bung not used.
4.) Connect first post cat heater cables together by using resistor. (can this be done on engine harness or do you hack the existing o2 connector cable?)
5.) Connect second post cat heater cables together using resistor. (can this be done on engine harness or do you hack the existing o2 connector cable?)
6.) Connect both first and second o2 black cables.
7.) Connect both first and second o2 grey cables.
8.) From there you wire the black and grey to the LC-1 as signal and ground (not sure which one is which yet).
9.) They you wire the LC-1 to the DME via ground and 12V power source.
So the heaters for the o2 are being simulated by the resistors, the 2 o2 ground and signal are combined and wired to the LC-1 which will mimic both and finally all is connected to the DME.
This seems pretty straight forward now that I have gone through the thread 3 times Am I correct?
Reposted Schematic:
Old 06-21-2012, 06:08 PM   #271
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Just got it done yesterday. Works like a charm so far after ~100 miles.
Hack it after the engine harness cable. O2 sensor connectors are plenty used. Engine harness end, not so much.
I think the thread became confusing as there are a few ways to simulate the heaters, either by using the stock O2 sensors or installing resistors.
No one mentioned added a fusing the 12v line from the LC-1 with a 5a fuse. I did, just in case.
phamine is offline   Reply With Quote
Old 06-21-2012, 11:34 PM   #272
F1004fun
My Ride: '02 330Ci
Your post was perfect!
For those of you that want to tie both of the post-cat O2 signals together on Analog1 and use Analog2 as an output to a AFR gauge, yes this works MOST of the time. If you run into problems though us the above method.
On the AFR gauge note: Since most of us have iPhones you might want to look into the Innovate OT-2.
http://www.ot-2.com/
It has a really good data logging feature that I use to check AFR's on WOT runs, you can data log intake air temps if you want to play around with intakes.
F1004fun is offline   Reply With Quote
Old 06-26-2012, 04:26 PM   #273
phamine
The LC-1 eliminated the catalytic efficiency codes. But I can't get rid of these codes.
I ran DIS and the codes are below. I don't understand the codes as it states both before and after the catalytic converter within the same code.
I ran the test plan in DIS for the 02 sensor and noticed and found that:
=> When throttle is applied ; voltage does not increase. DIS expects it to increase with throttle application
=> 0.6V is steady as throttle is applied
=> Voltage drops to 0 when the throttle is released.
So what can be the issue? DIS is telling me to replace both of my precat and postcat o2 sensors.
DME - (226) E2 Trimming. oxygen sensor behind catalytic converter, bank 2 - too great in rich range (P1193)
=> Oxygen sensor, Bank 2 before cat converter B1214_MS43LV2
DME - (225) E2 Trimming. oxygen sensor behind catalytic converter, bank 1 - too great in rich range (P1192)
=> Oxygen sensor, Bank 2 before cat converter B1214_MS43LV1
Old 06-26-2012, 10:26 PM   #274
F1004fun
My Ride: '02 330Ci
Let's try setting the voltage curve to .750V up to 20:1 AFR and then back to .050V at 21:1. What are your current fuel adaptations before adjusting the curve, long-term and short-term.
After running this setup for a while on a couple of cars I have noticed that at .650V the DME pulled a bit of fuel out of the long term fuel curves. I have been currently testing with the .750V setup and noticed a change of 1%-3% in the long term fuel curve. So basically if you were sitting at -5% running the LC-1 at the .650V setup could push you past the -8% limit and set off a rich running fault.
I'm not really sure why the DME does this. I have looked at other cars and it seems that the post-cat voltage range WITH cats has been between .650V and .750V.
Old 07-12-2012, 05:36 PM   #275
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
What does the LC-1 output when the wideband isnt connected to the brain? I wired mine in yesterday but due to the awd nature of my car could not physically access the o2 sensors. I just reflashed back to a US mapping for my supercharger install and INPA says the rear 02 sensors are reporting a voltage (.44 at idle), but the signal wires aren't even attached to the sensors any more, they are attached to the LC-1.
But part of me also thinks that might just be the ECU improvising since it threw an INSTANT CEL as soon as I turned the key after flashing it.
ETA: Everything I know about everything is wrong. My ECU is running the latest US spec software. Catalytic converter detection shows ACTIV in INPA. The LC-1 lambda probe is disconnected from the LC-1 controller and I have not programmed the LC-1. The wires on the post-cat O2 sensors have been CUT and the LC-1 soldered-in on the engine-side of the harness. Only the heater wires remain connected to the sensors. The LC-1 calibration wire is curled-up in the ECU's box, connected to nothing.
That insta-SES light? It turned itself off.
Is everything I know about everything, and everything we all thought we knew about everything wrong?
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 09-12-2012, 08:34 AM   #276
johntrhodes81
On the LC-1 programming. Should the high impedance box be checked? It is by default.
Thanks,
John
Old 09-14-2012, 11:07 PM   #277
F1004fun
My Ride: '02 330Ci
You are seeing the base voltage from the DME, the O2 sensor "pulls" this voltage up or down depending on mixture. There is a longer answer that an electrical engineer could better provide, but that;s the short one.
Thanks,
Yes, this makes the signal go "high impedance on sensor warmup, and this is what the factory O2 sensors do.
Old 09-15-2012, 10:12 AM   #278
johntrhodes81
thanks,
John
Old 09-16-2012, 09:58 PM   #279
johntrhodes81
Has anyone, especially those driving both sensors from one analog output gotten a Comprehensive Component Emissions Monitor not ready?
Thanks,
Sent from my PC36100 using Bimmer App
John
Old 09-17-2012, 09:17 AM   #280
dpgrand
My Ride: 2005 330xi
All my monitors are "Ready" and I have passed emissions in RI.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
