Old 10-26-2009, 11:38 AM   #1
zoidberg
My Ride: 02 325ci.
Unhappy Urgent. EML/BRAKE (yellow) faults.
Ok so on the way to my buddies house two lights in the gauge cluster appear. EML and BRAKE (yellow). Immediately i lose power and car drives rough. I pull over and check the brakes for excessive heat and look under the hood for anything noticable. Nothing. So i turn the car off and turn it back on. The lights go away and normal car function is returned.
The on the way back from my buddies it happens agian. I turn the car off and on agian. Then right before i get to my house it happens one more time.
I was reading a bunch of threads with eml problems and everyone says its either a bad throttle body or ICV needs to be clean or some kind of computer error.
I cleaned my ICV about a year ago, but never my throttle body. And if that is the case why does a BRAKE (yellow) light appear.
Can anyone enlightnen me because I have a meeting tommorrow and I need to fix it tonight.
zoidberg is offline   Reply With Quote
Old 10-26-2009, 02:13 PM   #2
zoidberg
My Ride: 02 325ci.
I also forgot to mention that on the third time it happened my CHECK ENGINE LIGHT came on and stays on even if i turn the car on and off.
Old 10-27-2009, 09:20 PM   #3
zoidberg
My Ride: 02 325ci.
Talking
Well, I sprayed my MAF sensor with some CRC MAF cleaner. Everything works fine now.
Funny how a mass air sensor can indicate a brake failure.
Only in a BMW
Old 10-28-2009, 02:38 AM   #4
gsbmw
My Ride: 2000 323i
Thanks for updating us. I may have a related problem, which I posted about 8-9 hrs ago (thread title starts with "SES EML ABS..."). I'll probably try cleaning the MAF sensor to see if it prevents a repeat of the EML/ABS/lost power symptoms (I don't want to lose so much power in traffic again!), although I didn't get a MAF sensor fault code. Please chime in on my thread if you think our problems are related (or even if you don't).
gsbmw is offline   Reply With Quote
