Old 10-17-2009, 03:28 PM   #1
RAFF112
My Ride: 325ci M3 cbr 600rr
Wiper motor blows fuse: NEED HELP
My wiper motor went out and now i replaced it. Afterwards it wouldn't turn on. i changed the relay and then i noticed it keeps blowing the 30amp fuse behind the dash. Every time. Also the motor came from a e46 M3 and i have a 325ci does that make a difference. I dont know what to do
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
Old 10-17-2009, 04:18 PM   #2
RAFF112
No one wants to help me
Old 10-17-2009, 05:58 PM   #3
//TRD power
My Ride: 3.0 | 200hp | 214trq
If it blew a fuse it must not be compatible. Try using a wiper motor for your model. Or look up the part number and see if they match first.
//TRD power is offline   Reply With Quote
Old 10-17-2009, 06:45 PM   #4
RAFF112
Yeah the part numbers match i checked it on real oem before ordering it.
Old 10-17-2009, 07:04 PM   #5
//TRD power
so did you replace the fuse again? and it blew? try using a slightly higher amp.
Old 10-17-2009, 07:09 PM   #6
RAFF112
It uses a 30 amp. I know this is stupid but tomorrow ill try a 50 amp fuse.
Old 10-18-2009, 10:00 PM   #7
Commander FAT
Network Analyst
My Ride: 2002 330Ci
DO NOT PUT IN A BIGGER FUSE. You have an electrical problem that needs to BE FIXED. Higher rated fuse creates the chance of wires melting and starting a fire. It's possible the motor is shorted out internally or is binding up causing excess current draw which blows the fuse.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 10-19-2009, 08:44 PM   #8
RAFF112
So i gues it definately is the motor.
Old 10-19-2009, 10:27 PM   #9
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
what is the fuse number?
B is offline   Reply With Quote
Old 10-19-2009, 11:49 PM   #10
BodyMan
My Ride: 2002 325i
You might try to remove it from the car and use a separate battery or jump box to test it and make sure the unit works.
And as said don't use a larger amp fuse, that's a fire waiting to happen.
BodyMan is offline   Reply With Quote
Old 10-21-2009, 04:46 PM   #11
RAFF112
Im getting another motor 2day. so thats 3 in one month.
Old 11-04-2009, 05:17 PM   #12
RAFF112
Now i changed the motor and the wipers still dont turn on. i evern changed the relay again.
Old 11-04-2009, 05:33 PM   #13
Chris C
My Ride: 2001 325Ci
+1 on not using a higher fuse. Bodyman is correct. That's just asking for trouble.
Do you recall what circumstances caused your motor to fail in the first place? Did you blow another fuse again with the latest motor?
Chris C is offline   Reply With Quote
Old 11-04-2009, 05:38 PM   #14
RAFF112
No i didnt blow a fuse this time. But the first motor failed from some one reinstalling the wiper arms wrong when i got my car painted.
Old 11-07-2009, 06:07 PM   #15
RAFF112
computer behind the glove box had to get reset. case closed
Old 11-07-2009, 10:52 PM   #16
BodyMan
My Ride: 2002 325i
Glad you got it worked out!
Old 01-20-2010, 05:39 PM   #17
Another BM
My Ride: 330ci
Where is the relay for the wiper motor...
i'm having the exact same problem on my 330.
My fuse is fine so its either the relay, the motor, or the wiper switch..
i hope its the relay, lol
Another BM is offline   Reply With Quote
Old 01-21-2010, 03:32 PM   #18
kkeddy
My Ride: 325i
how do i reset the computer im having the same problem
kkeddy.
03 325i
2010 Civic SI
2001 m3
kkeddy is offline   Reply With Quote
Old 01-21-2010, 03:42 PM   #19
QuoteWarz Insurance
Past Site Sponsor
My Ride: M3
You can reset the computer by unplugging the battery for 1 minute and then hooking it back up. There should clear it out.
QuoteWarz Insurance is offline   Reply With Quote
