Old 10-19-2009, 03:16 AM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Question Custom gears for non-M 6 sp
I've got a 330 6sp and just upgraded my diff to an 3.15 unit and I would like to eventually to with a 3.46 rear. I still do a lot of long distance highway cruising in my car so I would like to keep my RPMs down and MPG up.
The 6sp has a .85 6th gear. I was wondering if replacing the .85 6th gear with something taller is an option? (Maybe a .68 6th gear?)
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-25-2009, 05:36 PM   #2
Vinnie Vega
My Ride: 0032870Vette70Velle
This is actually a really good idea. The same low end as a 3.46 rear, with the gas mileage of a 3.07 in 6th gear. Id imagine you would have to find the same trans that's in another car with this taller 6th gear and have a real tranny guy swap over 6th. I highly doubt there's anyone actually making this gear, and its not really something id recommend doing your self. It might end up costing a lot more than its worth to have done.
Vinnie Vega is offline   Reply With Quote
Old 10-25-2009, 06:12 PM   #3
bigjae1976
bigjae1976's Avatar
This is probably not a cheap project but I think it would be worth it. Its as close as you can get to having your cake and eating it too. I'm pretty sure that you'd need to get some sort of custom gear made.
I am going to contact Metric Mechanic about this. I am open to suggestions on other potential rebuilders that could do this.
Old 10-25-2009, 10:06 PM   #4
Vinnie Vega
well its more like paying for the fuel your saving up front. Do the math and I'm sure you'd have to drive an INSANE amount of highway miles to recoup your initial investment. I mean if your trying to be green that's fine I guess but I just don't see it paying off. What I would do is find another trans that would drop in with a similar 6th gear but tighter 1-5, and use the 3.15. It would probably cost you the same if not less money.
