How best to get E46 onto jack stands? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-20-2009, 10:04 AM   #21
Whammy
My Ride: ZHP
Originally Posted by LABMW13 View Post
jack on the rubber and mount the stands on the frame rails, this may help:
(a pic i just took)
http://www.bavauto.com/newsletter/20...ter.pdf#page=4
Interesting you use the jack stands on these points. I've accidently bent one of the rails with my floor jack when forgetting to use a piece of wood between the jack and the rail.
Originally Posted by SHOF View Post
I took it as only dont use the rear OEM jack points. I don't know what the difference between red and green would be as long as it doesnt have an X through it.
I've used the rear side mounts without issue.
Does anyone else have ideas between the red and green points on the picture above?
Originally Posted by havnfun328 View Post
Be sure to jake the rear from the subframe, not the differential.
Agreed. Do not touch the differential itself. I though have used the differential carrier to raise the car and have not had a problem. Jack stands were placed underneath the rear side jack mounts.
Whammy is offline   Reply With Quote
Old 04-28-2013, 04:14 PM   #22
Dave1027
My Ride: '06 IR zhp coupe
Here you go
Why does the diagram say not to use the rear jack points because they will bend?
Old 06-13-2013, 11:43 AM   #23
halo0
My Ride: '02 330i 5mt
I assume that is the underside of an M3? My car looks nothing like that.
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 06-13-2013, 11:28 PM   #24
BelindaP
My Ride: BMW
Good forum
I found this forum very useful and have bookmarked it for future reference.
Web Developer NSWand Business Catalyst Developers pride themselves on high quality service and support.
BelindaP is offline   Reply With Quote
Old 09-07-2013, 10:41 PM   #25
Stinger9
My Ride: '04 330Ci
You are exactly correct. M3 has a very convenient center jack point on the front that we non-M's would love to have. We do not have a center jack point on the front of our cars.
EDIT: Correction. M3 and Xi e46's have center jacking point on the front. Others lack this.
Old 09-09-2013, 02:19 PM   #26
Hogan773
My Ride: 2002 325xi
I do actually....(XI)......
Hogan773 is offline   Reply With Quote
Old 09-09-2013, 09:48 PM   #27
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Our 2000 328i has one also, on the tubular reinforcement.
ddaniel1 is offline   Reply With Quote
Old 09-09-2013, 09:59 PM   #28
Stinger9
My Ride: '04 330Ci
Yes, I know the early e46's have a tubular reinforcement. Is it really rock solid enough to take the weight of the car without deforming?
Old 09-09-2013, 10:03 PM   #29
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Yes, it is quite strong, I have been lifting the whole front end with it for several years, no sign of collapse whatsoever. In the center of it is one of the bolts that go into the subframe.
Old 09-09-2013, 10:15 PM   #30
Stinger9
My Ride: '04 330Ci
Wish I had that. Why couldn't BMW put something like that into the later model reinforcement plate!
Old 09-09-2013, 11:38 PM   #31
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
A pretty bogus omission on their part. It was probably quite an argument around the design table, the DIY supporting engineers probably got out voted.
Old 09-11-2013, 11:09 AM   #32
frongm
My Ride: 2002 330Ci
Put your jack on one of the rear jack pads and crank her up. this will lift the whole side of the car, front as well.. Jack it high enough to put a stand under the front pad. lower.. go to the other side rear and jack her up again. this will raise the opposite side of the car and allow you to put a stand on the front rubber jack point... lower. the front of the car is now on stands on the rubber jack points.. now jack the rear of the car from the center cross member near the diff.. place stands on both rear rubber pads.. done.. i have done this way too many times
frongm is offline   Reply With Quote
Old 09-11-2013, 11:44 AM   #33
PapiOcho
My Ride: CRV
Re: How best to get E46 onto jack stands?
LOL because BMW intended for us to bring the car to the dealer for EVERYTHING. Sneaky sneaky using a lift!
PapiOcho is offline   Reply With Quote
Old 09-11-2013, 12:57 PM   #34
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Is this the spot (red square) you're referring to? This is the front underside of a 323i.
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 09-11-2013, 10:51 PM   #35
Stinger9
My Ride: '04 330Ci
Sure looks like it would take the stress right to the subframe, which would do the job.
Bad part of a common e46 is the Al reinforcement plate has to crush before it comes into contact with the subframe. I have crushed mine and use it to lift. It does work, but pains me everytime I use it to think that the car has a huge blemish because of design stupidity.
Old 09-11-2013, 11:37 PM   #36
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Yes, that is what I am referring to.
Old 10-22-2013, 12:12 PM   #37
trj
My Ride: 325Ci
Bumping this thread.
How the hell do you get the rear of the car on the jack stands without using U bracket on the differential?
For the fronts, I drive on the ramps and lift the car from the rear jacking points and put the stands on the front points. Can I drive the rear wheels on the ramps and lift the car high enough from the front jacking points, to put the rears on the stands?
I always rented the lift, to do anything on the rear suspension. But I want to do the rear ball joints ASAP without renting a lift.
I dont have a long handle jack, hence I am not very comfortable going under the car and jacking up from the rear U bracket. May be I will just buy a pipe and add(weld) it to the short pipe on the jack.
Issue is: I live in an apartment and I dont have space to store full size jacks and tools. Hence I opted for a smaller one.
Old 10-22-2013, 07:53 PM   #38
Stinger9
My Ride: '04 330Ci
Not the solution to your query apparently, but I have no problem reaching the rear U bracket with a cheap $29 jack that I bought. Maybe have to drive the car up on 2X8's to start with.
Old 10-22-2013, 11:22 PM   #39
trj
My Ride: 325Ci
I think I will try your suggestion. Drive rear wheels on the 3 2x8s stacked as ramp(that's what I use for the front) and jack up at the u joint.
Last time I tried to raise the Car on the u joint, my hand was under the bumper(short handle on the jack), so I don't feel comfortable. May be driving the rear wheels on the home made ramps would give me more room to maneuver the jack.
Old 10-23-2013, 03:26 PM   #40
Stinger9
My Ride: '04 330Ci
Yes, my car also goes up the ramps fine with the rears. I have a set of the rubber ramps.
