Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 11-04-2009, 02:32 PM   #21
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Bmw m3 gts
Officially announced today as the BMW M3 GTS:
Click here for the HD version.
SpeedDemon is offline   Reply With Quote
Old 11-04-2009, 02:51 PM   #22
uninc4709
My Ride: 2002 BMW 325i 5spd
uninc4709 is offline   Reply With Quote
Old 11-04-2009, 04:32 PM   #23
Skazzy
My Ride: X Wing
BMW M3 GTS. Pure M genes.[/COLOR] (+Interview with Dr. Kay Segler. https://www.m-power.com/_open/b/edit...d=2021&lang=en)
5. Nov. 09
Even when you see it from a distance, you are instantly electrified. As a BMW M enthusiast, every step you take towards the orange painted concept vehicle of the BMW M3 GTS with its numerous matt black applications raises your adrenaline level a little more.
Exclusive 19-inch wheels with ample 255/35 tyres at the front and 285/30 at the rear catch your eye.
All this is certainly nice looking and sensible, but what you glimpse through the spokes of the aluminium wheel rims is even more exciting: a generously sized fixed caliper brake system with six pistons at the front and four at the rear.
The wheels almost fill out the wheel arches, but if you look closely you discover the next highlight. Yellow springs with a small M logo provide the crucial clue: a threaded suspension, adjustable in compression and rebound. "The rear axle support is bolted in place," adds the responsible engineer.
The expert will also spot the adjustable front splitter and rear wing. One thing is clear: this car is serious stuff. Not only can a high level of downforce be generated but it also precisely adjustable at front and rear. Fast bends can look forward to welcoming the BMW M3 GTS - but they won't get to see it for long.
"The serial production BMW M3 is already weight-optimised with a whole range of measures reserved for the BMW M3 CSL in the last model - the striking carbon lightweight roof, for example."
So the engineers had to get back to work again to come up with more. Light body-contoured seats are a must.
A cluster of lightweight construction measures such as optimisation of the insulation, the use of lightweight parts in the interior, the use of Macrolon for the car's windows in the back, the lack of air conditioning, navigation and radio and the entire rear seat also gets the scales the down.
And the new titanium rear silencer not only looks great and contributes to the thrilling sound of the BMW M3 GTS, it is also much lighter than its serial production counterpart.
Indispensable for safety reasons: the lightweight construction body has been prepared for installation of the 6-point seatbelt included for use on the race track. There are also mounts for the roll-over protective structure bolted on from the B column. A fire extinguisher and a battery master switch/emergency shut-off preparation do not make the car lighter either - but safer.
So the BMW M3 GTS concept vehicle puts the scales up to around 1490 kilograms - causing the engineer to give an appreciative nod.
And the drivetrain? The heart of the BMW M3 GTS?
The car is fitted with a 7-speed M dual clutch transmission with adapted shift characteristics. But an absolute highlight is to be found under the bonnet. Exclusively for the BMW M3 GTS, the engine builders of BMW M - recent winners of the Engine of the Year Award once again - have developed a power unit based on the M high-performance engine of the current BMW M3: with a capacity of 4.4 litres and an output of some 450 bhp, it will catapult the light BMW M3 GTS into a whole new sphere.
After all, the aim is to clearly beat the lap time of the legendary M3 CSL on the Nürburgring Nordschleife. And test runs certainly give grounds for optimism.
Skazzy is offline   Reply With Quote
Old 11-04-2009, 04:34 PM   #24
Skazzy
My Ride: X Wing
this sub-forum is gay, IMO this needs to be moved to the SHOWROOM! so friggin seksy
Old 11-04-2009, 04:42 PM   #25
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
cowmoo32 is online now   Reply With Quote
Old 11-06-2009, 02:53 PM   #26
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Well Said!
Old 11-06-2009, 04:43 PM   #27
baller2all
My Ride: BMW E46 M3
Can't believe they did not use their new motorsport performance seats or csl seats would of been a done deal....regardless still sick.
baller2all is offline   Reply With Quote
Old 11-10-2009, 07:17 AM   #28
Snik
Snik's Avatar
My Ride: IR M3 Vert.
BMW M3 GTS: An M3 CSL or GTR Successor?
So with BMW bringing out the new E92 M3 GTS, the thought, "Well, here's the closest thing to a CSL we'll see from BMW for the current M3." But then I started thinking, "Could this actually be closer to that of the E46 M3 GTR?"
The GTR was made in such limited numbers that only five are believed to be in existence. The GTR was also the first factory V8 powered M3. It had a a 4.0L V8 producing roughly 380hp DIN and 288lb-ft of torque (DIN is the modern German standard for horsepower ratings. It can be seen as DIN or PS. It also is measured in Metric Horsepower, instead of the American way of Mechanical Horsepower. DIN hp is measured at the output shaft.), or roughly 374hp in our standard. All this was to power an amazingly light car of only 2,976lbs.
The only reason that the GTR was made was to go along with the Le Mans rules stating that any vehicle raced must be produced in certain numbers for a certain length of time before the racing car starts its season. Since the Le Mans M3 GTR was a V8, the road car had to be, as well.
There was one big problem, though...
Porsche complained once BMW started beating them in their second season. In 2002 BMW won 6 of 8 races in the GT class along with taking a driver's title and the manufacturer's title. But since BMW's M3 street car wasn't a V8, the governing body of the American Le Mans Series was going to force them to add 220 pounds and a new restrictor plate. BMW opted to just hang it up and continue their efforts in Formula 1.
GTS - CSL
GTS - GTR
The CSL was a much different story for BMW, on the other hand. It was built as a more tuned and special version of the E46 M3. It wasn't a racing car, but it was meant for the track and less so for the street. It was quite a bit more than the standard M3, but then again, it was quite a bit more of a car. Gone were the fog lamps, gone were the seats, air-con, stereo, rear glass, and so many other things. One big thing that went that should have been kept was the manual transmission. It was replaced with BMW's SMG II transmission... Ugh.
But, it was still a monster of a car. It had the same 3.2L inline-6 as the regular M3, but it now put out 360hp instead of 333. The CSL also came with slick racing tires, which weren't meant for anything less than perfect street conditions to drive in. The M3 CSL set the Nürburgring afire with a 7 minute 50 second lap time, which was, at the time, 3-seconds slower than Porsche's 911 GT3 RS (the sportiest of all 911s), it is also the same lap time that Porsche set with its 2009 911 Carrera S with PDK, and 9-seconds faster than Cadillac's current hot shoe, the CTS-V. Just watch the Top Gear episode above and see what Jeremy Clarkson has to say about the M3 CSL and watch how fast it is around the Top Gear test track.
The M3 GTS and the M3 CSL have a lot of similarities. They both come standard with lightweight CSL wheels, of which the CSL was the first BMW to get. Both cars also come with a carbon fiber roof, racing seats with racing harnesses, stripped out interiors (no radio, air-con, etc.), revised suspension, brakes, aerodynamics and engines and paddle shift gearboxes. The CSL could, however, be outfitted with stereo and air-conditioning... The GTS also comes without a back seat, whereas the CSL came with two racing style bucket seats in the rear.
The M3 GTS and the M3 GTR also have some similarities. They both have adjustable suspension and rear wings, along with racing seats and the same types of trim that the GTS shares with the CSL. Although the CSL came with special wheels, the GTR rode on the same 19" factory performance wheels. The GTR still had upgraded cross-drilled brakes, like the CSL did, and much like the GTS does today. The only difference is that the E46 M3 had standard non-cross-drilled or slotted brakes, unless it was a CSL, GTR or ZCP model. The E90 series M3s all come standard with cross-drilled brake rotors.
Both cars also did without a rear seat and had roll cages for racing purposes, along with racing harnesses for seatbelts. The only differences are that the GTR was made to be a special street version of the M3 GTR racing car. The M3 GTS is made to be either a weekend track racer, similar to that of the 911 GT3, or it can be turned into a fully functional race car.
With all that said, is the new M3 GTS more like the GTR or the CSL? Well, really, it's a variation of both. Where the GTR had to be made by the rules of Le Mans racing, the CSL didn't have to be made, and neither does the GTS. So, in that way it's more like the CSL. But, the CSL has no adjustable rear wing like the GTR. I could go on and on for days about what each one has and doesn't have in comparison to the other. But what's most important is that the GTS is a successor to both the CSL and the GTR. All three come with carbon fiber bits and body panels all over to make them lighter and faster. It's like both of them in numerous ways, and unlike both of them in other ways.
Do you ride a sportbike?
Old 11-10-2009, 08:22 AM   #29
bimmerfan08
My Ride: F
had to add this video to the thread since its not here yet
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 11-10-2009, 01:41 PM   #30
Snik
Snik's Avatar
