Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 06-02-2011, 09:59 AM   #81
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Holy crap:
http://www.streetrays.com/store/inde...oduct_id=33722
I bought the one w/o the gauge (wishing I had it) for $130ish.
Originally Posted by tinkwithanr View Post
I just picked one up from summit yesterday. They had it priced for $250 with the analog gauge.
Old 06-21-2011, 04:40 PM   #82
DarkJoker
My Ride: 01 330ci
i just did this recently(diy) and got a state inspection sticker w/o issue
all readiness monitors set
no electronic 02 sim
i am a believer again
now just to tinker with the afr's and do a dyno run
DarkJoker is offline   Reply With Quote
Old 06-21-2011, 04:58 PM   #83
aggieE46
Keep it clean
aggieE46's Avatar
Glad it worked out for you, man!
Are you using the values he gave on the first page?
Old 06-21-2011, 05:05 PM   #84
DarkJoker
My Ride: 01 330ci
that i did
thanks for pointing this thread out and thanks f1004fun for all the work you put in
Old 07-05-2011, 03:24 PM   #85
McSpeed
My Ride: 2005 ZHP TT Stg 1
Looks like I'll be joining the LC-1 club
  • Where are you guys stowing the resistors? They get real hot right? Is it possible/advisable to put them under the car rather than under the hood?
  • Any idea what the AWG's of these wires under the DME are?:
Originally Posted by F1004fun View Post
Once in the e-box lift the DME and the bracket that it's held into up and expose the chunk of red-white and brown wires underneath. Connect the sensor ground wire and the white and blue LC-1 ground wires to the splice of brown grounds under the DME, next connect the LC-1's red wire into the splice of red-white yellow dotted wires.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-05-2011, 03:27 PM   #86
dpgrand
My Ride: 2005 330xi
I have mine mounted in the drug bin, thermal pasted to a piece of aluminum. I also have an aluminum heatsink thermal pasted on them as well.
(This is overkill)
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 07-05-2011, 04:16 PM   #87
McSpeed
(This is overkill)
Sounds good to me - the cooler they are the longer they last afaik
Any pics?
Old 07-05-2011, 04:24 PM   #88
dpgrand
My Ride: 2005 330xi
Any pics?
No.... I've been meaning to take some good pics of what I've done and upload it this thread - it just hasn't happened.
Old 07-05-2011, 04:36 PM   #89
McSpeed
(This is overkill)
I'm thinking about these since they're built into heat sinks:
More expensive but one less thing to deal with during install...plus it says they're "make sure long time for your daily use"
Old 07-05-2011, 04:48 PM   #90
TxZHP04
My Ride: ESS TS2+ ZHP
I thought your tune took care of that?
Old 07-05-2011, 04:56 PM   #91
McSpeed
turns out w/ the TT tune on MS45.1 some monitors are disabled(?), but the tune basically prevents an SES light being triggered for them
Nick tried a few approaches to get them all "ready" but no luck...
Old 07-05-2011, 05:46 PM   #92
TxZHP04
Sounds like he ran into the same issue as Asbjorn did with the ESS header tune. Glad you've got the LC-1 as a fallback.
Old 07-06-2011, 06:51 AM   #93
McSpeed
Interesting. Did AA just decide "F-it, we're getting to the bottom of this?" or does their header tune only work within NA parameters?
Yeah! thanks again to F1004fun, PEI and also to dpgrand, johntrhodes and lkstaack for doing all this LC-1 trailblazing.
Old 07-06-2011, 07:58 AM   #94
TxZHP04
Don't know about AA. Does anyone with the MS45.1 DME actually have the AA header tune that actually runs it on the street and has to pass an inspection (without "tipping" the inspector)? I thought I heard that someone from Siemens had told Asbjorn that it wasn't possible to turn off the post cat O2s and have the monitors indicate "ready" on MS45.1 but I've always assumed that ESS was simply trying to stay on the EPA's good side.
Old 07-06-2011, 08:16 AM   #95
McSpeed
SpeedDemon, who has MS45.1 and Ceramic Coated Supersprint Replica Headers, implied success with these posts, spaced 4 months apart:
http://forum.e46fanatics.com/showthread.php?t=682253#3
http://forum.e46fanatics.com/showthread.php?t=713645#14
although he doesn't explicitly mention passing emissions...nor do I know how rigorous the testing is in Seattle...
Old 07-06-2011, 08:20 AM   #96
TxZHP04
Some places allow for a certain number of monitors to be in the "not ready" state.
Old 07-25-2011, 10:42 AM   #97
McSpeed
Update: Fwiw, Nick's approaches might've worked better if my connections were good. While installing the LC-1 I discovered that a couple of the 'Posi-Seal' connectors I used under the car had let go a bit - one was very loose. The 'Posi-Seal' connectors' sealing material appears to deform slightly with time (and/or heat?), lessening the crush force on the wire. It should be noted that all the normal 'Posi-Lock' connectors I used were still nice and tight.
http://www.posi-lock.com/napa.html
Old 07-26-2011, 10:04 PM   #98
DarkJoker
My Ride: 01 330ci
has anyone just adjusted afr's without logging or dyno tuning?
Old 08-15-2011, 06:02 PM   #99
McSpeed
I passed! All monitors set to ready on a TT turbo MS45.1 The evap was the last hold out and it finally seemed to be cleared by idling in gear from a cold start for a few minutes, then driving below 3K RPMs to a school parking lot, then idling in gear for a few more minutes. I used the above mentioned resistors and also posi lock connections throughout (so no soldering). Also used posi-taps to avoid any cutting/splicing. The LC-1 was configured just as shown by F1004fun, and wired just as in lkstaack's diagram earlier in the thread. The only confusing thing was Innovate's description for wiring LC-1's status LED.
Old 08-15-2011, 06:44 PM   #100
lkstaack
My Ride: 04 330iZHP, 05 325iT
I passed! All monitors set to ready on a TT turbo MS245.1 The evap was the last hold out and it finally seemed to be cleared by idling in gear from a cold start for a few minutes, then driving below 3K RPMs to a school parking lot, then idling in gear for a few more minutes. I used the above mentioned resistors and also posi lock connections throughout (so no soldering). Also used posi-taps to avoid any cutting/splicing. The LC-1 was configured just as shown by F1004fun, and wired just as in lkstaack's diagram earlier in the thread. The only confusing thing was Innovate's description for wiring LC-1's status LED.
Congratulations! Does your state have a visual inspection requirement? How did it pass with the air cleaner relocated?
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
