Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 07-17-2014, 01:25 PM   #361
TigerTater
My Ride: 05 330i ZHP
Bump for response
TigerTater is offline   Reply With Quote
Old 07-17-2014, 04:46 PM   #362
TigerTater
Can anyone confirm this proposed diagram for wiring the LC2? The lc2 does not have the white/blue wires of the previous lc1, just a single black ground. Also I drew this with each sensor having it's own analog signal line as that was said to be most clear/accurate signal. Would I set both analog signals up the same way software wise? Click image for larger version
ID:	565734Click image for larger version
Old 07-25-2014, 04:39 AM   #363
dpgrand
My Ride: 2005 330xi
Originally Posted by TigerTater View Post
Bump for response
I would recommend resistors as they are far easier to replace. However, with the mount acting like a big heat sink in my setup, the resistors dont even get that hot so I don't anticipate having to replace them for quite some time.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 07-25-2014, 07:14 AM   #364
TigerTater
Thanks. What do you think of the diagram I have drawn? I think it's similar to everyone else's, but I'm using LC2 which is a little different wiring.
Old 07-31-2014, 07:50 PM   #365
330Cole
My Ride: 01' 330Ci
Is there anyone in the New England area that has had success with this? i could desperately use some help
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 07-31-2014, 10:13 PM   #366
TigerTater
I just successfully got all my monitors ready after installing my LC2!! Click image for larger version
Old 08-09-2014, 05:14 PM   #367
dpgrand
My Ride: 2005 330xi
So, my car is now throwing codes related to secondary O2 sensors now after many many miles.
I've checked the O2 fuse - it's fine
I've also done a free-air calibration.
My LC-1 is outputting .45V at all times, regardless of if I'm idle or decelerating.
The only thing I've done is change my valve cover gasket, so I wiggled and moved some of the O2 sensor wires.
Any ideas? Should I try the free-air calibration again?
Old 08-09-2014, 06:22 PM   #368
TigerTater
It should vary with throttle. Seeing as how it's constant I would assume either lc1 is dead, or your o2 sensor for lc1 crapped the bed? Maybe settings got defaulted back? Reconnect and ensure the ratios are right...would be my first guess and the re try o2 calibration
Old 08-28-2014, 03:19 PM   #369
dpgrand
My Ride: 2005 330xi
It turned out to be the O2 sensor of the LC1. The LC1 LED was indicating error #8 (defective sensor). I replaced the sensor and successfully passed MA inspection today.
Old 09-11-2014, 09:02 AM   #370
xHeiKe
My Ride: '02 BMW 325i Sedan
MA inspection is using OBD-II cable? plug and pass?
xHeiKe is offline   Reply With Quote
Old 09-11-2014, 09:05 AM   #371
dpgrand
My Ride: 2005 330xi
Yes. In MA, they plug into the OBD-II port and you need to pass the readiness monitors.
Old 09-12-2014, 12:28 AM   #372
daniel_f.
My Ride: 330iC
Anyone with a flasher willing to test a software solution?
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-13-2014, 05:09 PM   #373
Llink78
My Ride: 2002 330i
I dropped and broke the xp laptop i was using for all this stuff Im really hoping to find someone like yourself to be able to raise the rev limit and post 02 threshold of a EU file something tells me you might of found the file for O2's
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 09-14-2014, 07:51 AM   #374
daniel_f.
My Ride: 330iC
Just drop me a PM with what you need
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-23-2014, 02:58 PM   #375
TigerTater
keep getting post cat o2 sensor rich codes...p2097 and p2099. only happens when im driving long trips it seems at steady mph/revs with cruise set.
current settings are as follows: .700volts at 19:1 and .050volts at 20:1 on both analog 1 and analog 2
any advice on what to do to remedy this?
I have verified that the controller is on and working
Old 09-23-2014, 05:03 PM   #376
TigerTater
I think my values were too high. I was getting .740 volts post cats consistently...which is too high. I adjusted my curves and I'm now getting .620-.655 steady. Hope this clears my codes. Here's what I adjusted too : Click image for larger version
Old 09-23-2014, 09:11 PM   #377
dpgrand
My Ride: 2005 330xi
I think my values were too high. I was getting .740 volts post cats consistently...which is too high. I adjusted my curves and I'm now getting .620-.655 steady. Hope this clears my codes. Here's what I adjusted too : Attachment 574763
This is the original recommendation:
0.650V at 18:1
0.100V at 22:1
1/3 delay
Old 09-24-2014, 06:30 PM   #378
jamex
My Ride: 2005 325Ci
please post the results of this testing. I can't believe more people didn't jump all over this, but hopefully you got some PM's.
I'd hate to see a secret sauce fix like this remain private and unavailable. even knowing it DIDNT work is somewhat useful too.
jamex is offline   Reply With Quote
Old 09-24-2014, 11:38 PM   #379
daniel_f.
My Ride: 330iC
Well, its not a secret at all and there was no reply to my offer at all. Thats why i think no one is interested. Im running EU2 software, so i cant test it.
People seem to rather buy some expensive stuff to simulate instead of buying a flasher and being able to change all
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-25-2014, 09:10 PM   #380
jamex
My Ride: 2005 325Ci
are there any threads or resources where I can get caught up? I don't believe that there is no interest. I think it hasn't been spelled out in front of them like a tutorial. The wideband O2 method wasn't that popular until a member here posted up the walk through. If there's an easier alternative I'm sure people would jump all over it. I have no idea how much a flasher costs, what risks are associated with flashing, or any of the other legwork to get from a shopping list to a fully implemented solution. I'm betting I'm not the only one thats clueless too.
