Miscellaneous
Old 10-17-2009, 03:56 PM   #1
sbasketny93
My Ride: 2004 M3
Nikon N6006 SLR Camera
I found this in my mom's closet and she wants to get rid of it. I know nothing about cameras and have no use for it. I also have no clue what these are worth. All i know is that it is basically brand new.
heres is some info i found about the camera:
Type of camera: Integral-motor autofocus 35mm single-lens reflex
Picture format: 24 x 36mm (standard 35mm (135) film format)
Lens mount: Nikon F mount
Lens: Nikkor lenses having CPU contacts, AI-S-type Nikkor lenses*, AI-Nikkor lenses* and AI-modified Nikkor lenses* *With limitation. See notes below.
Focus modes: Autofocus, and manual focus with electronic rangefinder
Autofocus mode: Focus-Priority Single autofocus and Focus-Priority Continuous autofocus
Autofocus detection system: TTL phase detection system using Nikon Advanced AM200 autofocus module
Autofocus detection range: Approx. EV -1 to 19 (ISO 100)
Autofocus lock: Possible once a subject is in focus in Focus-Priority Single autofocus; in Focus-Priority Continuous autofocus, focus can be locked by using AE-L/AF-L lever when AF-L function is set
Electronic Rangefinder: Available in manual focus mode with an AF Nikkor and other AI-type Nikkor lenses with a maximum aperture of f/5.6 or faster
Exposure metering: Three types of exposure metering systems - Matrix Metering, Center-Weighted Metering and Spot Metering
Metering range: EV 0 to 19 (at ISO 100 with f/1.4 lens) for Matrix and Center-Weighted Metering; EV 4 to 19 (at ISO 100) for Spot Metering
Exposure meter: Activated by lightly pressing shutter release button; stays on for approx. 8 sec. after lifting finger from button
Exposure modes: Programmed Auto (PM, P), Shutter-Priority Auto (S), Aperture-Priority Auto (A) and Manual (M) modes
Programmed Auto exposure control: Both shutter speed and aperture are set automatically; Flexible Program in one EV step increments possible
Shutter-Priority Auto exposure control: Aperture automatically selected to match manually set shutter speed
Aperture-Priority Auto exposure control: Shutter speed automatically selected to match manually selected aperture
Manual exposure control: Both aperture and shutter speed are set manually
Exposure compensation: Possible using exposure compensation button within 5 EV range in 1/3 EV steps
Auto exposure lock: Available by sliding the AE lock lever while the meter is on
Auto exposure bracketing: 3 or 5 frames can be taken of the same subject using a variety of exposures (with compensation degree of 0.3, 0.7 or 1 EV between each frame)
Shutter: Electromagnetically controlled vertical-travel focal-plane shutter
Shutter release: Electromagnetic type
Shutter speeds: Lithium niobate oscillator-controlled speeds from 1/2000 to 30 sec.; stepless in Programmed auto and Aperture-Priority auto exposure modes; one EV steps in Shutter-Priority auto and Manual exposure modes; Electromagnetically controlled long exposure at B setting
Viewfinder: Fixed eyelevel pentaprism high-eyepoint type; 0.75X magnification with 50mm lens at infinity; 92% frame coverage
Eyepoint: Approx. 18mm
Eyepiece cover: Model DK-5 (provided) prevents stray light from entering viewfinder
Focusing screen: Fixed Nikon advanced B-type BriteView screen with central focus brackets for autofocus operation
Film speed range: ISO 25 to ISO 5000 for DX-coded film; ISO 6 to ISO 6400 for manual setting
Film speed setting: Auto for DX-coded films and manual setting available
Self-timer: Electronically controlled; timer duration can be selected between 2 and 30 sec. in one sec. increments; blinking LED indicates self-timer operation; two-shot self-timer is possible; can cancel at any time
Reflex mirror: Automatic, instant-return type
Flash sync control: Normal Sync, Slow Sync and Rear-Curtain Sync provided
Built-in TTL flash: Guide number: 43 (at ISO 100, 20C, ft.); angle of coverage: 28mm lens or longer; TTL auto flash including automatic balanced Fill-Flash is possible
Flash synchronization: In Programmed auto or Aperture-Priority auto, shutter operates 1/125 to 1/60 sec. (or 1/(focal length) in use at lens focal length less than 60mm) in normal sync or 1/125 to 30 sec. in Slow Sync; in Shutter-Priority auto or Manual exposure mode, shutter fires at speed set, and when set from 1/250 to 1/2000sec., shutter is automatically set to 1/125 sec.
Automatic Balanced Fill-Flash: Possible with built-in TTL flash or Nikon dedicated Speedlights such as SB-27, SB-26, SB-23, and SB-16B
Manual flash light output compensation: Can be controlled from +1EV to -3EV in 1/3 step increments
Flash ready-light: Without flash: Blinks when using flash is recommended (with scene brightness darker than EV10 at ISO 100 or scene brightness of EV10 or higher at ISO 100 where the center portion is darker than other areas by more than 1EV) With flash: Lights up when built-in TTL flash or Nikon dedicated Speedlight is ready to fire or blinks to warn of insufficient light for correct exposure
Accessory shoe: Standard ISO-type hot-shoe contact; ready-light contact, TTL flash contact, monitor contact
Film loading: Film automatically advances to first frame when shutter release button is depressed once
Film advance: In S (Single-frame) shooting mode, film automatically advances one frame when shutter is released: in CH (Continuous High) or CL (Continuous Low) shooting mode, shots are taken as long as shutter release button is depressed; in CH mode, shooting speed is approx. 2.0fps, and in CL, approx. 1.2fps
Frame counter: Additive type; counts back while film is rewinding
Film rewind: Automatically rewinds by sliding film rewind lever while pressing film rewind button; approx. 26 sec. per 36-exp. roll or 19 sec. per 24-exposure film roll; stops automatically when film is rewound
Camera back: Hinged back; unchangeable
Power source: 6V lithium battery pack (CR-P2/DL-223A or equivalent)
Checking battery power: Battery power is sufficient if shutter speed and aperture indications appear on the LCD panel and viewfinder by turning camera on or by lightly pressing shutter release button, and remain on for approx. 8 sec. after finger is removed from the button; battery power is insufficient if these indications turn off immediately after finger is removed from the button; if LCD blinks and shutter does not operate, batteries are exhausted or improperly loaded
Dimensions (W X H X D): 154.5 X 100 X 66.5mm or 6.1 X 4.0 X 2.6 in.
Weight: Approx. 650g or 23 oz. (without battery pack)
ID:	335410   Click image for larger version
ID:	335411   Click image for larger version
sbasketny93 is offline   Reply With Quote
Old 10-18-2009, 08:54 PM   #2
sbasketny93
My Ride: 2004 M3
bump!
Old 10-26-2009, 02:40 PM   #3
sbasketny93
My Ride: 2004 M3
Bump! Send me an offer
