Old 10-30-2009, 07:35 AM   #1
Stan 24v
My Ride: F21 M135i
Question E46 330ci - What to change, bearing or hub?
I have just been looking at price for a new bearing as my rear drivers needs replacing, and they come in around 32 each. A hub is around 50 each.
Quaestion is, due to the labour involved would it be easier to change the hub or bearing? Discuss
Stan 24v is offline   Reply With Quote
Old 10-30-2009, 10:15 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Here's a link to a DIY
http://forum.e46fanatics.com/showthread.php?t=663391
If the hub includes the bearing (I don't think it does) then 18euro might be worth the trouble saved.
Personally, I'm planning to replace the bearings and the hubs when my rear bearings go.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-31-2009, 03:39 PM   #3
mrshelley
My Ride: 2004 330i
If you are looking for less work, then buy the hub (it's actually called the drive flange). That way, you don't have to remove the outer race on the drive flange. unless your bearing is really really bad, the drive flange is probably OK. The 330 has the same rear bearing as an M3 and it's a pretty heavy duty unit as compared to the 2wd 323/325/328. If it was mine, I'd just change the bearing.
