Old 10-26-2009, 02:50 PM   #1
DILLA
My Ride: 330i ZHP/VW Jetta
Cam Question
I was looking around at cams online the other day and I came across this set from Technik Engineering: http://www.technikpower.com/site/pro...5%26sort_by%3D
As you can see there is a note at the bottom, "These are forced induction camshafts, not to be used with natural aspiration."
So my question is, why can't these be used with natural aspiration? Sorry if this is a mundane question, but I figured I'd ask.
LRx
DILLA is offline   Reply With Quote
Old 10-26-2009, 03:31 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
They can be, but they're designed for FI. Different lift/duration combinations are better for FI vs. NA.
Old 10-27-2009, 03:42 PM   #3
DILLA
Ah I gotcha. So having these cams on a NA motors would just be overkill?
LRx
Old 10-27-2009, 03:47 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
Not overkill, just not optimal.
Also, Technik isn't really doing anything anymore. Consider Schrick or ZHP cams.
Old 10-27-2009, 04:17 PM   #5
DILLA
Ok, thanks man!
LRx
