Old 11-01-2009, 07:17 PM   #1
M3TA5IN
My Ride: 06 e90 - e36 M3
Diff question? Overall performance questions
Ive been searching the forum for information on upgrading the performance of a 330i. I am currently searching for exactly what I want, I'm very particular so its taking me some time...
Anyway, I come from the jeep world so I am very familiar with swapping gears, axles, lockers etc etc. I see that a lot of you guys swap out your "whole" diff? and its an expensive upgrade?
I am assuming you are just taking the whole casing and swapping it for one with higher gear ratio. How exactly does the diff work on a bmw? What the cost of just swapping a diff? Its nothing to have 5k to 10k wrapped up in a jeep axle.
Also I am interested in looking into SCCA racing stuff, any advice on setting up a car for that would be helpful. Nothing serious at first, just want to get into it.
Would a 330i not be ideal for track opposed to a 330ci?
Thanks in advance.
M3TA5IN is offline   Reply With Quote
Old 11-02-2009, 02:26 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Just just swap the whole unit - case, gears, etc.
If you want to race, then you will want to get an LSD which costs about $3000 depending on your final drive ratio. I think diffsonline just dropped their prices. I would add a finned diff cover. Looks cool and is functional.
Its pretty straight forward swap in a new diff.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-02-2009, 11:19 AM   #3
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
^werd. LSD units range from ~$1200 for the cheaper quaife and kaaz units up to $3kish for the better units. If you just want to change the ratio, look for a diff from an auto e46 (which would get you 3.38, 3.46, or 3.64 depending on which car it came out of).
The sedan is arguably stiffer than the coupe. In any case, it's just as good for the track as the coupe is.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 11-02-2009, 12:44 PM   #4
M3TA5IN
Thanks for the info guys.
Ideally the higher ratio well give you better accleration, correct?
In jeeps we generally go higher to compensate for bigger tires, better up hill pull. I have 4.56s in my jeep
Old 11-03-2009, 06:35 PM   #5
bigjae1976
bigjae1976's Avatar
For the most part, yes. But go with too short a ratio and you'll be constantly shifting.
Old 11-03-2009, 07:24 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Look around for a 3.46, that's about the highest we can comfortably swap.
Old 11-04-2009, 01:42 PM   #7
M3TA5IN
Now what about axles? Is it common to swap shafts in a bmw? For like stronger shafts like on a track or something? Im really trying to understand a bmw driveline so I can relate it to what I know with working jeeps and get an understanding
Old 11-04-2009, 01:46 PM   #8
Activ3
There are no aftermarket half shafts that I know about for our cars, and you really won't need them anyways.
If you plan on tracking the car, it's a must that you have the rear floor where the subframe mounts reinforced. Turner Motorsports and HPF both sell reinforcement kits for this. You might also want to change your guibo out for an M3 guibo.
Old 11-04-2009, 01:52 PM   #9
M3TA5IN
What is guibo?
Old 11-04-2009, 02:03 PM   #10
TxZHP04
My Ride: ESS TS2+ ZHP
What is guibo?
Also known as the flex-disc, it's a rubber disc that connects the drive shaft to the transmission output.
Old 11-04-2009, 03:25 PM   #11
M3TA5IN
interesting, kinda like a yoke? or a CTM joint? and its made out of rubber?!?
do you have a picture of this?
Old 11-04-2009, 03:50 PM   #12
TxZHP04
http://forum.e46fanatics.com/showthread.php?t=714925
Old 11-04-2009, 04:06 PM   #13
M3TA5IN
Thank you very much
Old 11-04-2009, 06:59 PM   #14
bigjae1976
bigjae1976's Avatar
http://www.m3post.com/forums/showpos...10&postcount=7
I really don't know if this happens a lot but at least the video is entertaining.
