Old 10-19-2009, 07:35 PM   #1
hx288
My Ride: 2001 BMW 325I
car won't start
Hi all,
I have a 2001, 325i and it won't start this morning. I turned the key and there was no sound. All the lights were on as normal in the dash board. even the AC was still running. I tried to jump start but that didn't help. Please help!
hx288 is offline   Reply With Quote
Old 10-19-2009, 07:35 PM   #2
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
Dead battery
reynaldo is offline   Reply With Quote
Old 10-19-2009, 07:54 PM   #3
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
I would say that if you have lights on the dash and the a/c works. Then your battery is fine. But, your starter or alternator might be bad. If you can get the car to an Auto Zone, I think they can test that for free.
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 10-19-2009, 09:23 PM   #4
hx288
I tried to charge the battery with another car for 20 min but that didn't do any good. If I can't get it to autozone for testing, is there another way for me to figure out if it was the starter or alternator?
Old 10-19-2009, 10:07 PM   #5
sycE46
My Ride: 323ci
maybe a bad key? try your spare key. The chip died in my friend's key. The car won't start without it.
Also... check the voltage across your battery. it should read around 12v.
sycE46 is offline   Reply With Quote
Old 10-19-2009, 10:38 PM   #6
2003_325Xi
My Ride: E46 325Xi, MINI R53
I'll second the battery.
2003_325Xi is offline   Reply With Quote
Old 10-20-2009, 01:06 AM   #7
sycE46
My Ride: 323ci
If you try to jump start the car, make sure you use good jumper cables. Cheapo ones won't work.
Old 10-20-2009, 04:20 AM   #8
kenny89_e46
My Ride: 01 black e46 sedan
my car does the same thing but only happens everyonce in a while. but when it does it wont start but after a few more trys itll start up. and this will repeatly happen throughout the day. i know it is the starter. but it has not bothered me enough to fix it. and yes i checked and doubled checked my battery. voltage and charged it. had a previous alternater problem but thats fix and the only thing thats left is the starter.
kenny89_e46 is offline   Reply With Quote
Old 10-20-2009, 04:22 AM   #9
kenny89_e46
and im curious about the key thing??? can someone verify that? my battery is dead in my keyy too.
Old 10-20-2009, 12:06 PM   #10
hx288
I will try the spare key this evening after work. How do you check the voltage on the battery?
Old 10-20-2009, 12:26 PM   #11
sycE46
My Ride: 323ci
You need a voltmeter. Ask around... one of your friends might have one.
Old 10-20-2009, 12:49 PM   #12
hx288
Thanks SycE46. A friend of my has the voltmeter and I will check the battery after work. If it's less than 12 V, that means the battery is the problem right? I need to change the battery?
Old 10-20-2009, 04:45 PM   #13
sycE46
My Ride: 323ci
If the battery reads less than 12V, it's most likely the battery that is the issue. Replace the battery.
It could be the alternator that is dying. If you can get the car jump started. and the alternator isn't putting out ~14volts while the car is on. Your alternator could be the problem. if you unplug the battery while the car is on, the car should still be able to run without the battery connected. Alternator should be able to provide enough power to keep the car running without the battery.
When jump starting the car. Thin gauge jumper cables won't work (10-12 gauge). They won't be able to provide enough current. Get a good set of 4-8 gauge cables.
If the car has problems starting (but the battery is good), it could be the starter.
If all the above are okay (Battery / alternator / Starter), might be the key.
Old 10-20-2009, 10:54 PM   #14
hx288
Thanks everyone for your responses. My wife tried the spare key and the car started with no problem. So, I am not sure what is wrong with my other key. It still lock and unlock doors but would not start the car. Can it be fixed?
Old 10-21-2009, 03:24 AM   #15
sycE46
My Ride: 323ci
Not that I know of. My friend had to buy a new key. There's something wrong with the anti-theft chip. it prevents the car from starting. If you put in the spare key for a second. Then switch it to bad key, the car should start.
Old 10-21-2009, 12:14 PM   #16
hx288
SycE46, thank you very much for your help. You have saved me alot of time and money. I was told it was the starter that need to be replaces and I got a quote for $685.00. I was glad that it was just the key.
I did a search and did not find much information for the key issue.
Old 10-21-2009, 01:59 PM   #17
sycE46
My Ride: 323ci
I don't think it's a common issue, but something people should be aware of. My friend spent several hundred towing his car around. Had 2 mechanics look at his car, before they discovered it was a bad key.
Also.. I rarely hear of the starters going bad on the E46.
