Old 10-31-2009, 02:55 PM   #1
Pharaoh2716
My Ride: 2001 BMW 330CiC
Borla Exhaust Question?
I have a borla cat back on my 2001 bmw 330ci, and I like the sound, but can I take out a resonator to make it louder? And If I do take out the resonator, will it be the same exhaust note as right now, only louder? Thanks you guys are the best!!
Pharaoh2716 is offline   Reply With Quote
Old 10-31-2009, 04:03 PM   #2
Acarder
My Ride: 69' M3
The note will change, resonators cancel out certain frequencies of sound so over the powerband you'll probably have a deeper idle and raspy sound at higher speed. I don't think you'll make it any louder. You'd need to change other parts of the exhaust system - you could consider adding headers to your car, that would make it louder while keeping relatively the same note.
Acarder is offline   Reply With Quote
Old 10-31-2009, 04:31 PM   #3
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
actually there's a good chance you will get louder, deeper. well at least it worked for me. I only removed the smaller of the two and I definitely recommend trying that first. no rasp what so ever.
remus - 1 res =
Anub!s is offline   Reply With Quote
Old 10-31-2009, 04:35 PM   #4
Pharaoh2716
How much did it cost you? Also If I install the Dinan High Flow Intake System will it make any difference in the exhaust note?
Old 10-31-2009, 04:53 PM   #5
Anub!s
i think it was like 30 bucks way back then.
intake will give you a bit more sound.
Old 10-31-2009, 05:03 PM   #6
Pharaoh2716
sound in the engine note or the exhaust note?
Old 10-31-2009, 08:11 PM   #7
Pharaoh2716
please advise!
Old 10-31-2009, 08:20 PM   #8
Acarder
My Ride: 69' M3
Engine noise, not exhaust note. It just replaces the stock airbox which muffles the intake sound.
Old 10-31-2009, 09:56 PM   #9
Anub!s
Originally Posted by Pharaoh2716 View Post
please advise!
sorry, engine noise.
Remove a resonator. Just hang on to it just in case you want to put it back later.
2001 bmw 330ci, 330ci, borla, exhaust, resonators
