Old 10-19-2009, 11:45 AM   #1
95dime
My Ride: '99 323i
removing sedan rear bumper-my car is not same as diy?
i have a '99 323i sedan. my bumper does not have the holes on the bottom or the bolts by each wheel that the diy stickied in here shows. can anyone tell me where the bolts are that i need to remove to get this off? thanks.
-Derek
'99 323i - daily hotness
'95 s10 - 355 sbc~500hp, 5sp manual, 4:10 gears.
95dime is offline   Reply With Quote
Old 10-22-2009, 12:58 AM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
in the middle you have two T50 torx bolts.
remove the lower black trim and you will see them.
delmarco is offline   Reply With Quote
Old 10-22-2009, 01:08 AM   #3
mvrk10256
My Ride: E30 325i
i did it. ^^^^^^^^ is right. so the bottom strip pulls out (just start on one side and squish it in till it comes out), lay down and undo the two torx t50 bolts completely. The side clips will come off with no force really. so it will slide off the back. the bumper is light and easy to line up later on......
Old 10-22-2009, 01:18 AM   #4
mvrk10256
My Ride: E30 325i
http://forum.e46fanatics.com/showthr...901&highlight=
Old 10-22-2009, 11:54 PM   #5
delmarco
I love my fanatics.
glad to help out.
Old 10-24-2009, 04:35 PM   #6
95dime
My Ride: '99 323i
thanks guys. i found the bolts. one comes out but the other one was all buggered up and i cannot get it out. ill probably have to try and weld a nut onto the end of it to get it out.
-Derek
