Old 10-21-2009, 03:40 AM   #1
sbonse
My Ride: 330ci
Alpina air box
Im wondering can a alpina performance airbox be fitted onto a 330ci. If so do i need to change anything etc. what benefits will i get from doing this
sbonse is offline   Reply With Quote
Old 10-21-2009, 02:45 PM   #2
Iceman00
Banned User
My Ride: E90 6MT
It's the stock box with a tube to draw older air from the bumper right? Should gain power, and I can't imagine it's hard to fit. I'd just get a CAI and be done with it...
Old 10-21-2009, 03:16 PM   #3
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
where can you get that airbox?
Devious1 is offline   Reply With Quote
Old 10-21-2009, 03:21 PM   #4
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
hard to say; the Alpina engine has a completely different intake than the 330
firefirefire90 is offline   Reply With Quote
Old 10-23-2009, 12:00 AM   #5
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
A good combo though would be the bottom part of the Alpina airbox with a Dinan Intake.
SpeedDemon is offline   Reply With Quote
Old 10-23-2009, 12:06 AM   #6
AlpineCI
My Ride: is paint code 300!
^ very clean mod list. i like
how much of a difference is the handling over stock? i mean the stock is pretty tight, but yours must be tight like a tiger
Alpine White 2004 BMW 330CI ZHP
-stock for now-
-_-
AlpineCI is offline   Reply With Quote
Old 10-23-2009, 12:15 AM   #7
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
if that the case, isn't the Dinan air intake box just as the same?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-23-2009, 02:28 AM   #8
SpeedDemon
The Dinan airbox just replaces the top part of the box.
Dinan normally asks you to cut a hole in both the bottom of the box and in the brake duct and then run tubing between the two. It's a crappy solution to the problem of getting cold air into the bottom of the air box.
The better solution is using the smooth tube like Alpina's box/tube that goes to the middle of the opening on the front bumper. Alpina's solution isn't just simpler, it also doesn't mess with airflow in the brake duct, it has smoother tube for better airflow, and it would be much easier to install.
Old 10-23-2009, 02:56 PM   #9
Bimmer Dude Xi
I know the whole installation procedure. I done it myself. I actually moved the tube from the brake duct to the bottom of the belly pan under the left fog light.
