Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#61 |
Hold on guys, you gotta know me a little. This is grassroots tuning here, I wish I had the resources and the time to actually tune a DME with a a laptop, but I don't. I do however have a knack for reverse engineering things, when you want the DME to do something for you go to it source of input. In this case I am making the mixture leaner because I am running a 4Bar fuel pressure regulator to get my open-loop AFR down to 13:1 (they were at 13.6:1 after I installed my Schrick cams). This caused my closed loop mixture to go rich and the DME would lean it out my fuel adaptations, so be letting the motor run a little richer and not see it the DME stopped pulling fuel out and let me adaptations mellow out a little. Does this make sense?
I am not talking a radical change here, and I don't recommend radical changes. I am running down the freeway in closed-loop at about 14.2:1 AFR when the desired AFR for emissions is 14.7:1. A little fact is that for N/A motor the arguable AFR for the most power is around 13:1 AFR. Does this lower fuel mileage? Yes, a little maybe 1 MPG. Did this improve throttle response and increases in power on the butt-dyno, yes. But you can change it by just plugging in the laptop and hitting the "Factory Default" button and the voltage curve goes back to reality. As for the post-cat O2 voltage curve, on the LM Programmer I use .650V from 8:1 up to 20:1AFR and the I run it down to .025V at 22:1AFR, but you need to make sure to go into the advanced menu and put the max 1/3 second delay on the post-cat O2 sensors signals. This will give you that lag time to show a good oxygen saturation in the catalytic converter and still give you the lean signal so the DME see's that everything is legit. This is exactly what I am trying to tell people about the simulators that just make the flat .650V signal, this might work on some simpler ECU's but not ours. Our DME needs to see a certain amount of lag time after you let off the gas pedal and go into fuel-cut upon deceleration to see the rear O2 sensor go lean. I have yet to see simulator that does this. Last edited by F1004fun; 02-19-2011 at 02:34 PM. |
#62 |
^ I wasn't trying to knock your approach. You definitely seem to know what you're doing and why you're doing it. I was merely trying to emphasize that this level of fiddling requires more expertise than the average DIY'er around here typically has - before someone does decide to get a little too radical.
#63 | |
Thanks, John |
#64 |
1 will be enough for no CEL
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
#65 |
He is using one LC-1 pre-cat to get his AFRs where he wants them, and one LC-1 post-cat to eliminate the cat efficiency CEL. So, one LC-1 can service both post-cat sensors.
Lars
2004 330i ZHP ESS TS2 ![]() |
#66 |
Well, close. In sticking with German wiring tradition, so one LC-1 is Bank1 pre-cat and post-cat and the other is Bank2 pre and post. BMW considers Cyl.1-3 as Bank1 and Cyl4-6 as Bank2. And yes I used to run one LC-1 as just my post-cat signal and it worked just fine.
#67 | |
Lars
#68 |
Yes, thats pretty much it, but you should tie all those grounds in with a ground wire that goes to the main ground lug behind to e-box, this will keep all the signals clean and properly referenced with the DME.
#69 |
thanks for your hardwork and information F1004fun im having the same issue on not be able to pass due to readiness codes not being set
i just have 1 question with the lc-1 will i still need my 02 simulator hooked up?(im running electric and anti-fouler method) and thanks lkstaack for the diagram it helped put it all together visually
#70 | |
Lars
2004 330i ZHP ESS TS2 ![]() Last edited by lkstaack; 05-29-2011 at 08:51 PM. |
#71 |
so you take out the secondary 02's completely and just use the wideband in 1 bung and plug the other?
#72 |
Is it possible to have the exact link to buy the O2 simulator?
http://www.o2simulator.com/index.php...products_id=10 Or this: http://www.o2simulator.com/index.php...&products_id=9 Could be the assembly diagram right? Simulators start in place of the downstream oxygen sensors ? I ask these questions because I'm going to mount my header next Friday |
#73 | |
The LC-1 will provide your ECU with the signals it wants to stay happy as long as you program it to do so (like F1004fun did). Remember, the post-cat sensors are not needed for the tune; its just there to ensure your cat is working properly. Edit: the LC-1 wideband isn't needed to defeat the cat CEL, but can be used downstream for a AFR gauge.
Lars
2004 330i ZHP ESS TS2 ![]() Last edited by lkstaack; 05-29-2011 at 08:52 PM. |
#74 | |
Lars
#75 |
Banned
its cheaper to take the light out behind the the check engine sign
#76 |
#77 |
Just Google "Innovate LC-1".
#78 |
Keep it clean
What is this "Google" that you speak of? Surely it's some new advancement in technology.
#79 |
Keep it clean
And you still wouldn't pass inspection in most states. Neat comment, though.
#80 |
I just picked one up from summit yesterday. They had it priced for $250 with the analog gauge.
