Old 10-19-2009, 02:39 PM   #1
ecaicedo
My Ride: 2003 BMW 325i Sport
Limited Slip Differential On 2003 325i
Hello Fellow BMW Enthusiasts,
I have a 2003 325i (not iX), does anyone know how I can tell if I have a limited slip differential? I want to change my differential fluid and there are two Redline options: one with and one without limited slip differential.
Any help is appreciated, thanks!
Ed
ecaicedo is offline   Reply With Quote
Old 10-19-2009, 02:40 PM   #2
neil1138
You don't have an lsd
neil1138 is offline   Reply With Quote
Old 10-19-2009, 02:40 PM   #3
jeffro3000
My Ride: 2000 328i
you dont.
jeffro3000 is offline   Reply With Quote
Old 10-19-2009, 02:42 PM   #4
silv3rstr3ak
My Ride: 01 TiAg 330i
Yup, you don't... Mostly M3's...
-Rob
silv3rstr3ak is offline   Reply With Quote
Old 10-19-2009, 10:08 PM   #5
ecaicedo
Thanks for the feedback friends!
Old 10-19-2009, 10:10 PM   #6
Acarder
My Ride: 69' M3
Only M3s , on the E46 at least.
Acarder is offline   Reply With Quote
Old 10-19-2009, 10:55 PM   #7
nickr519
My Ride: ZX-10R, Ram 2500
BMW stopped putting lsd's in non-m cars after 1995 I believe.
nickr519 is offline   Reply With Quote
Old 10-19-2009, 11:21 PM   #8
Anthony@F1 Autohaüs
THE BRAKE GOD :D
My Ride: E46 330i
Send a message via AIM to Anthony@F1 Autohaüs
Which Stinks..
Anthony@F1 Autohaus
Anthony@F1 Autohaüs is offline   Reply With Quote
Old 10-19-2009, 11:24 PM   #9
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
Originally Posted by Anthony@F1 Autohaüs View Post
Which Stinks..
Anthony@F1 Autohaus
+00
i can't even have one lsd (at least as far as i know).
-Mike
“I’m sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If you’ve got even half a scrotum it’s not going to happen.”
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 10-20-2009, 10:29 AM   #10
Kubica
My Ride: 2003 325xi
Originally Posted by Messe46 View Post
+00
Yes, you can. You can put a quaiffe in the back and leave the front open in an xi.
Old 10-20-2009, 10:38 AM   #11
myksbmw
My Ride: BMW 2003 325i
You can find an M3 Diff and swap it in?
myksbmw is offline   Reply With Quote
Old 10-20-2009, 10:56 AM   #12
TxZHP04
My Ride: ESS TS2+ ZHP
Not in an xi, the front and rear diff ratios would no longer be properly matched. The M3 diff can be swapped into a non-xi but you have to swap a lot more than just the diff itself. There are also numerous aftermarket LSD options that will bolt right up.
