Old 10-22-2009, 12:45 PM   #1
cbechtle
My Ride: 330 cic
Pulling to right...ideas?
I have a 04 330cic...the car has about 79,000 miles on it and about a year ago, a rough sound started in the front end. It only appeared < 20 mph and was not affected by braking. The car pulled a little to the right so I thought it was an alignment problem.
However I decided to do some maintenance to see if the problem would correct itself. So I had the following services performed...
- New brakes all around (Turner Brake kit)
- New front wheel bearing assemblies (again Turner) at the suggestion of the mechanic because he heard the grinding.
- 4 wheel alignment
Problem is still there...Any ideas?
cbechtle is offline   Reply With Quote
Old 10-22-2009, 03:52 PM   #2
havnfun328
My Ride: '99 328i, '03 M5
Rotate your tires.
If the pull changes then that's your problem.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 10-22-2009, 03:58 PM   #3
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
check your tires/rotation or u have a bent wheel...as I do
howie is offline   Reply With Quote
Old 10-23-2009, 07:02 AM   #4
cbechtle
My Ride: 330 cic
Thanks for the tire idea...unfortunately, sport package eliminates rotating option and the tires are relatively new. I guess I could swap left and right temporarily to see what happens....
Old 10-23-2009, 10:56 AM   #5
hummer
My Ride: 2001 330CI
At 79K your control arms and bushings are prime suspects.
Old 10-23-2009, 11:00 AM   #6
Chris-TK
My Ride: Mk VI GTI
Check your tie rods as well.
K.
Chris-TK is offline   Reply With Quote
Old 10-23-2009, 11:04 AM   #7
howie
got any fat chicks ridin with u when this happens?
Old 10-23-2009, 12:14 PM   #8
cbechtle
My Ride: 330 cic
typically, only my fat a**.... The car sits 6 days a week. It was a European delivery car that has been retired to the plush life of weekend/emergency duty. I'm guessing I need to take it in....Thanks all for the ideas...
Old 10-24-2009, 10:34 AM   #9
hummer
My Ride: 2001 330CI
Love those "fat bottomed girls"
Old 10-24-2009, 11:10 AM   #10
frogg320
My Ride: 2000 323i
Test it on the wrong side of the street, just to make sure. You could be paying attention more than usual, and most roads are sloped.
frogg320 is offline   Reply With Quote
Old 10-24-2009, 11:19 AM   #11
dauble2k5
My Ride: N55 E92
I'd say check tire pressure; I noticed mine was pulling to the left like none other, turns out the front left tire was low on air. Fixed the problem!
dauble2k5 is offline   Reply With Quote
Old 10-25-2009, 09:23 AM   #12
ALSHUBCAPS.COM
WHEEL GUY
My Ride: TAA II
switch tires from right to left, you may have a radial pull
ALSHUBCAPS.COM is offline   Reply With Quote
Old 10-28-2009, 12:59 PM   #13
cbechtle
My Ride: 330 cic
Took it to the dealer today, they said....
- The Turner pads are causing the noise....I don't believe it.
- Burned through a set of rears, bought new ones from Discount Tire. Typically good results from DT but they rotated the tires..there are fronts on the back and backs on the front...thus the pulling.
I'll end up pulling my hair out over this....they wanted $650+ for new pads and sensors. The Turner kit is only 6 mos old.
Whatever...
Old 10-28-2009, 01:08 PM   #14
Chris-TK
My Ride: Mk VI GTI
Whatever...
Pads can cause squealing if the pad is coming into too much contact with the rotor as a result of a sticking caliper or burrs that have developed on the edge of the pad.
K.
Old 10-29-2009, 01:10 AM   #15
DSpencer18
My Ride: 2005 BMW 330ci (ZHP)
Send a message via AIM to DSpencer18
my front control arm bushings wore out...it was doing it to me.
  • Has: - BSW d210 Subs/Amp - iSimple Ipod Integration - Smoked Side Markers - Smoked Reflectors - LED White Interior Lights - Hoen Xenonmatch Fogs - Hardwired Valentine V1 Radar Detector - AVT Ram Air Scoop - BMW Performance Intake - BMW Performance Short Shifter Kit -
    - Lambda Chi Alpha Zeta Phi 1067 and E46Fanatics.com stickers. -
  • DSpencer18 is offline   Reply With Quote
    Old 10-29-2009, 07:27 AM   #16
    Bimmer Dude Xi
    My Ride: 03 325XI 07 ZX-6R
    Send a message via AIM to Bimmer Dude Xi
    possibly its a brake pull like mines doing
    |Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
    |BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
    Bimmer Dude Xi is offline   Reply With Quote
    Old 11-05-2009, 12:55 PM   #17
    cbechtle
    My Ride: 330 cic
    Issue solved.....
    It was screwed up wheel stagger...took it back to Discount tire...they mistakenly put rear tires all around and put one of the rear wheels on the left front...
    I'm an idiot for not checking their work...
    I had the wheels and tires put to the proper places and wouldn't you know it, the problem has gone away. I need to get another alignment, but the sound is gone and all seems better in the world...
    Thanks for all the suggestions, especially the bushings. I'll be replacing them next.
    Old 11-05-2009, 01:45 PM   #18
    Chris-TK
    My Ride: Mk VI GTI
    Glad it was an easy fix.
    K.
    Old 11-05-2009, 01:54 PM   #19
    Philbert
    My Ride: 02M3|80 280ZX|87Yota
    are they going to pay for the alignment? they should - dumb asses.
    I had Big O install a 4" lift kit on my truck with new wheels and tires....the front was really feeling all the bumps afterward - even at 2 MPH in a parking lot! Turns out they forgot to adjust the tension rods on the front suspension - the front control arms were FLUSH against the frame, so the frame was absorbing everything on the road and there was not suspension travel. They fixed it, and aligned it free. I felt like a dumbass for taking so long to figure that out.
    Glad it was an easy fix!
    02 M3 Vert | 87 4Runner | 80 280ZX
    Dinan S. | Clears | DiCE | OEM Alarm Retrofit | ACS Rep. Peds | DDEs
    My Valentine 1 Hardwire | Remote Display Gauge Cluster Mod
    Considering selling 2002 M3 Convertible (~38,000 miles) this year (don't drive it enough...). If seriously interested, PM me. SF Bay area.
    Philbert is offline   Reply With Quote
