Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 4.81 average. Display Modes
Old 10-31-2009, 10:29 AM   #1
hus23
My Ride: 2003 325i
P0174 P0171 codes, system too lean bank 1, bank 2
I have an 03 325i. I am getting P0174 and P0171 codes. I took it to an independent shop, who erased the codes, and suggested that it may be an O2 sensor problem. Before I hit a 100 miles, the codes came back.
I've seen several theories as to why these codes happen, relating to the MAF sensor, or the intake/vacuum hoses. Is there an easy (hopefully inexpensive) definitive fix? The car runs fine except for the engine light keep coming back on.
hus23 is offline   Reply With Quote
Old 10-31-2009, 10:38 AM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
check your lower intake boot elbow. most common problem.
then check oil separator lines
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 10-31-2009, 11:05 AM   #3
Hinman
My Ride: 2002 330ci
check your MAF, that was my problem.
Hinman is offline   Reply With Quote
Old 10-31-2009, 01:24 PM   #4
xe460
My Ride: 02 325i auto
I got those codes a while back and it turned out to be my fuel pump was failing and not enough fuel delivering to the engine. I tried to fix other things but finally pump died after two weeks and it was really the final culprit.
xe460 is offline   Reply With Quote
Old 10-31-2009, 01:27 PM   #5
BMW_Matt
My Ride: 135
Lol ironic I have the same code along with p0313. I'm gonna follow drew's advice and clean my MAF. Lemme know if you get it fixed and what it was.
BMW_Matt is offline   Reply With Quote
Old 11-03-2009, 03:38 PM   #6
hus23
My Ride: 2003 325i
Thanks!
I took it down to my buddy's place, and after a lot of searching, we found a small pin hole in the intake boot. It took a while since there are a lot of ribs around it, but there was a slice with a small hole in the middle there. We put some silicon on it, and cleared the codes. So far they haven't come back.
Thanks everyone.
Old 01-26-2010, 06:36 PM   #7
hus23
My Ride: 2003 325i
A quick update: After a few hundred miles, the codes come back. I ended up buying both intake tubes. Part #'s 13-54-1-435-627, and 13-54-705-209 ($35 total). Both of the old tubes had numerous cracks in them, and so far the codes haven't came back.
Old 01-04-2012, 04:08 PM   #8
ima_UNC_fan
My Ride: 2003 325i Sedan
+1 for hole in vac hose...just fixed mine.
ima_UNC_fan is offline   Reply With Quote
